Possible video card issue
Post Date: 2010-03-05
solomon413 View Drop Down
  Quote solomon413 Quote  Post ReplyReply bullet Topic: Possible video card issue
    Posted: 05 Mar 2010 at 11:42pm
So Ive been having some issues with my computer blue screening and im getting ready to send it back to DS. But last night I hooked it back up to try something, I have two GTX 295's in my computer running in sli, and I happend to hook up my moniter to the lower video card. when my computer turned on my screen was black for a minute or two then the only thing that poped up was my cursor. nothing else would pop up and I waited around for a couple minutes. Does this mean there is something wrong with my second video card? or do you always have to have your moniter hooked up to the upper video card? Also it looks like there are two spots that you can hook up the moniter on each video card does it matter which one you use?
Edited by solomon413 - 05 Mar 2010 at 11:43pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Mar 2010 at 12:50am
for nvidia I thought it was the top card.
have you tried just running one at a time to see if that helps, also changing drivers might help, but I assume you did all that.
  Quote solomon413 Quote  Post ReplyReply bullet Posted: 06 Mar 2010 at 12:59am
Yeah it does work in the top video card. Just don't know why it wouldn't work in the lower one
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Mar 2010 at 1:01am
thats how nvidia is setup, I believe with ati it will not matter.
Edited by DST4ME - 06 Mar 2010 at 1:01am
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 07 Mar 2010 at 11:13am
Probably windows recognizes the second card as undominant, and therefore thinks that anything plugged into it is instead a second monitor. Your computer probably works perfectly fine. Windows versions have a tendency to black out secondary screens during login, though you can still move your cursor in there and see it. That's what I think you were seeing.
I think preferably, you should hook up your display to the slot labeled "1" on the top video card.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 07 Mar 2010 at 11:17am
Again, you can use any slot you want, with any card.
  Quote solomon413 Quote  Post ReplyReply bullet Posted: 08 Mar 2010 at 12:45am
ablahblah This is exactly what happend. thxs for the info atleast now i know it isnt something wrong with my computer
Edited by solomon413 - 08 Mar 2010 at 12:45am
