please review and help with this
Post Date: 2009-11-28
aries1969 View Drop Down
  Quote aries1969 Quote  Post ReplyReply bullet Topic: please review and help with this
    Posted: 28 Nov 2009 at 3:43pm
hello this will be my first custom built pc and i was wondering if it is better to run 2x or 3x 5870 or 3 gtx 285 or 2x 295 and if OCd would i have to have them cooled with the liquid cooling or can i just go with the extra side fans they can put in and the liquid cooling how do you refill the resevoir(however you spell it lol) is it a chemical you can buy anywere and how do you know when its time to refill it .......sorry for all the newb questions like i said this will be my first built PC
thank you again
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 3:51pm
Well firstly, what is the resolution you were planning on operating with? And what's the budget we're looking at? What are you using the comp for? That'll determine what vid cards ya need more than anything else. We'll figure out OC/LC later.
Refilling the reservoir will depend on your case and setup but someone more experience can comment on refill times. Talk to DS about brandname and item code when you get it. They should provide you some information you can work with.
Edited by satsunada - 28 Nov 2009 at 3:52pm
  Quote aries1969 Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 3:57pm
oh sorry about that i would like to run max resoluition on a single 23 or 24" and i also have a 32" hdtv i could use and i would like to run mmropg and games like fear type games and CoD type and my limit is no more than maybe 5 grand and thanks again for the help
  Quote satsunada Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 4:19pm
I'll pitch up a recommended build once i'm able to, apparently they turned save off so it's difficult to transcribe here. It ended up being $4130 before any discounts were applied.
As far as video cards goes, the best out right now is the ATI stuff but you may only need 1 card for those screens. 2 would make sure you have awesome graphics on the TV but you may not need it. You can afford it though so 2 would be a safer bet, and you can LC them easily on that budget if you wanted. Though again, it's all about what you need. I'd wait for someone else like DST4ME (who somehow has the likely ability to get on that page we can't see) to offer up some advice.
Sorry I can't help more atm :(
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 4:54pm
Chassis Model: Cool Master - HAF 932
Hard Drive Set 1: Operating System: 1x (256GB Solid State (By: Corsair) (Model: CMFSSD-256GBG2D)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Seagate/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Optical Drive 2: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs)
Liquid Color:UV Redish Pink: Medium Glowing Non-conductive Fluid (Requires H20: Stage 3 & UV Lighting)
Windows OS: Microsoft Windows 7 Home pro (64-Bit Edition)
LCD Display: Samsung 24 inch (Widescreen) (Black) (High-Performance Gaming Display)
Keyboard: Razer Tarantula Gaming Keyboard
Mouse: Razer Lachesis Gaming Mouse (High-Speed Gaming Grade)
this is gonna be around $4300, few month down the road, if you see you need more gpu power, and I doubt you will, add another 5870.
  Quote aries1969 Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 4:57pm
thanks everyone for your time and help
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 5:04pm
Our pleasure
