Power supply swap
Post Date: 2020-01-22
Ragman View Drop Down
  Quote Ragman Quote  Post ReplyReply bullet Topic: Power supply swap
    Posted: 22 Jan 2020 at 11:26am
I have a three year old Vanquish 5, i7-7700, z270 chipset, and gtx 1060 6gb GPU. The psu evga 600w, died yesterday, a new psu has been ordered and will take awhile to arrive. I use this pc for work at my home. Can I use an older psu from an old Dell Xps 8300? It is rated 460w max, but wasn't sure about the pic-e compatibility as the older psu is using 2.0 and my rig is 3.0. Is this or any other connectors a deal breaker using the old psu until my new one arrives?
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 22 Jan 2020 at 2:11pm
We can’t be certain what your actual power draw might be, so if it was equipped by DS with a 600 watt PSU, I would not replace it with a lower wattage PSU even temporarily.    I hope the new PSU you ordered will be 600 wat or higher, and hopefully all modular cables to make for less cable clutter...
Reg1 View Drop Down
  Quote Reg1 Quote  Post ReplyReply bullet Posted: 08 Jun 2020 at 12:48am
I’m wanting to upgrade my PSU from a Corsair rm850x to a Corsair HX 1200i
In my Aventum 3 Pro
Are the cables all custom?
If so can I just swap out the power supply’s and plug in the existing cables?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 08 Jun 2020 at 6:41am
I can't think of a reason why Corsair cables would not be the same. I'd be surprised if they weren't standard for all brands. The factories would go nuts.
This page was generated in 7.373047E-02 seconds.
