Power connection question for GPU
Post Date: 2018-04-06
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Topic: Power connection question for GPU
    Posted: 06 Apr 2018 at 12:24pm
I currently have 780ti in SLI in my PC. I looked at specs and it says the connector it needs are "additional 8+8 pin PCIe power required"
The prices for 1080 ti GPUs are finally under 1k and I was going to buy one to replace the 2x780ti. It says the connectors it needs are
"Power Connector 2 x 8-Pin"
I know this will sound retarded, but are these equivalent?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 06 Apr 2018 at 12:44pm
Yes, 8+8 pin is the same as 2x8 pin.
Nice upgrading to the 1080 it.
Each of your 780s needed 2x8 pin, total of 4x 8 pin   Your single 1080ti won’t need all four , just 2.
Edited by bprat22 - 06 Apr 2018 at 12:46pm
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Posted: 06 Apr 2018 at 12:52pm
Thank you for the prompt response.
