Preferred Battery Backup and Surge Protection?
Post Date: 2010-03-12
rholyrag View Drop Down
  Quote rholyrag Quote  Post ReplyReply bullet Topic: Preferred Battery Backup and Surge Protection?
    Posted: 12 Mar 2010 at 7:29pm
What do the members here use for battery backup and surge protection, and why?  If you don't use any, put none and why.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 12 Mar 2010 at 8:13pm
battery backups are nice. I have a couple APC 1500's for my little PC's but they fail to run the bigger ones. lol I have tried some bigger backups, but did not find one I was happy with.
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 12 Mar 2010 at 8:23pm
I use an APC surge protector that has both cable and rj-45 protection and have installed a cutler hammer surge protector that goes right at the breaker box (closer to earth ground) because of a members advice here: http://www.digitalstormonline.com/forums/forum_posts.asp?TID=9019&KW=cutler+hammer.
Edited by AndydViking - 12 Mar 2010 at 8:26pm
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 12 Mar 2010 at 9:06pm
Thank you justin and Andy for your thoughts.  I also thank you Andy for the link to the other thread.  I missed it when I was searching for this topic.
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 12 Mar 2010 at 9:39pm
I use an APC 1500VA with an LCD that can support a wattage load of 865 Watts.I also have a small surge protector strip for anything that isn't completely vital if the power should ever black out, like my second monitor and printer, and I have ethernet/RJ45 hooked up to the APC 1500VA LCD. In addition, I always have an extra plug available and hanging out by an extension on the APC 1500VA LCD.
The reason I use it is that if something bad ever happens like a brownout or blackout, my rig won't instantly shut off and possibly cause really bad corruption to the files. I have backups, sure, but those are USB powered and would thus go out with my computer too.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
