Please review my build (+question)
Post Date: 2009-12-17
DonSasquatcho View Drop Down
  Quote DonSasquatcho Quote  Post ReplyReply bullet Topic: Please review my build (+question)
    Posted: 17 Dec 2009 at 12:23pm
So, this is what I just ordered. Please let me know if you have any advice for last minute changes.
The only second thoughts I'm having right now are about:
Would you recommend it? Has anyone done it? What exactly do they do? Can it be reversed?
Thanks!
Motherboard: EVGA X58 Micro Edition SLI (Intel X58 Chipset) (Supports SLI or CrossFire)
System Memory: 6GB DDR3 1600MHz Digital Storm Certified (Highly Recommended) (Hand Tested)
Video Card(s): 1x ATI Radeon HD 5870 1GB
Extreme Cooling: AIR: Stage 1: Cooler Master V8 High Performance Cooler (Compatible With ONLY i7 Processors)
CPU Boost: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Dec 2009 at 1:19pm
change your mobo to LE, micro has only 2 pci slot for gpus.
what is your budget? and what resolution will you be gaming at?
  Quote DonSasquatcho Quote  Post ReplyReply bullet Posted: 17 Dec 2009 at 1:40pm
Thanks for the quick answer DST4ME
Budget is $2200 (which this build is very close to)
Resolution, 1680x1050 But I'm hoping will get to 1900x1200
I considered the micro vs the LE. I've read somewhere that the LE has only one x16 PCI slot and the rest are x8. The Micro has  2 x16 PCI slots and I don't think I'll ever get to the x3 GPUs anyway (before I upgrade the whole computer anyway)
I don't feel strongly about it though. Performance wise they both seemed to go rate very similarly.
Edited by DonSasquatcho - 17 Dec 2009 at 1:48pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Dec 2009 at 2:19pm
when you say hoping to get to 1900 x 1200 you are talking about purchasing a new monitor right? if so when do you plan on doing that?
with micro its not a matter of going tri sli, its a matter of if you do go dual sli/cf, you will not have anymore pci slots open for any other pci card, wireless card, estata card, sound card, tv card, etc.
  Quote DonSasquatcho Quote  Post ReplyReply bullet Posted: 17 Dec 2009 at 2:43pm
I see your point about the mobo. I'm convinced.
1900x1200 is in my wish list for the few (1-3) months if the computer is able to handle it. If it is not as is, then first will come the x2 ATI... then the 1900x1200 (6mo or so then)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Dec 2009 at 2:51pm
this is all you need for 1900 x 1200
Here you go Ticket# 365247 --- Price: $2080 (To see this build click here) Price after current promotion $2080
Trim Accents: - Not Available
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Boost OS: - Not Available
Office: - Not Available
Benchmarking: - Not Available
I would change the case to 932 if I were you.
Edited by DST4ME - 17 Dec 2009 at 2:52pm
  Quote DonSasquatcho Quote  Post ReplyReply bullet Posted: 17 Dec 2009 at 3:34pm
Awesome. Thanks a lot!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Dec 2009 at 10:36pm
My pleasure
