Power Supply
Post Date: 2018-11-19
Sgt.Moore View Drop Down
  Quote Sgt.Moore Quote  Post ReplyReply bullet Topic: Power Supply
    Posted: 19 Nov 2018 at 3:34pm
So the Power Supply on my Wife's bolt just bit the dust and New Egg is out of stock so I was wondering if any of you Hardware guru's knew of a replacement because it is much different than most power supplies I have replaced in the past.
https://www.newegg.com/Product/Product.aspx?Item=N82E16817273013&Tpk=N82E16817273013
"RLTW"
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Nov 2018 at 9:18am
Okay, I'm not a power supply guru, but I don't think it's critical you get an exact match. I found this on Newegg, and it's also platinum rated. That's what I think you want, and it seems to be the same form factor:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817438135&Description=750%20watt%20power%20supply&cm_re=750_watt_power_supply-_-17-438-135-_-Product
Hope it helps.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 20 Nov 2018 at 9:41am
He;s looking for a SFX,  small form factor, psu to fit in the Bolt.
I haven't followed whats available, but Silverstone used to be a good bet.
I did do a little searching but didn't find much.  They must be out there, though.  Big%20Smile
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Nov 2018 at 8:51pm
Thanx.
  Quote Sgt.Moore Quote  Post ReplyReply bullet Posted: 24 Nov 2018 at 9:00am
bprat22 to the rescue again ! Thank you so much I was at wits end trying to find a match and sure enough Silverstone has one.
https://www.amazon.com/SilverStone-Technology-SX800-LTI-Titanium-Capacitors/dp/B01NALZ89C/ref=sr_1_1?ie=UTF8&qid=1543078762&sr=8-1&keywords=SX800-LTI&th=1
"RLTW"
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Nov 2018 at 9:27am
Awesome.Awesome
Glad you got pointed in the right direction.  That is a nice psu.
How's Uncle Sam treating you ?  Hahaha       Good seeing you again.  Big%20Smile
  Quote Cretae Quote  Post ReplyReply bullet Posted: 24 Nov 2018 at 8:42pm
  Quote hoserator Quote  Post ReplyReply bullet Posted: 25 Nov 2018 at 12:35am
  Awesomebprat22 Big%20Smile
Hope you get that Bolt running again. Happy wife makes a home happy. Hahaha
Edited by hoserator - 25 Nov 2018 at 12:36am
This page was generated in 7.104492E-02 seconds.
