Please help me with my configuration
Post Date: 2013-02-13
Brute Force View Drop Down
  Quote Brute Force Quote  Post ReplyReply bullet Topic: Please help me with my configuration
    Posted: 13 Feb 2013 at 7:00am
Budget: $1800-$2200
Expectations: Play BF3 and other current games with some future proofing. I'd like to get 5 years or more out of the system.
Usage: In addition to gaming this will be a work and family PC running typical Office programs, storing pictures, etc.
Special Needs: PC case specs need to be around 20"D X 19"H X "W This will be in a cabinet of a desk so I"m concerned about cooling. there's some flexibility with the depth but not so much on the height and width.
Saved Ticket #: 786512 I liked the ODE V2 Level 3 but the case is too large so I created this custom with the same performance in a smaller case.
Please let me know your thoughts. I'm open to suggestions!
Thanks
BF
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 13 Feb 2013 at 7:35am
Hi Brute Force....   Welcome to the forums.
You din't mention monitor size or resolution but this will play on a 1920x1080 or smaller real nice.
5 years is a bit of a stretch for decent gaming.  Graphic cards usually need updating within 2-3 years to stay on top, which you can easily do with this setup.
Nice build.   I would suggest changing to the gtx 670 for your best bang for the buck.  The 670 is almost the same gaming as the 680, within a few fps, and alot less.
cpu cooler....  The Hyper 212 is all you need for stage 1 oc and is very reliable.  If you want to stay with the sealed, smaller profile coolers, spend another $20 for the Corsair H100i.  Its a better radiator, fans and larger tubing and the fans can be software adjusted with Corsair Link.    The Vortex on preset high settings can be loud unless a resistor pac is used to slow the fans.  DS will supply it.
I wouldn't put a gaming rig inside a closure.  It really needs room to breath.  Really don't want to recycle already heated air.  On top of a desk or small table is alot better.
Don't forget the free t-shirt.
Looks good.  Hope this helps and good luck. Big%20Smile
Edited by bprat22 - 13 Feb 2013 at 7:43am
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 13 Feb 2013 at 6:17pm
Hello Brute Force!   Good advice from the venerable forum wizard bprat.
A couple suggestions to offer here, as I recently set up & tested an Epoch build in the same excellent compact Corsair 300R case.
Having just had hands on the one I had DS build using a big air cooler, I sure would recommend you stay with the efficient closed loop liquid coolers in the small 300R case.     With a Stage 1 Overclock, you would be fine using the Vortex 240 cooler you had selected in your build, or the better new Corsair 100i cooler.   Both would use 2 x 120mm intake fans to cool the radiator mounted in the top of the case.      Using one of the air coolers with their rather huge heatsinks really fills up the small case interior volume, and makes it harder to see the board or to reach in and work on fan ports or ram on the board.     The big air coolers heatsink stacks also will block you from using at least one available window fan mount due to lack of clearance.
I would also recommend adding one of the fan upgrade selections if you can afford it, or you could easily add the fans yourself.     The Corsair 300R case is compact & well vented, and has 5 additional fan mounts available to improve cooling airflow to your warm components.     If you are going to game, you will want to make use of the available added air.      The 2 extra fan mounts on the window can take 2 X 120mm or 140mm fans.      140mm fans would generally provide better airflow, wh ile being quieter than the smaller faster RPM 120mm fans.     Using the two window fan mounts in particular would help your graphics card stay cooler and perform it's best for you.
For the 5 year future proofing you seek, you might want to upgrade to the better Z77 Sabertooth motherboard with it's longer ASUS 5 year manufacturer warranty... The other boards carry only 3 year mfg warranties.    Also...the LX board can't do SLI graphics cards, but Sabertooth would allow you to keep up longer by adding a second matching NVidia video card, easily doubling your video performance when you need a boost.    Adding another graphics card is a simple & fairly common way to make the rig work longer for you.
Remember to select your free game and shirt!
See what you think... Like the case a lot... Easy size to move...will look sharp lighted with red...lots of options for easy fan or hard drive additions....
Edited by HockeyBuck - 13 Feb 2013 at 6:30pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Feb 2013 at 11:17am
HockeyBuck is our resident 300R specialist Big%20Smile so lots of good info there. Strong
  Quote Brute Force Quote  Post ReplyReply bullet Posted: 14 Feb 2013 at 11:40am
Guys, thanks for the feedback!  I think I've incorporated all your feedback into this upgraded config.  Please review and let me know if I captured everything, and if you have any other suggestions.  I'm now officially over budget!  Oh well, it's not not by much!
Config:787080
Chassis Model: Special Deal Hot Seller - Corsair Carbide 300R (With Window)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R)
Video Card: 1x NVIDIA GeForce GTX 670 2GB (Includes PhysX)
Extreme Cooling: H20: Stage 2: Corsair H100i 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition)
Chassis Airflow: Upgrade All Fans to Corsair Airflow 140mm Performance Edition (Up to 6 Fans)
Game: FREE NVIDIA Bundle - Assassins Creed III (Digital Download Code for all GeForce GTX 600 Series)
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Feb 2013 at 11:53am
Nice. Strong
Over budget, don't we all? Hahaha  but a quality build.
Good Luck. Big%20Smile
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 14 Feb 2013 at 12:26pm
Much better build for you Brute Force... Well done sir!       Going to be a fun gaming rig with a 670 to play with, and when it's time a 2nd 670 should cost a bit less, and 2 X SLI 670 will dramatically improve gaming performance!      Always nice to have options all planned out....if only briefly, it makes us appear smart & helps convince our wives to go along...lol.
The excellent Corsair Airflow series 140mm fans will keep things cool in the case, and come with red, white, and blue colored snap on trim rings to choose from....so you can have red to match your red light ... DS will put the 240mm cooler and its 2x 120mm fans in the top...The fan upgrade will replace the stock 140mm's front & back....and you'll get 2x 140mm airflows as front intakes, 2 x 140mm airflows as side window intakes for your GPU, and a 140mm airflow rear exhaust.     Ask them in comments section to use the red rings on them.
Solid build.    Gotta post some photos for us when it comes!
Edited by HockeyBuck - 14 Feb 2013 at 12:41pm
  Quote Brute Force Quote  Post ReplyReply bullet Posted: 15 Feb 2013 at 7:58am
Thanks for the help. I'm not going to pull the trigger quite yet but will let you know when I do.
  Quote Brute Force Quote  Post ReplyReply bullet Posted: 15 Feb 2013 at 11:56am
I forgot to ask. What monitor would you guys recommend? How about keyboard and mouse?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Feb 2013 at 12:05pm
Alot of us use the Dell UltraSharps, like the U2312HM.   A quality IPS monitor for gaming.
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 15 Feb 2013 at 1:24pm
The Dell Ultrasharps are excellent and dependable IPS displays. I use the U2412m 24" model and it runs around $320 if you can find it in stock....very popular.
My fav gaming mouse is the Logitech G9X laser mouse...comes with two different shape hand grips to choose from, and weights to adjust how heavy you like it....Sensitivity in DPI is adjustable right on top.
Keyboards depend more on your needs... If you game or use the PC a lot at night, you might want a backlit LED gaming keyboard....but things like tactile feel of the keys and shape of keyboard are more personal & individual... You might want to go to a computer retailer that has some on display for you to try in the store for feel.
For basic computing & ergonomics the Microsoft 4000 keyboard isn't backlit or a gaming board, but is great for relaxing the hand and preventing wrist problems. Has some multimedia controls.
The Corsair K90 backlit mechanical gaming keyboard is solid built and works great.
The Razer Blackwidow 2013 Ultimate backlit mechanical keyboard is what I currently use, and I like it a lot.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 15 Feb 2013 at 1:27pm
The Max keyboards i heard are good. They are fully mechanical and backlight. Different colors to choose from but its only one color not mulitbacklighting unless you choose to customize it. The colors to choose from are (green, purple, orange, red, white or blue) also you get to pick which cherry mx switches you want. I'm planning on buying one soon.
Edited by ArkansasWoman777 - 15 Feb 2013 at 1:34pm
  Quote Brute Force Quote  Post ReplyReply bullet Posted: 17 Feb 2013 at 6:16am
Should I stick with Windows 7 or should I consider going with 8?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Feb 2013 at 7:04am
I use Win 7 and have no intention of updating.  If I bought a new pc I probably would go Win 8 just to try new and different, but it is a love/hate relationship for many.
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 17 Feb 2013 at 8:39am
No reason for a PC user to go Win 8 in my opinion....Unless you require a touch screen monitor, stay Win 7.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Feb 2013 at 11:15am
Dell UltraSharps are great I just ordered the U2413, those ips panels are great
  Quote Brute Force Quote  Post ReplyReply bullet Posted: 17 Feb 2013 at 2:20pm
Any thoughts on home versus professional addition of Windows 7?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Feb 2013 at 2:34pm
For most, it's whether you want to use over 16 gigs of ram.    Probably not you.
Home would probably do it.
  Quote Brute Force Quote  Post ReplyReply bullet Posted: 18 Feb 2013 at 7:27pm
Does anyone know how many USB ports come on this config? I'm thinking I may need to add a few more.
Edited by Brute Force - 18 Feb 2013 at 7:28pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Feb 2013 at 10:41pm
If you are talking about the sabertooth z77 then:
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
ASMedia® ASM1042 controller : *6
2 x USB 3.0 port(s) (2 at back panel, blue)
Intel® Z77 chipset :
10 x USB 2.0 port(s) (4 at back panel, black, 6 at mid-board)
*6-1: Supports ASUS USB 3.0 Boost UASP Mode.
*6-2: The USB 3.0 ports only support Windows® 7 or later versions.
Edited by DST4ME - 18 Feb 2013 at 10:42pm
  Quote Brute Force Quote  Post ReplyReply bullet Posted: 19 Feb 2013 at 5:47pm
Pardon my ignorance DST4ME, but I'm not sure I'm following your post. How many total ports are there? How many ports are on the front versus rear?
Thanks for your help.
BF
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 19 Feb 2013 at 7:13pm
The front panel of the 300r includes two USB 3.0 connectors and i think there is 8 usb ports on the back where the motherboard is.
Edited by ArkansasWoman777 - 20 Feb 2013 at 4:25am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Feb 2013 at 9:30pm
Front usb ports depends on what the case you are choosing supports.
Back panel:
