Power Protection Question
Post Date: 2010-10-13
  Quote Tidgxor Quote  Post ReplyReply bullet Topic: Power Protection Question
    Posted: 13 Oct 2010 at 8:30pm
Hello all,
I'm going to be biting the bullet on my first DSO purchase very soon. As this will be the first "beast" of a computer I have ever owned (I've been on laptops almost exclusively since 05, and average desktops before that), I have a few questions about power.
For a High-End gaming PC, is a UPS recommended? I've never used one before except with work computers, but I didn't know if it would be a good idea to have one for a gaming PC. If so, can you recommend any? Is the one DSO offers a good model?
What about Surge Suppressors? Again, all I've ever used, at least since 95, was just standard surge protectors, some better than others, but none which probably cater to a High-End PC. Is it really worth the extra money for a high-end surge protector and if so can you recommend any?
Finally, someone suggested to me that a high-end gaming PC might give me problems with blowing fuses (Still on fuses in this old apartment), is there any truth to this at all? I'll have at least a 1200W PSU.
Thanks for your time Smile
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 10:48pm
a ups would be very expensive and isn't rated for too much power. plus it wouldn't last long. personally what i am going to use with my build is a really good surge protector. I'm going to use the panamax m8-av-pro. its a little pricey $150 but i got it from a store that was going out of business for $25 by me.
Its definitely worth it though. Surges can enter your computer through every external thing that goes into it. this surge protector protects tv cables, internet cords and 8 power outlets! it is guerenteed that everything plugged into it will be surge protected and you know its really good because if your components properly connected to the surge protector are damaged by any type of surge (even lightning which is impossible to protect from but very rare) they will pay to replace it.
(edit forgot the link ) http://www.panamax.com/Products/Floor-Models/M8-AV-PRO.aspx#tab_benefits
doubt you will have problems with your computer unless you happen to have a microwave or something like that on the same fuse. the only time i have blown a fuse was running the oven and microwave and toaster at once. so as long as you don't have something really power intensive on the same fuse like a space heater might blow it or might not. Its just good to know whats on the same fuse as your computer.
Edited by maxyme - 13 Oct 2010 at 10:50pm
Steam:pcmaster160
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 10:15am
Thanks so much for the info and link! Big%20Smile
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 10:23am
It is my understanding that a large PC  power will absorb power spikes better than 99% of all strips.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 10:45am
Could you elaborate on this a little more? Was there a typo here or am I just that ignorant on technology Big%20Smile.  Sorry for my lack of understanding.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 10:49am
It is my understanding that a large PC  power supply will absorb power spikes better than 99% of all strips.
he just left out a word, i fixed it
to my understanding, the idea here is that a power supply is specifically designed to regulate power, the less direct you make the line between it and your household power, the less consistant your electric flow to your computer will be, and the less consistant your hardware will operate (especially if your power strip or UPS is ineffecient
so not only is it just as safe to plug in to the wall, its better for overclocking and current stability
at least thats what i understand about it.. i dont practice what i preach though.. i use 2 medium-high rated power strips for my rig/desk.. there simply arent enough wall plugs for me
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 11:44am
LOL thanks for the fix.
 hate using the little berry to post, always make a ton of errors.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 3:47pm
Awesome, thanks for the information everyone, I had never cosidered the PSU having its own built in protection, but then again, I never thought much about the PSU beyond its wattage and efficiency. Oops
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 6:17pm
then again, the entire purpose of having that UPS module is insurance for when the power gets cut in your area while you're finishing up that rendering project (that took you 7 hours) due in the next 3 hours....lol.Then again, it's really only a great option if you get frequent power outages/spikes.
The tough part is that standard consumer lines  ($150 max) can only tolerate a max load of 865 watts. Any higher and you go high end to the $500 options.
Edited by ablahblah - 14 Oct 2010 at 6:18pm
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
JJJJ_Shabadoo View Drop Down
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 7:37pm
Actually with a good power strip/UPS that functions as a voltage regulator the exact opposite is true. A lot of homes' power straight out of the wall isn't very clean (especially older homes) and has frequent voltage fluctuations. A good voltage regulator can ensure a steady 120 volts being supplied to whatever is connected to it.
While a good computer PSU can keep a steady level of power going to the components of your computer, it's not going to save your comp from a lightning strike. Also keep in mind that other things plugged into your comp (eg ethernet cables, printers, scanners, speakers) can transmit a power surge to your computer. In my opinion, if it in any way connects to your computer it should, at bare minimum, be connected to a surge suppressor.
Edited by JJJJ_Shabadoo - 14 Oct 2010 at 7:40pm
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 8:36pm
Tidgxor, I made this post (link below) a while ago and took Westom's advice and got a surge protector at the breaker panel (I also use a strip). I thought his advice seemed informed and well thought out. Just another option to think about.
http://digitalstormonline.com/forums/forum_posts.asp?TID=9019&KW=24/7
Edited by AndydViking - 14 Oct 2010 at 8:55pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 9:36pm
Surge protector at the panel is a good idea, the strips, I have had more problems with them not able to supply enough voltage, and causing way more problems than they are worth. Depends a lot, on the amount of draw your PC has.
  Quote maxyme Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 9:39pm
the one i linked shouldn't have problems with any build on the site rated for 1800W
Steam:pcmaster160
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 9:40pm
Again, thanks for the multiple responses and links everyone, as always, you have proved very helpful.
At this point, it is looking like for my uses at home, I won't be needing a UPS. However, it does seem like I will be needing to invest in a good surge protector that protects all my lines of input.
The only issue I have with that, is that in the past, such a surge protector seemed to cause issues with introducing too much noise into my (already not so hot) DSL line. Though that was on an old protector, so I'm going to presume some of the newer ones allow for this?
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 14 Oct 2010 at 9:52pm
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Posted: 15 Oct 2010 at 11:13am
One thing to keep in mind regarding Westorms advice is that most power surges aren't of the magnitude of a direct lightning strike and a good quality surge suppressor can handle them just fine.
Example: Many moons ago lightning struck a telephone pole near my house. Fried out several phones and one of my computers modem but thankfully wasn't powerful enough by the time it entered my house to fry out anything else in the comp. My other computer, which had the phone line routed through a surge suppressor, was untouched.
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 15 Oct 2010 at 2:10pm
That's definitely true.  Most will be just fine with a typical surge protector to absorb the high "spikes" of electricity.  I feel that the protector at the breaker box gives that extra protection from 'line slap' down the road and just a bit of extra confidence in your surge protection.  One can prolly get a unit installed for $175.00 or so ( or around the cost of a 1500va UPS).  It's one of those things you don't need per se but is nice to have.
westom View Drop Down
  Quote westom Quote  Post ReplyReply bullet Posted: 19 Oct 2010 at 12:29pm
   View numbers for a power strip protector.  Protection already inside every appliance makes a 'hundreds of joules' surge irrelevant.  For example, dimmer switches and bathroom GFCI are less robust than electronics.  And routinely survive small spikes.
  Surges that overwhelm appliance protection are typically hundreds of thousands of joules.  Where does any plug-in protector claim to protect from that type of transient?  Show me that manufacturer spec number.  Power strip protects from a surge that typically does no damage.
  Another reason why earthing (a connection often made via a 'whole house' protector) is critical:  hundreds of thousands of joules must dissipate harmlessly outside the building.   To protect that power strip protector rated only for hundreds of joules.
  Once inside a building, that surge hunts for earth via appliances.  It only finds one or some appliance.  In one previous post,  it found earth destructively via one telephone appliance and ignored the other.   That previous post assumed every phone appliance should have been damaged.  But surges do not work that way.  The surge hunts.   Find the better path to earth only via some appliance.  And nothing inside the house averts  that search.  No plug-in protector stops (or in specs claims to stop) that selection.  The other phone appliance would be undamaged with or without a protector.  The protector did what its manufacturer claims in specs – virtually nothing.
  A surge means all appliances are damage?  Of course not.  Once inside, that surge selects which better connection to earth - destructively via one or a few appliances.  And no plug-in protector will even discuss (let alone stop) a destructive search for earth ground.   Plug-in protectors claim to protect from surges that typically do not overwhelm internal appliance protection.  Will not even discuss the destructive surge that must be absorbed before entering the building.
  Quote westom Quote  Post ReplyReply bullet Posted: 19 Oct 2010 at 12:40pm
   Most computers draw about 200 watts.  Your machine would typically draw less then 300 watts average.
  Meanwhile, even 1930 wiring must be sufficient for a 1200 watt appliance.
  If you believe your computer is 1200 watts, then a minimal UPS starts at maybe 1700 watts.  Obviously that 1200 number (provided by others) is bogus.  Now you know something about the credibility of that information source.
  The $100 power strip (high end) protector is the same circuit also selling for $7 in the grocery store.   High-end what?  High-end protector or profit center?
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 19 Oct 2010 at 3:46pm
Panel surge protector, heh, was right about to say. Easiest possible home solution lol, and saves some bucks on buying surge protector after surge protector.
Additionally, most computers should be drawing less than 100 watts. I'm talking office computer. "Multimedia" computers may draw a bit into the 100 watt range, shouldn't really though. A gaming computer will typically draw at least 200 watts, high end drawing 600 watts or more.
Edited by ablahblah - 19 Oct 2010 at 3:47pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote maxyme Quote  Post ReplyReply bullet Posted: 19 Oct 2010 at 5:07pm
with 2 gtx 480s being maxed out you will use around 800w but it may be around 1000w with cpu and other stuff... people say to use a 1200w psu because to increase a psu's lifetime you want to stay using around 70-80% of the psu's rated performance.
You actually are completely wrong with the surge protectors. heres some info about them from http://electronics.howstuffworks.com/surge-protector5.htm
To protect your equipment from surges, you need individual surge protectors for each outlet. These power strips range a great deal in quality and capacity (as we'll see in the next section). There are three basic levels of power strip surge protectors:
Basic power strip - These are basic extension cord units with five or six outlets. Generally, these models provide only basic protection.
Better power strip - For $15 to $25 you can get a power strip surge protector with better ratings and extra features.
Surge station - These large surge protectors fit under your computer or on the floor. They offer superior voltage protection and advanced line conditioning. Most models also have an input for a phone line, to protect your modem from power surges, and may feature built-in circuit breakers. You can get one of these units for as little $30, or you can spend upward of $100 for a more advanced model.
Uninterruptable Power Supply (UPS) - Some units combine surge protection with a continuous UPS. The basic design of a continuous UPS is to convert AC power to DC power and store it on a battery. The UPS then converts the battery's DC power back to AC power and runs it to the AC outlets for your electronics. If the power goes out, your computer will continue to run, feeding off the stored battery power. This will give you a few minutes to save your work and shut down your computer. The conversion process also gets rid of most of the line noise coming from the AC outlet. These units tend to cost $150 or more.
Expensive Surge protectors also vary greatly due to
    the voltage they start protection at
    how much energy they can absorb
    and the response time. with a longer response the longer your computer will be exposed to surges for
    also high end surge protectors protect against surges via eithernet cords
In addition to all of that good high end surge protectors will have a guerentee and if something gets damaged they will pay you to replace it. Thats definately enough of a reason for me not to let my $4,000 computer get destroyed because of not paying a extra $100.
Edited by maxyme - 19 Oct 2010 at 5:13pm
Steam:pcmaster160
  Quote westom Quote  Post ReplyReply bullet Posted: 19 Oct 2010 at 11:51pm
HowStuffWorks is a benchmark for lies and myths.  Simply ask some embarrassing questions.  For example, where are the relevant numbers?  Any facts based in science always include numbers.  No numbers is a first indication of junk science.
 Go to specification numbers for power strip protectors.  How do hundreds of joules in a protector make hundreds of thousands of joules (the typically destructive surge) just magically disappear?  It is not a rhetorical question.  Answer it.
  HowStuffWorks says "a protector with an indicator light that tells you whether or not it's functioning properly".   Oh?  View pictures:
  http://www.zerosurge.com/truth.htm
They removed all MOVs (the protector circuit) and those lights still say that protector is good.  Who is wrong?  Pictures taken by engineers?  Or HowStuffWorks?
  A properly designed protector degrades - does not fail.  Its voltage changes 10% (another number).  Lights can never report degradation.  Lights report a type of failure that every MOV manufacturer datasheet calls unacceptable. Any lie from HowStuffWorks exposed.
  Lights only reports a protector was grossly undersized.  Protector circuit disconnected as fast as possible leaving a surge connected to the appliance.  Undersizing (and that light) gets only naïve consumers to recommend the protector.  An effective protector means nobody even knew a surge existed.
  HowSutffWorks has far too many myths and lies to discuss here.  Another long post on 17 Nov 2003 entitled "Inside a surge protector" discussed only its first pages:
   http://tinyurl.com/2fy7u
  So where is the paragraph in HowStuffWorks that discusses where energy dissipates?  Where are those joules numbers?
  No protector does protection.  Either the protector connects hundreds of thousands of joules short (ie 'less than 10 feet') and effectively to earth.  Or that a protector does not even define protection in numeric specs.  Yes, where are those manufacturer numbers that claim protection from each type of surge?
  No earth ground (a plug-in protector) means no effective protection.  Protection is always about where energy dissipates.  A protector is only as effective as its earth ground.  Effective protectors always have that dedicated and short (ie 'less than 10 foot') wire to single point earth ground.  Always.
  Now, view the box.  What is the let-through voltage number?  330volts.   That means a 120 volt protector does nothing until voltage exceed 330 volts.  You said:
> Expensive Surge protectors also vary greatly due the voltage they start
> protection at how much energy they can absorb  and the response time.
Good.  I am an engineer.  You tell me something useful when you provide those numbers.  You said the numbers exist.  Good.  That means you post them.  And explain the significance of each number.  Honesty means claims WITH numbers.
  Meanwhile, OP's computer is not drawing 1200 watts or even 800 watts.  ablahblah  provided reasonable numbers.  But I have yet to find any PC draw 600 watts.
  Quote westom Quote  Post ReplyReply bullet Posted: 19 Oct 2010 at 11:53pm
  Now, view the protector’s box.  What is its let-through voltage?  330 volts. That means a 120 volt protector does nothing until voltage exceeds 330 volts.  But you said:
Edited by westom - 19 Oct 2010 at 11:54pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 9:14am
LOL   have yet to find a PC drawing over 600 wattsLOL
LOLLOLLOLLOLLOLLOLLOLLOLLOLLOLIm%20with%20StupidIm%20with%20StupidIm%20with%20StupidIm%20with%20StupidIm%20with%20StupidIm%20with%20StupidIm%20with%20StupidIm%20with%20StupidLOL
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 10:01am
knew this post was coming soon, lol
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 10:31am
what about the 3000+ watt PCs?  I have my 30 amp 240 Volt outlet in my test room for a reason.
  Quote westom Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 11:17am
  Absolute nonsense.  If your computer was drawing that much power, then you could cook pancakes on it.
  Back when a minicomputer was 400 pounds and took two people to move, even that monster never drew 1500 watts. We used them to also heat an entire room during the winter.  Never saw a PC that draws 600 watts.  But I do see many computer assemblers so untrained as to *know* their computer needs 800 watt power supplies.
  Amazing that one actually thinks his PC consumed 3000 watts.  One need only put a hand on it to know that is impossible.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 11:38am
come by anytime, bring a kilowatt meter, and a case of beer for being wrong. Hahaha
4 GTX 480's OC'd pull 400 watts each,  2 980x's OC'd draw 250 watts each, then 250 watts for 35 fans, lights and 4 water pumps.. yep = less than 600 watts. Big%20Smile then add the 5 horse power dual stage cascade.. hmm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 11:57am
  Absolute nonsense.
Justin's speciality
Yea, if you didnt cool it with anything, lol?
this seems pretty babelfished, maybe something is getting lost in translation?
even i know justin is right on this one, and im no electrician, i know that pcs can draw more than 600, thats old news
Edited by !ender_ - 20 Oct 2010 at 11:58am
  Quote westom Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 12:40pm
  Even i know justin is right on this one, and im no electrician, i know that pcs can draw more than 600, thats old news
  Good.  You can list wattage for each component.  If you cannot, the you only know from hearsay.
  A 3000 watt computer means hands are pained from heat removed  by a few computers fans.  Or we do simple thermal caculations for airflow.  About 1000 CFM to remove 3000 watts.  How many 35 CFM (80mm) fans are in your 3000 watt computer? 28 muffin fans?   Please learn how electricity works.
 In a nation where most computer assemblers have no electrical knowledge, then  energy consumption myths are routinely propagated. Most PCs consume about 200 watts or less.  lender - if you know, then you also post numbers that say why you know.  Otherwise the post promotes junk science.
  How much wattage does each component consume to total 600 watts?
Edited by westom - 20 Oct 2010 at 12:53pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 1:15pm
I did not say that I had a 3000+ watt PC, just said that they exist.
120MM fans are the smallest on my main PC. appx 70CFM each,  with 4 triple radiators and one quad, they can dissipate appx 3000 watts at a 10C air to water Delta.
  Quote westom Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 1:26pm
You are confusing PCs with blade servers.  They both use a microprocessor.  But blade servers use tens or 100 times more.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 1:32pm
No I am not. I am talking about gaming PC's
here is one that used two 1200 watt per supplies, using close to 2300 watts, @ 82% efficiency = appx 2800 watts at the outlets
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 1:46pm
/thread
get out of my house troll
Edited by !ender_ - 20 Oct 2010 at 1:47pm
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 20 Oct 2010 at 1:47pm
Well guys, thanks for all the input Smile
Things have progressed far beyond my limited knowledge at this point, so I'll just set back and try to learn a few things Ninja
This page was generated in 0.1328125 seconds.
