Power management settings don't work
Post Date: 2015-09-13
curt1 View Drop Down
  Quote curt1 Quote  Post ReplyReply bullet Topic: Power management settings don't work
    Posted: 13 Sep 2015 at 5:00pm
This isn't a huge problem, but my new computer doesn't go into sleep mode based on the time I set in the power settings. The screensaver also doesn't come on at it's setting. Anyone have a clue what is causing this? I'm using a USB mouse and unplugged it, but it did not improve the situation.
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 13 Sep 2015 at 5:44pm
just to get the obvious out of the way, you were logged in as administrator when creating your power plan, correct?  the power plan was created in the "system settings" pane?  this will change all other plans to automatically adhere to these settings.  can you look up any and all plans saved on your computer by looking in pereferred and additional plans and see what's there?  you might have something overriding the one you want.
try this: in search box type troubleshooting
click view all on the left panel
click power and a new window will popup
follow the on screen instructions.  that should restore your screen saver.
a video driver can be the problem.  try a different driver if the current one is causing the problem.
Edited by db188 - 13 Sep 2015 at 5:47pm
  Quote Snaike Quote  Post ReplyReply bullet Posted: 14 Sep 2015 at 12:13am
Off topic, but related.
I don't let my machine 'sleep' or 'hibernate'. It caused more problems than it solved with my wifi capabilities. I would come back to it from a 'sleep' cycles and have to log off / restart it immediately so it just wasn't worth it.
It's now powered down when I'm done for the day.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 14 Sep 2015 at 1:58am
+1, never use "sleep", "hibernate" or screen saver.  Strong
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Sep 2015 at 3:25am
+2. Its not worth the 1 or 2 minutes saving with pladder drives. Seconds with SSD. Sleep might work for a lot of users, but when it messes up I've seen an OS reinstall is needed.   Thats worse case.
  Quote curt1 Quote  Post ReplyReply bullet Posted: 14 Sep 2015 at 6:56am
I thought I posted a reply here, but it didn't show up. Anyway, thank you for the feedback, as I appreciate other users opinions.
  Quote curt1 Quote  Post ReplyReply bullet Posted: 19 Sep 2015 at 2:09pm
The guilty culprit is the Logitech 3D Extreme joystick which interferes with the power options. Once you disconnect it (USB), power options work as they should. Many are reporting this problem in the MS forums, so I hope they release a fix for Win 10 users.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Sep 2015 at 2:29pm
Nice find and congrats.   Thanks for the feedback.
OS updates always cause their share of weird issues.
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 19 Sep 2015 at 8:06pm
First thing I do on any new PC is disable hibernate. Sleep, hibernate... Ew. That's too much space I don't wanna give up... Not to mention I'm a performance whore. Those just slow down your PC over time.
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
