Please Help with first Gaming buildPost Date: 2011-03-10 |
| Author | |
dANGLICO
Joined: 10 Mar 2011 Online Status: Offline Posts: 29 |
Topic: Please Help with first Gaming buildPosted: 10 Mar 2011 at 4:54am |
I want to build a computer for gaming, mostly WoW, SC2, COD series shooters, Totalwar Series and future similar types of games. I am new to gaming computers and appreciate the advice. I have a significant budget because I have been saving for four years through four deployments.
I don't really know why but I would like to OC and liquid cool. I admit I do not know much, but am especially confused about the GPU cards and SLI and what kind of monitor make the best combination. I am not commited to that Hanns G monitor but I want something between 25-30 inches with a low response time less than 5ms. My total budget is up to 5.5k. I would appreciate any advice. Thanks Specifications:
Chassis Model: Special Deal Hot Seller - Black OPS HailStorm Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS Sabertooth P67 (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 8GB DDR3 2000MHz GTX-8 Digital Storm Certified Performance Series (Highly Recommended) Power Supply: 1000W Digital Storm Certified (Dual/Triple/Quad SLI Compatible) (Silent Edition Highly Recommended) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (LightScribe Edition) Optical Drive 2: - No Thanks Internet Access: !PROMOTION: Killer 2100 (Optimized for Online Gaming) Lag and Latency Reduction Video Card: 2x SLI Dual (NVIDIA GeForce GTX 580 1.5GB (PhysX) (EVGA Black Ops 015-P3-1583-AR) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect for H20 Tubes) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material) Boost Processor: Stage 2: Overclock the processor between 4.7GHz to 5.2GHz (Liquid Cooling Upgrade Recommended) Boost Video Card: FREE: Yes, Overclock the video card(s) as much as possible with complete stability Boost Memory: Memory Fan Kit Only (Does not include memory overclocking service) Boost OS: FREE: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: FREE: Hot-selling game with a NVIDIA GeForce GTS 250 or above graphics card Display: Hanns G 25 inch X-Celerate OD (Widescreen) (Black) (High-Performance Gaming Display) Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: Razer Lycosa Gaming USB Desktop (Multimedia Keyboard) Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Edited by dANGLICO - 11 Mar 2011 at 12:59am |
"In absence of orders go and find something to kill." Field Marshal Erwin Rommel.
Capt J |
Posted: 10 Mar 2011 at 1:34pm |
For gaming you want to match power to montor res, so first thing we need to know is the native resolution of your monitor, you don't have one so we will need to settle on that first.
Now, couple of things you need to understand about monitors, response time and contrast ratio are BS numbers to fool the buyers. look for a monitor that has the same Viewing Angle, both vertical and horizontal, and is at or above 170°, this is a sign of a quality panel on a monitor, assuring great picture quality, ips panels for example have the best picture quality, but of course they cost more because of it. so what is the budget for the monitor? |
dANGLICO
Posted: 11 Mar 2011 at 12:03am |
I would like to keep my total budget around $5,500. So, Maybe 500-750 or so I am a little flexible on that. I do not want a Monitor less than 24 or more than 30 inches. I am considering Dell UltraSharp U2410. is the Dell UltraSharp U3011 worth the significant price increase? I would like to balance it keeping in mind that I would still like a high end machine with some bells and whistles like LC and OC for fun. I hope that makes sense. Thanks for your help!
Edited by dANGLICO - 11 Mar 2011 at 1:04am |
Capt J |
Alex
Joined: 04 Jun 2012 Online Status: Offline Posts: 16314 |
Posted: 11 Mar 2011 at 1:31am |
For a $5K budget, you might want to consider a nice triple monitor setup with NVIDIA's Surround Technology.
dANGLICO
Posted: 11 Mar 2011 at 2:04am |
What type of monitors and card setup would you recommend for that type of setup?
Capt J |
Posted: 11 Mar 2011 at 2:49am |
Dell UltraSharp U2410 / U3011 are great ones, I think dragoon has the u3011 and loves it, and I can't say I blame him.
so lets say you get the u3011 (you lucky bastard) then this is the pc you want to kick some butt with it: Here you go Ticket# 498691 --- $3752 (To see this build click here) Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS Maximus IV Extreme (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x CrossFire Dual (ATI Radeon HD 6970 2GB) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 3: FrostChill Cooling System: CPU Only H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.7GHz (Cooling Upgrade Recommended) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Ask DS specifically for this fan to be added to the top, so you endup with 4 x 200mm fans: haf 200mm non led fan |
dANGLICO
Posted: 11 Mar 2011 at 3:54am |
I like the idea of the 30inch screen, so lets stick with it. That being said, do you really prefer the Radeon 6970's to the SLI GTX580's? I dont mind the 200$ difference if there is anything to be gained there. I am curious about the benifits of the Maximus IV Extreme. Could you explain that a little please?
Capt J |
Posted: 11 Mar 2011 at 4:22am |
Well going with a big monitor like that, I thought I give you the option of tri fire should you need it, tho the p67 platform is not the best one for tri sli, if you are not interested, we can save money by dropping the psu to 1000w corsair and the mobo to deluxe, which can do dual sli/cf easy.
you won't have any real gain from sli 580 over cf 6970, I like the 6970 for the 2GB of ram in the higher res, but the sli 580 will do good also, its your choice. Edited by DST4ME - 11 Mar 2011 at 4:24am |
dANGLICO
Posted: 11 Mar 2011 at 5:01am |
Thanks, I really appreciate all your help. I wasn't being critical just trying to learn. So the GPUs are pretty much a toss up then and user preference? I had not considered going tri sli, what would be the benifit of that down the road?
Capt J |
Posted: 11 Mar 2011 at 6:19pm |
From what I have seen with good aa, the 6970 cf beats the 580 sli in 2560 x 1600.
being able to add another gpu down the road brings the benefit of more gpu power should the need be there, but like I said the p67 is not the best platform for that. Here you go Ticket# 499100 --- $3463 (To see this build click here) Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x CrossFire Dual (ATI Radeon HD 6970 2GB) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 3: FrostChill Cooling System: CPU Only H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.7GHz (Cooling Upgrade Recommended) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty |
