Power Supply HELP!
Post Date: 2008-11-21
USMC1419 View Drop Down
  Quote USMC1419 Quote  Post ReplyReply bullet Topic: Power Supply HELP!
    Posted: 21 Nov 2008 at 1:56pm
I just bought a 9800 GX2 1GB card that requires 620W. I have a silverstone ST56F 560 W power supply.
I want to buy this power supply (750W corsair 750tx) http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=750tx
The only problem is, my NEW card needs a 6 pin and 8 pin power (both at same time).
Does this power supply support the 9800 GX2? Or do the adapters come in the PNY 9800 GX2 box?
Am i getting the right power supply? Will this setup work?
Thanks a million in advance,
Joe
Axel Daemon View Drop Down
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 1:58pm
http://corsair.com/products/tx/default.aspx
Yeeeeeeeeeep
XpubuX View Drop Down
  Quote XpubuX Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 1:59pm
Yeah its got four 6+2 pin connectors so it will work
  Quote USMC1419 Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 2:00pm
Oh my LORD. You guys ROCK. I cannot believe how fast that was. Thank you so much! I love this community!!
DS rocks btw!!!! Will never by any other brand of PC every again.
Thanks always,
Joe Mercurio
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 5:02pm
harleyman is incorrect.
20+4 works because it is 24 pin -_- it means you can use it as a 24 pin connector or disconnect the 4 extra pins to connect to a 20 pin mobo
whereas ones that list it as 24 pin means its a 24 pin where you can't disconnect pins to make it connect to mobos with a 20 pin connector.
Edited by skyR - 21 Nov 2008 at 5:05pm
  Quote USMC1419 Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 5:13pm
Are you sure.. This will work right? I ordered it already.
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 5:17pm
yes it works as stated by my previous post alrdy.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 5:29pm
skyR is correct, in a 20 + 4 setup, the 4 pin is optional thus you can do 20 or 24
  Quote USMC1419 Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 8:12pm
phew. I'll be installing all of this on monday when it arrives. Any tips on installing the PSU or how i ground my system?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Nov 2008 at 8:29pm
Make sure you system was unpluged for more then a few minutes, make sure you ground yourself before you touch the pc parts.
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 22 Nov 2008 at 3:04am
Actually by any chance there's a quicker method to that?  Turn off the PSU unplug etc etc.  Then try turning it on.  It'll absorb the rest of what's leftover and nothing will be left right?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Nov 2008 at 3:36am
you can do that to but after a couple of minutes, nothing should be left
  Quote XpubuX Quote  Post ReplyReply bullet Posted: 22 Nov 2008 at 4:08am
wear plastic sole shoes ecspecially if working were there is carpeted floor hit power button after unplugged. Ground yourself by touching metal case.
  Quote USMC1419 Quote  Post ReplyReply bullet Posted: 22 Nov 2008 at 8:51am
Thanks guys. The PSU will be here on monday (just checked) and my graphics card on tuesday.
Looks like i'll just use monday to get the PSU in and re wire everything. Installing the 9800gx2 is the easy part.
Thanks again
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Nov 2008 at 12:59pm
Good luck, let us know how it all went
  Quote Axel Daemon Quote  Post ReplyReply bullet Posted: 22 Nov 2008 at 6:36pm
Thanks for the instructions Harley.
  Quote USMC1419 Quote  Post ReplyReply bullet Posted: 24 Nov 2008 at 4:57pm
I installed the power supply neatly and everything works 100%!!! I made sure to leave 2 PCI-E 6+2 wires available for the 9800 GX2 mammoth that comes tomorrow. So far so good, thanks for the help to this point. Tomorrow is the easy part.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Nov 2008 at 7:17pm
Thats great news
stalker00 View Drop Down
  Quote stalker00 Quote  Post ReplyReply bullet Posted: 26 Nov 2008 at 11:39pm
does that work?
  Quote USMC1419 Quote  Post ReplyReply bullet Posted: 01 Dec 2008 at 11:24am
Power supply and 9800 GX2 installed. All working 100%!!! This PSU is rock solid. Buy it, its dirt cheap and its stable, quiet, and very adaptable to anything you throw at it!!
