Topic ClosedPlease Help
Post Date: 2012-10-11
Gaarashatan View Drop Down
bullet Topic: Please Help
    Posted: 11 Oct 2012 at 4:57pm
hello, i know a bit about computer hard and software but not everything. can you tell me if these components will work together nicely. if not why? and what else ill need :3. i used tigerdirect for these items
-Case
Cooler Master HAF 912 RC-912-KKN1 Mid-Tower Computer Case - ATX, mATX
-Motherboard
Intel DH67BLB3 Socket LGA1155 Desktop Board - Micro ATX, Socket H2 (LGA1155), Intel H67 Express, DDR3 1333MHz, RAID, SATA 6.0 Gb/s, 1 x PCI Express x16, DVI-I + HDMI, Gigabit LAN, USB 3.0
-Ram
PNY Optima MD8192KD3-1333 Desktop Memory Kit - 8GB (2x4GB), PC3-10666, DDR3 1333MHz
-Cpu
Intel Core i5-2310 BX80623I52310 Processor - Quad Core, 6MB L3 Cache, 1MB L2 Cache, 2.90 GHz (3.20 GHz Max Turbo), Socket H2 (LGA1155), 95W, Fan, Intel HD Graphics, Retail
-Gpu (1)
EVGA GeForce GTX 550 Ti 01G-P3-1556-KR Video Card - 1GB, GDDR5, PCI-Express 2.0(x16), 2x Dual-Link DVI-I, 1x Mini-HDMI, DirectX 11, Dual-Slot, SLI Ready, Plus Photoshop Elements 10 Promo
-Aftermarket Cpu Cooler
Corsair CWCH100 Hydro H100 CPU Liquid Cooler - 120mm Fan, LGA775, LGA1155, LGA1156, LGA1366, LGA 2011, AM2, AM3
-Extra Fans (4)
Cooler Master R4-L2R-20AC-GP Case Fan - 120mm, Blue
-Dvd Drive (1)
Sony Optiarc AD7280S-OB 24x DVDRW Drive - 24x, SATA, Black, OEM
-Operating System
Microsoft Windows 7 Professional FQC-04649 Operating System Software - 64bit, DVD
-Harddrive (1)
WD Blue WD5000AAKX 500GB Desktop Hard Drive - 3.5", SATA, 7200RPM, 16MB Cache
-Fan Controller (gaming kick :3)
AeroCool Touch2000 Fan Controller - 4 Temp, 4 Fan
-PSU
Cooler Master eXtreme Power Plus 600-Watt ATX Power Supply
-Thermal Compound
Cooler Master Thermal Compound
sorry for all the long text, i just want to make sure you get to the right piece of equipment. thank you for all the help. i feel my main problem is the motherboard. also what cords will i need for everything? thanks again. i cant wait to get this stuff at my front door ^^
Edited by Gaarashatan - 11 Oct 2012 at 4:58pm
bullet Posted: 12 Oct 2012 at 5:43pm
Please Help!
Bobby View Drop Down
bullet Posted: 12 Oct 2012 at 7:24pm
Gaarashatan.....in case you don't get a reply, this may explain why: http://www.digitalstormonline.com/forums/forum_posts.asp?TID=18959&PID=209972#209972
Respectfully,
Bobby
bullet Posted: 12 Oct 2012 at 8:00pm
i do understand that, but building a custom computer yourself is just so much cheaper.
bullet Posted: 13 Oct 2012 at 3:49am
It does appear that all the parts would work together.
What is your budget and the cost of these parts?.
Not sure what you're using the pc for.     The cpu and video catd are entry level, meaning gaming on a 19" monitor at 800x600 would be decent in my opinion.
I would consider reducing the added fans for the CM912 to just one more on side or front for example and drop the fan control. The added $$ would allow you to step up to the gtx660, much better gaming if thats the goal.   I would rather have performance over eye candy.
You could also drop the H100 cooler to the stock cooler or A50, H80 etc.   Without overclocking its all you need.   The saved $$ might allow the i5- 3450, 3570 etc.
Have you checked out the Marauder pcs under Special Ops?       Alot of us have built our own in the past because you can save 10-20% but for some of us it got old and we wanted someone else with a great reputation to fall back on.
Good luck either way and let us know how it goes.
Edited by bprat22 - 13 Oct 2012 at 4:11am
bullet Posted: 13 Oct 2012 at 11:28am
I'm sorry but I'll have to close this thread as we would like to keep the forums open for helpful advice for users interested in a Digital Storm PC.
