POWER SUPPLY QUESTION
Post Date: 2012-05-24
dms13 View Drop Down
  Quote dms13 Quote  Post ReplyReply bullet Topic: POWER SUPPLY QUESTION
    Posted: 24 May 2012 at 6:33pm
in this build , is 850psu fine, or so i dont burn out my hardware is the 1050 psu needed?????? this is my last question for this computer..... promise lmao
Power Supply: 850W Corsair TX850 V2 (Dual SLI Compatible)
Hard Drive Set 1: Operating System: 1x (240GB Solid State (By: Intel) (Model: 520 Series)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (Includes PhysX)
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black
  Quote dms13 Quote  Post ReplyReply bullet Posted: 24 May 2012 at 6:56pm
forgot to mention i will not be adding anything to this rig, so im looking for a def answer on power supply,
850 enough where everything runs smooth and not stressed, or to make things run without trouble or stress the 1050, i see on many websites people are saying 850 is enough but i am getting mixed signals....
Cypher 6 View Drop Down
  Quote Cypher 6 Quote  Post ReplyReply bullet Posted: 25 May 2012 at 1:06am
Hello dms13,
850w should be enough for sli 670 and a mild overclock:
http://www.guru3d.com/article/geforce-gtx-670-2-and-3way-sli-review/4
Depending on budget, you could move up to the 1050 as it carries a better efficiency rating and is modular which is very, very nice.
Either way you should be fine, the new generation of GPUs are very efficient. Good luck
Edited by Cypher 6 - 25 May 2012 at 1:11am
This page was generated in 6.396484E-02 seconds.
