Power supply/ Voltage difference between US and AU
Post Date: 2009-03-28
SammA View Drop Down
  Quote SammA Quote  Post ReplyReply bullet Topic: Power supply/ Voltage difference between US and AU
    Posted: 28 Mar 2009 at 6:14am
Hi Folks,
My wife caught me before I jumped the gun and took the next step to buying a new PC from DS :#)
I hope I don't confuse anyone with this question... but we realised that the US and Australia have different voltages for mains plugs.
I'm actually from the UK. So I'm used to having adapters that change the plug pins - but otherwise UK and AU share the same voltage.
Which is what has lead us to wonder, do I need some kind of convertor when plugging a DS ordered PC into an AU wall socket?
Kind Regard and thanks in advance for your helpful replies!
Sam
  Quote Alex Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 12:20pm
I believe a majority of power supplies now have auto switches to convert voltages.
However, I would highly recommend doing research on the power supply you will be selecting to ensure it will work in your environment.
