Please help me tweak! About to Purchase.
Post Date: 2011-10-21
jgortner View Drop Down
  Quote jgortner Quote  Post ReplyReply bullet Topic: Please help me tweak! About to Purchase.
    Posted: 21 Oct 2011 at 12:12pm
Hi Everyone!
About to purchase but just wanted to get some advice from this great community!  Please respond with words of advice or approval.
Budget
As far under $2,000 as possible.  Looking for most performance for the dollar without having to pay large amounts ($100 to $200) for small FPS rewards.
Expectation
Single Monitor at 1080p with no plans to ever upgrade resolution.  Maybe a second monitor down the road so I can look up quests while playing.  Want to play current games and games released for next 2 to 3 years at very high settings.
Usage
Games will be the most demanding thing I do.
Special Needs
Would prefer the PC to be as quiet as possible.
I tried to upgrade things up to before there was a big jump in price.
BUILD - $1481
607729 (clickable link - summary below)
Cooler Master Storm Enforcer
Intel Core i5 2500K 3.30GHz
ASUS P8P67 (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI)
8GB DDR3 1600MHz Digital Storm Certified Performance Series
600W Corsair CX600 V2
128GB Solid State (By: Crucial) (Model: RealSSD C300 CTFDDAC128MAG-1G1) (SATA 6Gbps)
Wireless PCI 802.11n Up to 300Mbps (Supports 802.11n/g/b) (Model: 3FMPCIMWN-R)
ATI Radeon HD 6950 2GB
Standard Factory Heat-sink and Fan (Not Recommended for CPU Overclocking)
Standard Intel Turbo Boost 2.0 Automatic Overclocking
Edited by jgortner - 21 Oct 2011 at 12:15pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Oct 2011 at 4:37pm
to do what you asked (Want to play current games and games released for next 2 to 3 years at very high settings) you need slicf 570/6970. which is our of your budget, best we can do is give you a system that can do sli/cf but has one gpu right now, you add the ssd and the second gpu later yourself.
your config is all kinds of wrong.
so let me know what you like to do, single system with no sli/cf ability or single system with sli ability, fyi single system with sli ability will land around $2000.
