Performance problem needs troubleshooting
Post Date: 2014-06-20
Slappyn View Drop Down
  Quote Slappyn Quote  Post ReplyReply bullet Topic: Performance problem needs troubleshooting
    Posted: 20 Jun 2014 at 3:15am
Hi All,
I have a problem with my computer. At random times it seems to lag. I would blame the internet except its not just pages is everything. The symptom is a glitchyness in my mmo game and freezing where 20 seconds later the battle is over but it looks to me like it has not even began. I have noticed the water cooling system make a sloshing sound a second before the glitching starts. The glitching happens at least once a day, anytime into my computer use (from 5 min on generally) and sometimes goes away on its own or a reset will solve it. This has been going on for a few days. What do you think? Specs below and thanks for helping.
HAFF 922 with an I7 920 oc to 3.4GHz
with an evga x58 micro chip set
win 7 64 bit
6 month old GTX 780
Asetek Liquid CPU cooler
All fans working
Samsung SSD
16GB Ram
  Quote Snaike Quote  Post ReplyReply bullet Posted: 20 Jun 2014 at 3:23am
I'm not an expert, nor even half as knowledgeable as most of the people you'll encounter here, but I have to ask something.
Have you checked your temps/voltages?  Download HWMonitor and see if anything spikes.
I'm sure the smarter people will be here shortly to help, too.  Big%20Smile
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 20 Jun 2014 at 3:27am
Hi Slappyn... I would get some canned air and blow out the case of any dust buildup if you haven't already.   Blow through the fan on your 780 and out the back with power off.
Blow out the Asetek coolers fins behind the fan.   They can plug with dust.
Download and run the free HWMonitor and check your cpu core and 780 gpu core temps while stressing the rig.   Temps should be mid 80C or less.
Good luck.
Snaike beat me to it.
Edited by bprat22 - 20 Jun 2014 at 3:28am
  Quote Slappyn Quote  Post ReplyReply bullet Posted: 20 Jun 2014 at 3:38am
Maybe its not a gushing sound from the radiator but it kinda sounds like one.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 20 Jun 2014 at 3:49am
If you have noise coming from the rad or the pump unit mounted to the cpu, then it's a good chance the unit is failing. Try blowing out the rad and checking temps.   Temps will tell you if that's it or a problem elsewhere.
If the temps are good then you could have a bad ram stick, a drive starting to fail, etc.
  Quote Slappyn Quote  Post ReplyReply bullet Posted: 20 Jun 2014 at 4:37am
Everything looking good here. Ill give it a good go over again for dust and check the rams sticks. Thanks
CPUID HWMonitor Report
Binaries
HWMonitor version     1.2.5.0
Monitoring
Mainboard Model          121-BL-E756 (0x00000263 - 0x047853E0)
LPCIO
LPCIO Vendor          Fintek
LPCIO Model          F71882F
LPCIO Vendor ID          0x1934
LPCIO Chip ID          0x541
Config Mode I/O address     0x4E
Config Mode LDN          0x4
Config Mode registers
          00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
     00     FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
     10     FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
     20     05 41 20 19 34 00 00 3E 30 00 40 20 08 0A 00 00
     30     01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
     40     FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
     50     FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
     60     02 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
     70     00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space          LPC, base address = 0x0290
Hardware Monitors
Hardware monitor     Fintek F71882F
     Voltage 0     3.39 Volts [0xD4] (+3.3V)
     Voltage 1     1.33 Volts [0x71] (CPU VCORE)
     Voltage 2     1.51 Volts [0x80] (DRAM)
     Voltage 3     1.35 Volts [0x88] (CPU VTT)
     Voltage 4     1.13 Volts [0x72] (NB CORE)
     Voltage 5     5.13 Volts [0x7A] (+5V)
     Voltage 6     12.26 Volts [0xA6] (+12V)
     Voltage 7     3.38 Volts [0xD3] (VSB3V)
     Voltage 8     3.28 Volts [0xCD] (VBAT)
     Temperature 0     39°C (102°F) [0x27] (CPU)
     Temperature 1     46°C (114°F) [0x2E] (VREG)
     Temperature 2     27°C (80°F) [0x1B] (System)
     Fan 0          1319 RPM [0x471] (CPU)
     Fan 1          1771 RPM [0x34F] (JPPWR)
     Fan 2          688 RPM [0x885] (JCHA)
     Fan PWM 0     100 pc [0xFF] (CPU)
     Fan PWM 1     100 pc [0xFF] (System Fan 1)
     Fan PWM 2     100 pc [0xFF] (System Fan 2)
     Fan PWM 3     50 pc [0x80] (System Fan 3)
     00     FF 03 00 00 FF FF FF FF FF FF 01 51 55 4C 00 00
     10     00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
     20     D3 70 80 89 72 7A A6 D4 CD FF FF FF FF FF FF FF
     30     FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
     50     FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
     60     00 00 00 00 FF FF 04 00 00 00 FF 0E 40 2A FF 00
     70     FF FF 28 FF 2E FF 1B FF FF FF FF FF FF FF FF FF
     80     FF FF 64 55 5A 55 55 46 FF FF FF FF FF FF A8 FF
     90     00 08 08 00 00 FF 7F FF 44 22 FF 55 55 55 FF 1A
     A0     04 6B 00 FF 02 C3 3C 32 28 1E FF D9 B2 99 80 0D
     B0     03 4D 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0E
     C0     08 87 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
     D0     0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
     E0     FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
     F0     00 00 00 00 00 00 3F FF 01 72 FF 00 FF FF FF FF
Hardware monitor     ACPI
     Temperature 0     39°C (102°F) [0xC32] (THRM)
Hardware monitor     NVIDIA NVAPI
     Voltage 0     0.86 Volts [0x35E] (VIN0)
     Temperature 0     31°C (87°F) [0x1F] (TMPIN0)
     Fan 0          1305 RPM [0x519] (FANIN0)
     Fan PWM 0     39 pc [0x27] (FANPWMIN0)
Processors
Number of processors          1
Number of threads          8
APICs
Processor 0
     -- Core 0
          -- Thread 0     0
          -- Thread 1     1
     -- Core 1
          -- Thread 0     2
          -- Thread 1     3
     -- Core 2
          -- Thread 0     4
          -- Thread 1     5
     -- Core 3
          -- Thread 0     6
          -- Thread 1     7
Timers
     ACPI timer          3.580 MHz
     Perf timer          3.507 MHz
     Sys timer          1.000 KHz
Processors Information
Processor 1               ID = 0
     Number of cores          4 (max 8)
     Number of threads     8 (max 16)
     Name               Intel Core i7 920
     Codename          Bloomfield
     Specification          Intel(R) Core(TM) i7 CPU        920 @ 2.67GHz
     Package (platform ID)     Socket 1366 LGA (0x1)
     CPUID               6.A.5
     Extended CPUID          6.1A
     Core Stepping          D0
     Technology          45 nm
     TDP Limit          130 Watts
     Core Speed          3590.8 MHz
     Multiplier x Bus Speed     18.0 x 199.5 MHz
     Rated Bus speed          3590.8 MHz
     Stock frequency          2666 MHz
     Instructions sets     MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
     L1 Data cache          4 x 32 KBytes, 8-way set associative, 64-byte line size
     L1 Instruction cache     4 x 32 KBytes, 4-way set associative, 64-byte line size
     L2 cache          4 x 256 KBytes, 8-way set associative, 64-byte line size
     L3 cache          8 MBytes, 16-way set associative, 64-byte line size
     FID/VID Control          yes
     Turbo Mode          supported, disabled
     Max turbo frequency     2933 MHz
     Max non-turbo ratio     18x
     Max turbo ratio          22x
     Max efficiency ratio     12x
     TDC Limit          110 Amps
     Core TDP          110 Watts
     Uncore TDP          20 Watts
     Power @ 12x          52 Watts
     Power @ 13x          61 Watts
     Power @ 14x          71 Watts
     Power @ 15x          83 Watts
     Power @ 16x          97 Watts
     Power @ 17x          112 Watts
     Power @ 18x          130 Watts
     Max bus number          255
     Attached device          PCI device at bus 255, device 2, function 0
     Attached device          PCI device at bus 255, device 3, function 4
sabahat View Drop Down
  Quote sabahat Quote  Post ReplyReply bullet Posted: 09 Nov 2014 at 10:00pm
I too tend to avoid BIOS updates unless the update fixes a specific problem that I am experiencing and it is that last thing I can do before replacing the motherboard.
sabahat
