Power supply stays on?
Post Date: 2010-09-03
Warpig View Drop Down
  Quote Warpig Quote  Post ReplyReply bullet Topic: Power supply stays on?
    Posted: 03 Sep 2010 at 5:24pm
My PSU appears to stay on after I shutdown the PC, I can just hear it, several small lights are lit up on the MOBO and my keyboard has a light on it which also stays on.
Is this a power setting or something I can adjust ?
  Quote Alex Quote  Post ReplyReply bullet Posted: 03 Sep 2010 at 6:24pm
It may stay on to cool down, but, after about 5 minutes, the fan inside the PSU should stop.
You will still see lights on the motherboard, etc... that is normal.
  Quote Warpig Quote  Post ReplyReply bullet Posted: 03 Sep 2010 at 6:39pm
Will power still be fed to external devices after the 5 minute cooldown?
Edited by Warpig - 03 Sep 2010 at 7:36pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 03 Sep 2010 at 7:09pm
You mean external? If so, no, unless the motherboard has that feature.
  Quote Warpig Quote  Post ReplyReply bullet Posted: 03 Sep 2010 at 7:36pm
Heh yes external, yes it is keeping the docked light on my USB keyboard up.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 03 Sep 2010 at 10:18pm
its a setting in the bios that allows you to feed power through usb ports even when the computer is turned off, refer to your motherboards manual if you want to turn this off
