Power Plugs
Post Date: 2012-04-24
De4th_BY_nINj4 View Drop Down
  Quote De4th_BY_nINj4 Quote  Post ReplyReply bullet Topic: Power Plugs
    Posted: 24 Apr 2012 at 1:54am
Hi, im Sam
seeming i live in australia i was wondering before i buy anything, if the computers come with plugs that can be used here is australia.
thanx for any help and if i posted in the wrong spot please tell me as i dont know what really to do.
thanx anyway
  Quote FrankW Quote  Post ReplyReply bullet Posted: 24 Apr 2012 at 8:02am
Hi Sam,
Nice to hear from someone so far away.
DS will have to answer your question. You can always cut off the US plug and add your own Australian plug. More important is your voltage. I think you have 250V 50 cycle and you need to make sure DS has the power supply wired for that voltage. I guess the power supply could be auto detecting but you should be very cautious about the power setup.
Good luck with your system. You have picked a great company to build it.
  Quote De4th_BY_nINj4 Quote  Post ReplyReply bullet Posted: 24 Apr 2012 at 7:36pm
Hi Frank
thanx for the feedback and i guess cutting it off could work as my brother is an electrician and could help me with that. do you have any advice on what power supply i should get.
Sam     Smile
  Quote Alex Quote  Post ReplyReply bullet Posted: 24 Apr 2012 at 9:57pm
The power supplies automatically switch from 110V to 220v-250v. All you need is a standard power connector that plugs into the power supply ATX dongle. This is the type of connector you need for your power cord that would go into the computer:
  Quote FrankW Quote  Post ReplyReply bullet Posted: 25 Apr 2012 at 5:49am
Hi Sam,
I think Alex has answered the question about the power supplies being auto-detecting. So all you have to worry about is getting the correct plug. I guess they don't provide a cable that matches your plugs or he would have mentioned it. I would let your brother sort that out.
As to what power supply to select. That depends on your system configuration. As long as you pick a Corsair AX or HX series you will be OK. I suggest you go to the Configuration forum and let us help you build a great computer.
Edited by FrankW - 25 Apr 2012 at 5:51am
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Apr 2012 at 9:45pm
I agree.
