Please advice on my build!!!
Post Date: 2011-02-18
PCP View Drop Down
  Quote PCP Quote  Post ReplyReply bullet Topic: Please advice on my build!!!
    Posted: 18 Feb 2011 at 4:19pm
Hi please help me out with my build, if all good I will place my order this weekend.
[$2000]
[Good computer to run today's games and can upgrade to run future games]
[games and watch movies online]
[I pick i5 chip cause it is lower price and good for gaming. I pick air cool stage 2 cause I am worry about overheating, I also added 6 fans. I didn't choose Nvidia 570 card cause probably in few months it will drop in price I can upgrade better card in the future]
Saved Ticket #: [487717]
[Specifications:
Processor: Intel Core i5 2500K 3.30GHz (Unlocked CPU for Extreme Overclocking) (Quad Core)
Motherboard: ASUS P8P67 (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s)
System Memory: 4GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Video Card: 1x NVIDIA GeForce GTX 560 Ti 1GB (Includes PhysX Technology)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional (PCI-Express Slot Based)
Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Xtra Large)
Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty]
Thanks!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Feb 2011 at 4:24pm
What res?
PCP View Drop Down
  Quote PCP Quote  Post ReplyReply bullet Posted: 18 Feb 2011 at 4:35pm
My resolution is " 1920X1080 2ms Full HD HDMI "
Thanks for the fast reply!!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Feb 2011 at 4:45pm
2ms is bs number pay no attention to it, so is contrast ratio, fyi.
Here you go Ticket# 487737 --- $1701 (To see this build click here)
to correct your own config it would be the above, personaly I like this better:
Here you go Ticket# 487738 --- $2088 (To see this build click here)
Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX)
this system will do better in the future cpu-wise and can also do sli 560/570/580, in short if you find yourself needing more gpu power for some games, you can go ahead and add a second gpu.
no matter what you do, with the haf x case ask DS specifically to add this 200mm to the top, so that you have 2 of those on top:
haf 200mm non led fan
PCP View Drop Down
  Quote PCP Quote  Post ReplyReply bullet Posted: 18 Feb 2011 at 5:40pm
Thank you for the reply. Just a quick question:
whats the reason not to upgrade to Zalman fans?
corybo7 View Drop Down
  Quote corybo7 Quote  Post ReplyReply bullet Posted: 18 Feb 2011 at 10:32pm
with the HAF-X it provides excellent airflow already.....the extra fans are 120mm fans and they are loud....not really needed
"Kindness is the Oil that keeps Friction out of Life" -myself
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Feb 2011 at 7:07pm
the fan upgrade is only six fans, not all fans, and they are loud, also the haf x comes with 3 x 200mm fans and if you do as I say and add another, you will endup with 4 x 200mm fans, for great airflow.
pretty much what cory said.
  Quote corybo7 Quote  Post ReplyReply bullet Posted: 19 Feb 2011 at 7:18pm
@DST....I believe the front fan on the HAF-X is 230mm.......230mm front LED red fan.....200mm fan on the side....and 2 200mm fans on the top......1 of those being optional....and a 140mm fan on the back of the case.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Feb 2011 at 7:56pm
The front is 230mm but I repeat this so manytimes a day that its easier to just say 4 x 200mm, then get into it more if the user wants to change the to led fans.
but if you look at my posts that users what to change to led, you will see me say its a 230mm led and provide a link to a 230mm led blue.
the HAF X comes with the fans you mentioned with the option of adding a second to the top.
  Quote corybo7 Quote  Post ReplyReply bullet Posted: 19 Feb 2011 at 8:14pm
ok gotcha....
