Please help Review my Build
Post Date: 2021-01-18
SarcasticSensei View Drop Down
  Quote SarcasticSensei Quote  Post ReplyReply bullet Topic: Please help Review my Build
    Posted: 18 Jan 2021 at 2:44pm
[4k to 5k]
[Able to run most if not all Triple A titles at Max settings]
[Daily Gamer and plan to start streaming as well]
Hi all i recently purchased this config from Digital storm i spent weeks researching what I think i'd need but only after purchasing today i found the forum lol. No one has reached out to me just yet from Digital storm so i'm sure some changes can be made if needed. But i'm just looking for any helpful feedback on my choices for the build. Thanks in advance.
Chassis Model: Digital Storm BOLT X
Trim Accents: Edge to Edge Premium Tempered Glass
Processor: Intel Core i9-10850K (5.2 GHz Turbo) (20-Thread) (10-Core) 3.6 GHz
Motherboard: ASU STRIX Z490-I Gaming / MSI MEG Z490-I UNIFY (Wi-Fi) (Z490 Chipset) (Mini-ITX) (Up to 1x PCI-E)
Power Supply: 800W Digital Storm Performance Series (Modular) (80 Plus Platinum) (Supports up to RTX 3080)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (500GB Digital Storm M.2 Performance Series) <br><strong></strong>
Storage Set 2: 1x SSD (2TB Samsung 860 EVO) <br><strong></strong>
Graphics Card(s): 1x GeForce RTX 3080 10GB (Performance Edition) (VR Ready)
Extreme Cooling: Digital Storm HydroLux PRO LITE (CPU Only)
HydroLux Fluid Color: Clear Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System)
Chassis Fans: Standard Black Fans
Internal Lighting: Remote Controlled Advanced RGB Internal + Front Panel LED Lighting
Airflow Control: - No Thanks
Boost OS: Yes, Disable and tweak all of the non-crucial services on the operating system
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
  Quote Cretae Quote  Post ReplyReply bullet Posted: 19 Jan 2021 at 5:05am
You got the slowest M.2 form factor SSD offered here by an extremley wide margin. Wanna look into that?
  Quote SarcasticSensei Quote  Post ReplyReply bullet Posted: 19 Jan 2021 at 12:21pm
Thanks so much I know all m.2 ssd storage aren't created equally but i didn't know there was such a huge difference in performance. I have since updated my order to m.2 firecuda 500gb 520. Based on the little research i did today seems to be a good choice.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Jan 2021 at 4:28am
