Power supply for 4x Geforce RTX 2080 TI
Post Date: 2019-10-10
Dragro2k View Drop Down
  Quote Dragro2k Quote  Post ReplyReply bullet Topic: Power supply for 4x Geforce RTX 2080 TI
    Posted: 10 Oct 2019 at 12:19pm
How much power supply would this require if I wanted to use four RTX 2080 TI's. I'm not only a gamer but also a streamer and youtuber.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 10 Oct 2019 at 4:41pm
Welcome to the forum Drago2k!
Beast mode plans!
I would think you would need to use the DS Aventum X case which I believe has room for 2X big power supplies.   I would think 2 x 1200W PSU might be required, but you should really talk to DS about what all you want to do with 4x RTX 2080 Ti...Could be that
2 x SLI/NSync RTX 2080 Ti might be plenty of performance these days for what you hope to do with them.    Email Alex our friendly local DS Manager and I'm sure he can get you with the right salesperson for the larger higher end build answers.
Try email to [email protected]
  Quote hoserator Quote  Post ReplyReply bullet Posted: 11 Oct 2019 at 12:29am
There are a few online tools to determine power requirements. Below is one.
https://outervision.com/power-supply-calculator
Good luck. If you have the budget for those cards also check out the Titan RTX. It is the most powerful card out there right now and might be better for what you want to do.
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 11 Oct 2019 at 12:46am
Yep that's exactly why I suggested he allow Alex to direct him to their DS high end system design guy to match him up better to what he wants to do with multi GPU cards.   Needs to be designed right...that's a lot of GPU to support.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 12 Oct 2019 at 1:24am
And we are only touching on the consumer/prosumer cards.There are the Volta and Turing architecture cards for real crunching work.$$$$$ Smile
Edited by hoserator - 12 Oct 2019 at 5:52am
This page was generated in 2.441406E-02 seconds.
