Please help with final build questions
Post Date: 2009-11-24
Bishop View Drop Down
  Quote Bishop Quote  Post ReplyReply bullet Topic: Please help with final build questions
    Posted: 24 Nov 2009 at 4:18pm
Please help me finalize my choices. I have been going back and forth between the 920 and 860 and I think I am leaning towards the 860.
Here is my thinking. I want a fast gaming PC that will last 3-4 years. I don’t plan on upgrading to the new 6 core chips that will come out or any other CPU for at least 4 years. I am not going to be overclocking, I will probably upgrade the GPU in 1-2 years but will not be doing SLI or Crossfire. Given this will the 860 be enough to run all of the demanding games (FPS, RPG, flight sims) for the next few years?
- Will I need heatsink with the 860 or will the stock do?
- Should I get the 1TB 32MB  or 500GB 16MB version hard drive?
- Should get the P55 SLI or the FTW motherboard? Not sure if I need all of the FTW features.
Trim Accents: - Not Available
Processor: Intel Core i7 860 2.80GHz (Quad Core)
Motherboard: EVGA P55 SLI (Intel P55 Chipset)
System Memory: 4GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Hard Drive Set 1: Operating System: 1x (1TB Seagate/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card: 1x NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Boost OS: - Not Available
e06028 View Drop Down
  Quote e06028 Quote  Post ReplyReply bullet Posted: 24 Nov 2009 at 5:04pm
Because I know they will ask, what resolution will you be gaming at and will you be getting a new monitor in the future with a higher resolution.  After they know that they can help you better. I can also tell you that they won't think a 1TB will be best for your OS.  Try 2 500MB hard drives, one for OS and one for data storage.  Or 1 500MB for OS and a 1TB for backup. To defrag a 1TB takes a long time especially when it has all of your programs and games on it.
Also please provide your ticket number, that will help them speed up the process.
My two cents.
  Quote Bishop Quote  Post ReplyReply bullet Posted: 24 Nov 2009 at 5:37pm
Thanks for the reminder. I will not go beyond 1600x1200. I went with a 1TB because I heard that the Black Caviar drives were better. I would prefer a 640MB Black but they don't have it.
I guess going to 500MB is okay if I am not going to see much of performance impact.
I don't have the ticket number. I guess I can re-create it once my other questions are answered.
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 24 Nov 2009 at 5:58pm
is this a prefab or black ops? letting us know this will better help us help u this way we know what options we have
what will you be using this computer for?
what are your needs?
what is your budget?
in terms of hard drives the more cache you have the more you can do with out turning on your hard drive. doing this you have to wait till it spins to its rpm speed then it has to transfer the data thus slowing it down. the higher the cache the better
  Quote Bishop Quote  Post ReplyReply bullet Posted: 24 Nov 2009 at 6:05pm
This is a prefab configuration. Computer will be used for gaming. see first post.
Budget is about $2K. I could spend more if it is recommended. However, I am wondering if I really need the extra horsepower (CPU * GPU) if the above 860 build would perform in most games if I lowered my resolution a bit?
I guess the 500MB will be enough. The HD will just work a little harder.
Edited by Bishop - 24 Nov 2009 at 6:11pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Nov 2009 at 7:39pm
with stock speed of 2.8GHz you will see a difference in games vs oc speed.
this is much better:
Here you go Ticket# 356903 --- Price: $1824 (To see this build click here) Price after current promotion $1824
Chassis Model: Special Deal Hot Seller - HAF 932
Office: - Not Available
Benchmarking: - Not Available
Edited by DST4ME - 24 Nov 2009 at 7:40pm
  Quote Bishop Quote  Post ReplyReply bullet Posted: 24 Nov 2009 at 9:08pm
Thank you all for the suggestions. I guess I am going to go with the 920.
My concerns were getting a CPU that is slower and needed to be overclocked to get more out of it. I am not technical as you can tell so I have heard negative things about overclocking. I also know that there is a lot of hype and marketing when it comes to CPU & GPU companies. It is just difficult to get the real info.
DST4ME - Thanks for your help again.
1. What internet security and anti-virus would you recommend for online gaming?
2. I am assuming that 750 PSU is more then plenty for future SLI configuration?
3. Will the DS warranty cover any issues including overclocking for the three year?
4. The sales rep. from Micro Center recommended that I get Win. 7 Ultimate 64 bit. Any issues with this versus Professional version?
Thanks.
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 24 Nov 2009 at 11:40pm
1. norton imo is better (more expensive tho/ a lil harder to use) McAffee is very user friendly, but the one they offer i believe is only 30 days of coverage.
2 yes it will handel it
3 DS gives you overclock warranty for 3,4,5 years. doing so voids the intel one but ds has you covered.
4 no he is just trying to get a better comission. pro and ult have XP mode
micro center offers cheap stuff yes but i know of two made by them and they are constantly getting repaired for idiot problems. the people who construct them in the ny store are morons and do things half a$$ed. before the computers ran right they each spent an avg of 12 hrs on the road and 3 weeks fixing it (all the trips combined) avoid them
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 1:52am
Norton and McAfee just give you a false sense of security.  Their scanning engines are complete crap and simple packers/encryptors can hide a malicious exe from detection.
I would highly recommend Kaspersky and Panda.  Panda offers cloud anti-virus for free, though I haven't tried this out yet.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 5:39am
Thanks.
My pleasure
there is nothing wrong with oc when its done right and DS knows what they are doing, your oced 920 is under warranty and should last you minimum of 8 years.
1. ESET Smart Security, it has a 30 day full free trial, try it first then buy a license after 30 days its fast and light and you will love it, forget mcafee and norton
2. 750w will give you dual sli but not tri sli, for that you will need 1000w psu (corsair)
3. yes warranty covers the whole pc as you get it, so if its oced then its under warranty with the oc.
the sales rep from Micro Center is an idiot,
look here and tell me if you see anything that says you should get ultimate, the only reason I chose pro is because of xp support, otherwise I would have recommended premium.
Edited by DST4ME - 25 Nov 2009 at 5:40am
  Quote Bishop Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 12:23pm
Thank you again. I just placed the order.  My first custom build PC. Ouch
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Nov 2009 at 6:23pm
Congrats Let the torture begin
  Quote Bishop Quote  Post ReplyReply bullet Posted: 26 Nov 2009 at 10:28am
Thanks. So, far I am very impressed with DS.
One more question. Will DS load all of the latest drivers? Besides MB and GPU are there any other drivers that I should keep an eye out for on regular basis?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Nov 2009 at 12:20am
actually only gpu drivers are the ones that you want to update, but if you are having smooth gaming and nothing is wrong,I wouldn't even upgrade the gpu drivers for a while.
sometime they can cause problems, some drivers just won't play nice with some people's systems, I think all of us here has had that one time or another, where a gpu driver update just gave bsod or didn't play nice, so we had to go back to the one that was working before it.
and yes DS does load all the drivers.
