Power to GTX 480
Post Date: 2010-10-12
MICHAEL2A View Drop Down
  Quote MICHAEL2A Quote  Post ReplyReply bullet Topic: Power to GTX 480
    Posted: 12 Oct 2010 at 8:28pm
The 480 uses a 6 pin and 8 pin connector from the PSU. Since I'm not an electrician, would it be okay to use a 6 pin to 8 pin molex adapter (extension) for connection to the GPU? Would there be any load issues?
Look good?
NZXT Switch 810
Asus Rampage V ED10
16GB Corsair Platinum 3000mhz
i-7 X5960, 3.0Ghz-3.5Ghz
Intel 750 800GB NVME-SSD
Corsair H115i CPU Cooler
2 Asus Strix 1080 8GB SLI
Corsair AXi 1200 PSU
AmbientChong11 View Drop Down
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 12 Oct 2010 at 10:41pm
I used molex to power my GTX 295, so it's fine.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 10:00am
six pin PCIe has 3 12V + 3 12V- wires, most companies power supplies on 8 pin Pcie have the same 3 + 3, but add "sensing" wires. so really an 8 pin PCIE will not supply any more power than a 6 pin, but some power supplies do it different. The 8 pin that powers the CPU, is 4 12V+ and 4 12V - so different animal there.
so your adapter for 6 pin Pcie to 8 pin Pcie will work fine, there is also adapter for two Molex's into an Pcie. Usually a molex is reffer to a flat conector with 4 wires, a 12V + a 5V+ and two grounds.
This page was generated in 6.738281E-02 seconds.
