Power Supply question
Post Date: 2010-10-23
JStones View Drop Down
  Quote JStones Quote  Post ReplyReply bullet Topic: Power Supply question
    Posted: 23 Oct 2010 at 3:00am
Hello all,
I have a question concerning what power supply I would need for the build below. This is the one area I am ignorant on.
This is not a gaming machine it is for professional 3d modeling, rendering, and photoshop work (hence the 12 gig ram).
Basically I want to know if a 750 will be enough to handle the build without putting stress on it or if a 1k is needed. My concern is how much the ram and hard drives will add to the power consumption as per Ender's guide it recommends staying under 3/4 of the max output.
Thanks
Processor: Intel Core i7 950 3.06GHz (Quad Core)
Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset) (Model: 141-BL-E757-TR)
System Memory: 12GB DDR3 1600MHz Digital Storm Certified (Highly Recommended) (Hand Tested)
Hard Drive Set 2: Multimedia\Data: -1x (1TB Hitachi/Seagate (7200 RPM) (32MB Cache)
Video Card: 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology) (EVGA Brand)
Extreme Cooling: AIR: Stage 1: Corsair A70 Dual 120mm Fans High Performance Cooler
  Quote JStones Quote  Post ReplyReply bullet Posted: 23 Oct 2010 at 4:04am
I found this: http://extreme.outervision.com/PSUEngine , If its accurate I should be fine with a 750.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 23 Oct 2010 at 9:51am
750 is enough, next to the video card, the power draw of most other things is pretty low
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 23 Oct 2010 at 9:29pm
I'd recommend the Corsair 750w.
  Quote JStones Quote  Post ReplyReply bullet Posted: 24 Oct 2010 at 2:49am
Thanks its been ordered
