power save mode
Post Date: 2012-03-12
d2l41 View Drop Down
  Quote d2l41 Quote  Post ReplyReply bullet Topic: power save mode
    Posted: 12 Mar 2012 at 9:44am
Ok just bought a computer from you guys and it runs great.except one issue. While gaming the computer or monitor goes into power save mode randomly.   I have all the power save mode options on never too.
I have a dell u3011 playing at 2560x1600.   3 gtx 570 's,   16 gigs of ram a 3930 k processor 1200 watt power core
  Quote d2l41 Quote  Post ReplyReply bullet Posted: 12 Mar 2012 at 10:51am
Anyone know what the problem could be?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Mar 2012 at 11:06am
I don't have any easy answer.  Try unplugging and reseating monitor cable both ends.   Is monitor plugged into top left DVI port, closest to mobo?
Try plugging mouse and keboard into different USB ports.
Did you put HDD into 'never' in advanced power saver options?
  Quote d2l41 Quote  Post ReplyReply bullet Posted: 12 Mar 2012 at 11:23am
Yea its plugged into the top left graphics card, another thing to is it will go into power save mode but I can still hear the music in the background from whatever game I was playing. But I guess ill have to try putting the hdd into never.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Mar 2012 at 12:12pm
Is it possible the monitor is and  pc not going into power saver??  You hear music.
Monitors go into power saver when they don't detect a video signal.  I would try the other dvi port on your u3011 and if that doesn't help try different dvi ports on your gpu's.  Maybe intermittant bad cable.
Edited by bprat22 - 12 Mar 2012 at 12:13pm
Brewtus View Drop Down
  Quote Brewtus Quote  Post ReplyReply bullet Posted: 13 Mar 2012 at 4:10am
Also check the menu settings within the monitor itself. See if there is a power save mode or setting you can adjust.
