Power Supply
Post Date: 2014-06-09
Seafoam View Drop Down
  Quote Seafoam Quote  Post ReplyReply bullet Topic: Power Supply
    Posted: 09 Jun 2014 at 12:35pm
Does a power supply effect performance? I was thinking about getting a 800W one, instead of a 750W. Any recommendations are appreciated. Specs are in the sig of what I got so far, you can use that to evaluate the right power wattage.
EDIT: Also in general, is the config below good enough for moderate gaming? I use a lot of the adobe suite too, video editing, rendering, all that good stuff. Mostly gaming though, I just want a solid PC to be able to handle anything I throw at it.
Edited by Seafoam - 09 Jun 2014 at 12:39pm
PC SPECS:
- Intel Core i7 4930k 3.4Ghz
- ASUS Rampage IV Black Edition
- 16 GB DDR3 1866MHz Corsair Vengeance Pro
- 750W Corsair
- Samsung 250 GB SSD
- 1TB Storage
- NVIDIA GeForce GTX 780 Ti 3 GB
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Jun 2014 at 12:44pm
A power supply doesn't effect performance, unless it's not enough and the you'd know it with crashes, BSOD, etc.   Upping the wattage won't give you any better gaming.   It only feeds what's asked of it for the most part.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Jun 2014 at 12:46pm
Just saw the edit... that is a strong gaming rig.   If you game on a single 1920x1080 then it'll give you top performance with most games.
  Quote Seafoam Quote  Post ReplyReply bullet Posted: 09 Jun 2014 at 12:49pm
Jeez, you guys like staring at the forums everyday? Haha, I like it. Thanks for the quick response.
Anyway, I hear ya. Since i'm OCing my processor, would it be necessary to upgrade it by 50W?
EDIT: Just saw your edit, I emailed DS and they recommended an ASUS monitor, 24 inches, and 2ms response time with an led backlight I believe. It'll be better than heaven when I get it.
Edited by Seafoam - 09 Jun 2014 at 12:52pm
PC SPECS:
- 750W Corsair
- 1TB Storage
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Jun 2014 at 12:51pm
You should be fine.
Theokritos View Drop Down
  Quote Theokritos Quote  Post ReplyReply bullet Posted: 09 Jun 2014 at 2:53pm
One thing that you may wish to add to your shopping list is a Uniterruptable Power Supply (UPS). Look for one with a battery backup and able to handle the wattage of whichever PSU you decide upon. The idea is to have something sitting between your power plug and your PC that smooths out line noise, power surges, and power sags. (Think of a water filter on your tap water faucet.) The battery should provide enough power for a smooth, and orderly shutdown of the PC should power drop altogether. The battery should also allow your PC to operate through a brief power outage, such as when a transformer is zapped by lightning and the power company switches around the now smoldering piece of equipment.
Velox
Cool and Quiet
AMD Ryzen 9 7900X
32GB DDR5 5200MHz
Radeon RX 7900 XTX
