Power supplies
Post Date: 2009-08-23
Phoolish View Drop Down
  Quote Phoolish Quote  Post ReplyReply bullet Topic: Power supplies
    Posted: 23 Aug 2009 at 11:32pm
I put together a build:
325069
Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset) (Supports SLI or
CrossFire)
System Memory: 6GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced
(Highly Recommended) (Hand Tested)
Power Supply: 1000W Corsair HX (Dual/Triple/Quad SLI Compatible) (Silent
Edition)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 1x (1TB Western Digital (7200 RPM) (32MB
Cache) (SATA) (Extreme Speed)
Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL /
Network Connections)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 275 896MB (Includes PhysX
Technology)
Extreme Cooling: AIR: Stage 2: Noctua NH-U12P High Performance Cooler
(Compatible With ONLY i7 Processors)
Liquid Color:- Not Applicable, I do not have a H20: Stage 3 Cooling System
Selected
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
Enhancements: LCD NZXT Sentry LX Temperature Display & Fan Controller (Requires
Chassis Airflow Upgrade)
Boost Processor: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz
(Requires Air Cooling Upgrade)
Tweak Windows: - No Thanks, Please do not tweak the services on the operating
system
Windows OS: Microsoft Windows Vista Home Premium (64-Bit Edition) With Windows 7
Upgrade Coupon
LCD Display: - No Thanks
Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is
Successfully Processed
My question is about power supplies. As you can see in the build I have the
corsair 1000w selected. Is the PC power and cooling 910w enough for my system
or should I keep the corsair? I have heard very good things about PC
Power and Cooling as a brand and I do not know much about corsair's units.
Dropping to the 910 watt would enable me to add a 500GB hd. My budget is roughly
$2750 so I am trying to stay right around $3000 so I get the $250 off with the
promotion.
Also I guess while I am posting, as you can see I went with green case lighting
and blue performance fans. I thought it would make a neat color combo. Does anyone
have experience with mixing the system lighting and case fans or pics of examples
so I can see how it looks?
Thanks!
Caleb View Drop Down
  Quote Caleb Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 11:44pm
Give me a few minutes please and I will help you.
  Quote Caleb Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 11:53pm
Chassis Model: Cooler Master HAF 922
System Memory: 6GB DDR3 1333MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Hard Drive Set 1: Operating System: 1x (128GB Solid State (By: Corsair) (Model: CMFSSD-128GBG2D)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Liquid Color:Red: Non-conductive High-Performance Fluid (Requires H20: Stage 3 Cooling Package)
Review:
1. I gave you the i7 920 OC'd to 3.3-3.9.
2. I gave you 6GB's of ram 1333 :D.
3. I gave you a 1000w PSU if you upgade in the future.
4. I gave you liquid cooling to reduce noise.
5. If you want to change the colors please do so.
6. Here is your build: 3218$-Discount=2968$.
If you have any questions or comments PLEASE ask.
I'd also like a more experienced member to comment on my build. I'm not to good @ mobo pickin so tell me if that's a good one. And if your not going to be gaming @ 1900x1200 res. tell me so I can tell you how to reconfigure your build.
Edited by Caleb - 23 Aug 2009 at 11:56pm
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 12:04am
Keep the Corsair 1000W, PC P&C hasn't been as great lately as they used to be.
  Quote Phoolish Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 12:12am
Thanks Venom!
Will do.
  Quote venom Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 12:19am
Configuration looks good, though if you wanted to save a bit a 750w Corsair will handle those 275s, but you most likely will have to upgrade it in the future, so keep that in mind.  You could also save a bit going with 1333MHz Mushkin, 1600MHz will not improve the performance of games.
I think the Blue/Green looks good, though you may think differently.  I don't have any pics off hand to show, but maybe look in the Reviews section to see if there is any.
  Quote Phoolish Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 12:25am
Originally posted by Caleb
Review:
Thanks for the effort Caleb.
1. I already had that processor OCed to that amount.
2. 1600 ram is $9 more. Silly not to take the 1600.
3. I already had the 1000w psu, the question was whether to back off to the 910 to get other things.
4. I would love to get the frostbite, but it takes too much other stuff away that I want in the build.
5. I already had colors picked, which was the second question :P
6. Like I mentioned... my budget is $2750, not $3000.
I do like the attempt to get the SSD in which I would love to do, but I just could not come up with something I was happy with within my budget including it.
  Quote Caleb Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 1:02am
I'm sorry, I missunderstood when you said around 3000$. My bad.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 1:09am
what resolution will you be gaming at? do you really need a bluray drive in there?
Edited by DST4ME - 24 Aug 2009 at 1:10am
  Quote Phoolish Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 5:00am
1900 x 1200
I would like the blu ray, but it is not a necessity. My main home entertainment system has a 5 disc dvd changer that is getting a little long in the tooth and when I replace that it will be with a blu ray player. I thought it would be nice to have one in the computer as well.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 7:55am
Here you go Ticket# 325133 --- Price: $2823 (To see this build click here) Price after current promotion $2623
Enhancements: LCD NZXT Sentry LX Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 8:00am
i bet you could run that on a 700w with no overclocking
anyway keep the 1kwatt, it makes your epeen bigger
personally id step up to a 5year warranty
Edited by <8) slunK parade - 24 Aug 2009 at 8:00am
  Quote Phoolish Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 2:11pm
Well I finally pulled the trigger!
I went with the configuration listed above:
325069
Hard Drive Set 1: Operating System: 1x (1TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Total cost after discount was $2753.
Thank you so much for all the advice, suggestions, and information I have received over the last couple weeks as I researched my configuration options(especially DST4ME). Left to my own devices I would have spent money on components that would not have increased performance. Learning about the negligible difference between the 275s and more expensive cards was the big key as it saved me money that I was able to spend on a blu ray drive, fan controller, and upgraded led fans (gotta have the glow!).
Anyway, I have been very impressed by the knowledge and helpfulness of this community and everything I have seen leads me to believe I will be happy with this system and the company that built it.
Hopefully I will be posting a review article soon!
