plz help me how to post
Post Date: 2009-10-03
jhondavid View Drop Down
  Quote jhondavid Quote  Post ReplyReply bullet Topic: plz help me how to post
    Posted: 03 Oct 2009 at 3:17am
plz tell me how to post my link that contains some product infomatin with out disturbing others?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Oct 2009 at 4:20am
I'm not understanding what you are saying, what product info?
Chris91 View Drop Down
  Quote Chris91 Quote  Post ReplyReply bullet Posted: 03 Oct 2009 at 1:09pm
You seriously need to clarify your question, if your talking about posting an external link about product info from another site then just copy and paste the URL from the tab used to type in websites into your post that's it. I get what's so confusing about that. If that doesn't answer your question, sorry can't help you, I don't fully understand what your trying to ask.
EdH63 View Drop Down
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 03 Oct 2009 at 5:27pm
If you actually want to post a link, and have it active to click on in your post, you'll need to use the "Full Reply Editor" below in the white Message box.  Copying and pasting a link into your post makes the reader have to then copy and paste it into their browser.  This forum is set-up to allow you to post active links in the body of your post, people just need to utilize the forum the way it's designed to be used.  All the info to do this is at your fingertips, you just need to investigate all the forum options available.  Place your cursor over these options in the box below and they will have a pop-up that explains what that icon is for.  Click on them and see what they do for you.  The best way to find your way in a forum is to investigate all the available options.
Your question mark at the end of your sentence indicates that you found out how to post an active link (it's blue), so clarify what your needs are and we'll see if we can help you.
Edited by EdH63 - 03 Oct 2009 at 5:29pm
