please comment config build for purchase
Post Date: 2013-02-21
mlamanna View Drop Down
  Quote mlamanna Quote  Post ReplyReply bullet Topic: please comment config build for purchase
    Posted: 21 Feb 2013 at 6:25am
Budget:1800-2000
[Please Type Here]
Expectations:will upgrade ram to 16 and sli at a later date
[Please Type Here]
Usage:for gaming and some photo/video work. 24in 1080p display
[Please Type Here]
Specifications:Specifications:
Chassis Model: Special Deal Hot Seller - Corsair Carbide 500R (Black Finish)
System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) <b></b>
Hard Drive Set 1: Operating System: 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache)
Video Card: 1x NVIDIA GeForce GTX 670 2GB (Includes PhysX)
[Please Type Here]
Edited by mlamanna - 21 Feb 2013 at 6:41am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 7:48am
Hi mlamanna...  Welcome to the forums.
That's a real nice build.  Strong
 Just for another way to go , here's a build with a quad channel memory mobo as opposed to the Z77's dual channel memory.  The quad channel's larger  memory bandwidth might help with your video editing if you get into it with any degree, plus already has the 16gb ram.
Also the Noctua d14 air cooler will perform great and quieter than the Vortex 120 and the big block of cooling fins leave little to go wrong.  The Vortex units are smaller, have a real good reputation, but I like reliability and quiet if possible without sacrificing perfromance.
Config # 790265    Cost $ 2066
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
Nothing wrong with your build but this is an alternate to consider.
Good Luck. Big%20Smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 11:54am
BP has a good build for you.
I like the haf x better, its gonna be more quiet and I like big fans over smaller ones cause they are more quiet and move more air, but the 500r is a good case too, depending on its fans tho it could be loud.
  Quote mlamanna Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 2:12pm
Thanks for the respones so far,
I really need to keep it just under $2000, so I can't do the haf x Cry
but is is nice...
If I stick with the 3770/z77 combo I can do the haf x
here is my new build with same case but different combo
Ticket Number: 790343
Total Price with Instant Savings: $1,945.00
Motherboard: ASUS P9X79 PRO (Intel X79 Chipset) (Features USB 3.0 and SATA
6Gb/s) <b></b>
(7200 RPM) (32MB Cache) <b></b>
Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL /
Network Connections)
Cooler (High-Performance Edition) <b></b>
Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is
Successfully Processed
  Quote Asangard Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 2:31pm
Look really good but you left out the 2 most important parts.  Your Free Game and your free T-Shirt.Big%20Smile
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 2:32pm
Check out Config # 790510     Cost$ 1988.
I can't cut/ paste right now.   This gives you HafX.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 2:36pm
Bprats config
Chassis Model:Special Deal Hot Seller - Cooler Master 942 HAF X
More Info
Exterior Finish:- Standard Factory Finish
Trim Accents:- Standard Factory Finish
Core Components
Processor:Intel Core i7 3770K 3.50 GHz (Unlocked CPU) (Quad Core)
More Info
Motherboard:ASUS SABERTOOTH Z77 (Intel Z77 Chipset) (Features Thermal Armor and Thermal Radar)
More Info
System Memory:8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
More Info
Power Supply:800W Corsair GS (Dual SLI Compatible)
More Info
Storage / Connectivity
Expansion Bay:- No Thanks
Hard Drive Set 1:1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition)
More Info
Set 1 Raid Options:- No Thanks
Hard Drive Set 2:- No Thanks
Hard Drive Set 3:- No Thanks
Optical Drive 1:DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
More Info
Optical Drive 2:- No Thanks
Internet Access:High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections)
More Info
Graphics / Multimedia
Video Card(s):1x NVIDIA GeForce GTX 670 2GB (Includes PhysX)
More Info
Add-on Card:- No Thanks
Sound Card:Integrated Motherboard Audio
More Info
Digital Storm Engineering Lab
Extreme Cooling:H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition)
More Info
Chassis Airflow:Standard Factory Chassis Fans
More Info
Internal Lighting:Internal Chassis Lighting System (Red)
More Info
Enhancements:- No Thanks
Chassis Mod's:- No Thanks
Noise Reduction:- No Thanks
LaserMark:- No Thanks
Digital Storm TwisterBoost Technology
CPU Boost:Stage 1: Overclock CPU 4.0GHz to 4.4GHz
More Info
Video Boost:- No Thanks, Please do not overclock my video card(s)
Memory Boost:- No Thanks, Please do not overclock my memory
OS Boost:- No Thanks, Please do not tweak the services on the operating system
Software
Windows OS:Microsoft Windows 7 Home Premium (64-Bit Edition)
More Info
Recovery Tools:Windows Recovery Toolkit (Bundled with Windows CD)
More Info
Virus Protection:- No Thanks
Office Suite:- No Thanks
Game:- No Thanks
Accessories / Goodies
Display:- No Thanks
Surge Protector:- No Thanks
Audio:- No Thanks
Keyboard:- No Thanks
Mouse:- No Thanks
External Storage:- No Thanks
T-Shirt:FREE: Digital Storm T-Shirt - Black (Large)
More Info
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 4:30pm
Changed cooling on bp's build, you gotta be able to do this one, its only $18:
Here you go Ticket# 790584 --- $2018 (To see this build click here)
on your own config you have a few problems, for example we recommend the 1TB black caviar because its a fast and solid drive, you chose the regular 1TB which does not offer the speed and quality of 1TB BC.
Edited by DST4ME - 21 Feb 2013 at 4:31pm
  Quote mlamanna Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 7:55pm
Is the Noctua NH-D14 SE2011 really that much better than the DS vortex liquid cooler? I think I am going with the #790584 build, just don't know about the cooler yet
Edited by mlamanna - 21 Feb 2013 at 7:58pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 7:56pm
nothing beats it till you get to stage 4 subzero.
