Please Help. My 1st DS Rig
Post Date: 2009-01-13
blk331 View Drop Down
  Quote blk331 Quote  Post ReplyReply bullet Topic: Please Help. My 1st DS Rig
    Posted: 13 Jan 2009 at 9:14pm
what's up everyone!
Newbie here and fairly new to custom building a pc. I have a $1400-$1550 budget and would like to get the most bang for my buck. Ouch I'm local so i don't have to worry about shipping. I tried several configurations but i don't have the experience to know whats best. Big%20smile I basically just want to be able to play any game out there and not have to upgrade too soon.
Here is a ticket # i tried let me know what you guys think.
Ticket # 229014
Thanks in advance!!!!!!!Thumbs%20Up
Chassis Model: Antec 900
Processor: Intel Core 2 Duo E8400 3.00GHz (1333MHz Front Side Bus) (6MB Cache)
Motherboard: CLEARANCE HOT SELLER: NVIDIA 650i Core 2 Quad (Chipset: nForce 650i Ultra)
System Memory: 2GB DDR2 667MHz Corsair
Power Supply: 550W Corsair HX (Dual SLI Compatible) (Silent Edition)
Hard Drive Set 1: Operating System: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology)
Windows OS: Microsoft Windows Vista Home Premium
LCD Display: - No Thanks
Priority Build: - No Thanks
Edited by blk331 - 13 Jan 2009 at 9:16pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 9:19pm
honestly I say save another $500 and come back and I will show you a system that will last you and be very respectable for a few years to come. A system you can upgrade as you go and make more powerfull down the line.
  Quote blk331 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 9:32pm
dam another $500Wacko  yea I thought i would hear something like that..
Thanks for the help!
Edited by blk331 - 13 Jan 2009 at 9:33pm
  Quote blk331 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 9:40pm
say i save another $500, what would you recommend?
Dsnewb210 View Drop Down
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 10:28pm
This is what you need
Ticket Number: 229065
System Memory: 6GB DDR3 1600MHz OCZ Platinum Edition (High-Performance)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
With the current promotion this should put you right at around 2,534$
  Quote blk331 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 10:50pm
Thanks for the help! but that's another $500 on top of what DST4ME said. I guess my pc is going to have to wait..
what do you think of this one??
http://www.digitalstormonline.com/comploadsavedsd.asp?id=213239
Edited by blk331 - 13 Jan 2009 at 10:50pm
thorndike View Drop Down
  Quote thorndike Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 10:54pm
How about the new AMD chip, it's pretty cheap.
Or maybe the gateway FX6800-001e at best buy for $1250
or a laptop ASUS G50vt-x1 at best buy for $1050.
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 10:58pm
I am sure that in the next few hours or so that the folks on here will be able to get you closer to your targeted price range. DST4ME has helped a lot of people get the optimum system at the best price.  When the price just isn't workable he has been able to redo the build and reach a happy medium that is cutting edge and still affordable.  I have been ghosting the forum for a month or two and I am very pleased with what I have seen here.
The only thing I can give as advice is that sometimes it is better to spend just enough that it hurts a little because it is so difficult to try to upgrade primary components of a killer system.  Give this a day or two and your dream machine will start to take form in an affordable fashion.  I am watching and learning myself.  Every post I see helps me narrow on an ultimate system.
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:06pm
Best thing you can do is wait for DST4ME to post a config, I kinda suck at it... Because im the kinda max everything out guy lol...
  Quote blk331 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:10pm
not really fond of gateway and would want to stick with a desktop but thanks for your input. I will check out the AMD chipThumbs%20Up
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:13pm
^ Thanks for the help! but that's another $500 on top of what DST4ME said. <span id="userPro59928" title="View Drop Down"></span> I guess my pc is going to have to wait..what do you think of this one??http://www.digitalstormonline.com/comploadsavedsd.asp?id=213239
I was going to recommend the special but to be honest, it comes with a v8 cooler for ocing but its does not come with oc, so if you know how to oc yourself then it would be good for you, the other thing is that it comes with vista 32bit instead of 64bit.
and the problem with the special is that you can change anything in the config.
this is the best I can do
here you go Ticket# 229084 --- Price: $2081 (To see this build click here)
System Memory: 3GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Power Supply: 750W Corsair TX (Dual SLI Compatible) (Silent Edition)
Video Card: 1x NVIDIA GeForce GTX 260+ 896MB (216 Streams) (Includes PhysX Technology)
I would feel more comfortable with a 1000w psu
  Quote blk331 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:13pm
thanks! this was helpful!Thumbs%20Up
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:14pm
The other great thing about not going with the special deal, is the Haf 932 case.
Its a really good case that has tons of space for future upgrades. The antec 900 is pretty restrictive.
gogo 1000w psu?
Edited by Dsnewb210 - 13 Jan 2009 at 11:21pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:22pm
well I think by the time he saves another $500 the prices have gone down also
  Quote blk331 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:24pm
This looks a little better thanks DST4ME for the help and time i appreciate it! Looks like im going to have to save some more moola and i will continue to review more options. This site rocks!
  Quote blk331 Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:28pm
gogo 1000w psu?
I see.Ermm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:31pm
My pleasure and good luck
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 13 Jan 2009 at 11:33pm
I put the last ticket that dst4me built in my cart to see what the spedial price today was and it was cheaper because of an ongoing promotion.
105950 Digital Storm Desktop 94347
< = value=1 name=quantity1>1
$2,081.00
$2,081.00
< = value=yes name=ed2>101944 -- PROMOTIONAL LIMITED TIME BONUS DISCOUNT: $125
< = value=1 name=quantity2>1
($125.00)
($125.00)
Sub-Total:
$1,956.00
  Quote blk331 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 12:49am
$2,081.00
$2,081.00
($125.00)
($125.00)
Sub-Total:
$1,956.00
I think you forgot taxes.. around $172.00 here
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 4:26am
yes when you press submit you get another $125 off due to current promotions
Edited by DST4ME - 14 Jan 2009 at 4:27am
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 7:32am
I am pretty lucky about online taxes since I live in Illinois.  Most of the stuff I buy is out of state and gives me a good break when I buy online. Anyhow, it seems that the gap of affordability is narrowing and your dream machine will be heading your way pretty soon.
  Quote blk331 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 2:37pm
Ermm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 2:40pm
ya unless you live in California I don't think you will pay taxes, not sure about this tho.
  Quote blk331 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 2:49pm
cool for Onkel_Ken.. I live in California about 20min away from the DS Facility so i gotz to pay taxes Unhappy
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 2:50pm
Makes me happy i don't live in cali anymore.. I get to escape sales tax, traffic and endless smog. Yay me! Shocked
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 2:53pm
or have one of your friends that is in the next state over to buy and then go get it from him, otherwise ya, taxes for you
  Quote blk331 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 2:57pm
yup, traffic sucks big time and smog every two years.Unhappy That's the reason i had to get rid of my modified Mustang.
  Quote blk331 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 3:00pm
only friend would be in Texas..too far for me Big%20smile I guess its taxes for meQuestion
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 3:01pm
Smile I was talking about the air quality out there, they are tough on emissions though.
  Quote blk331 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 3:03pm
oh..rightSmile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 3:04pm
how much will it cost you to drive to Texas and back? isn't' that gonna cost more then the taxes?
  Quote blk331 Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 3:11pm
yup, 1,882 mi to Houston, TX Big%20smile
XpubuX View Drop Down
  Quote XpubuX Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 3:53pm
just send him the money have him pay for it then pick it up "for him"
