pro case have usb on front?
Post Date: 2007-10-21
Sikboy1029 View Drop Down
  Quote Sikboy1029 Quote  Post ReplyReply bullet Topic: pro case have usb on front?
    Posted: 21 Oct 2007 at 1:54pm
I'm assuming it does under a flap on the bottom, let me know for sure
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 21 Oct 2007 at 2:04pm
It has two top usb ports.
gdhart View Drop Down
  Quote gdhart Quote  Post ReplyReply bullet Posted: 21 Oct 2007 at 9:23pm
The Pro case has 4 USB + 1 FireWire port + 2 Audio jacks in a small closable 1" by 3 " panel on the bottom front of the case.
850W PSU/Pro Case
Q6600-G0 2.7GHz
nVidia 680i A1 Revision
4GB 800MHz XMS2
1x500 GB WD, 2x500GB WD RAID-1
2x500GB Ext
nVidia GeForce 8800GTX 768MB
ATI TV Wonder 650
Air Cooled Stage 3
67alecto View Drop Down
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 21 Oct 2007 at 11:47pm
They're not supposed to be functioning, though, right?  Mine aren't.
The LT motherboard has 4 USB - and all 4 of mine on the back work.  None of my front ones work, though.
Twister Pro
750W PS/Q6600 2.4GHz/680i LT/2GB Corsair 800/9800GTX/X-Fi XtremeGamer/Stage 2 Cooling
Vanquish II
430W Corsair/i3 3.3 GHz/Asus H61M/8Gb DDR3 Corsair Vengeance/650Ti Boost 2Gb
  Quote gdhart Quote  Post ReplyReply bullet Posted: 21 Oct 2007 at 11:56pm
I have the A1 Revision MoBo and it has 6 in the back and uses the two USB Connectors on the MoBo for the 4 USB  and 1 Firewire ports  on the front.
Do you have a Media Card reader?  If so they would have to use at least one of the connectors for it.
850W PSU/Pro Case
Q6600-G0 2.7GHz
4GB 800MHz XMS2
2x500GB Ext
ATI TV Wonder 650
Air Cooled Stage 3
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 10:09am
I will have a media card reader, 67alecto you should contact DSO about none of them working
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 10:55am
I have the media card reader - so with the USB port on that, I have a total of 5 that work.
The 4 at the bottom of my case do not work - that would give me 9.
I thought I read on the forums here that they could not hook those up for some reason - is that not correct?
Twister Pro
Vanquish II
  Quote gdhart Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 11:57am
According to EVGA's website the LT Mother Board does not have any internal USB connectors, where as the A1 Revision Mother board has 2 connecters.  With out the connectors on the mother board you can not connect the front USB ports.
850W PSU/Pro Case
Q6600-G0 2.7GHz
4GB 800MHz XMS2
2x500GB Ext
ATI TV Wonder 650
Air Cooled Stage 3
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 12:10pm
so if I get the media card reader my 2 front ones will work if I get the A1 motherboard, right?
  Quote gdhart Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 12:31pm
You'll have to check with DS, but I beleive I've seen in other posts that if you have the Media Card reader that the front USB ports will not be hooked up as the USB connectors are needed for the Media Card reader.
850W PSU/Pro Case
Q6600-G0 2.7GHz
4GB 800MHz XMS2
2x500GB Ext
ATI TV Wonder 650
Air Cooled Stage 3
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 12:35pm
Ok, that's what I understood was the case.
Just wanted to make sure I wasn't being cut out Tongue
Twister Pro
Vanquish II
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 12:45pm
why would the reader need 2 usb connections?
  Quote gdhart Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 12:54pm
You'll have to check with DS.  Looking at the specs for the card reader it looks like it only needs a single internal USB Connector.
850W PSU/Pro Case
Q6600-G0 2.7GHz
4GB 800MHz XMS2
2x500GB Ext
ATI TV Wonder 650
Air Cooled Stage 3
sundowner View Drop Down
  Quote sundowner Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 8:33pm
I have a pro case/media card and only 2 of the front usb ports work, i'm guessing not even places on the motherboard since i didn't get the A1.
Pro case with extra fan
Quad Q6600 2.4 OC'd 3.1!
Nvidia 8800GT
Asus Maximus Formula Mobo
2xgb 800mhz corsair
xfire - xuntiltheendx
Kenny View Drop Down
Digital Storm Engineering
  Quote Kenny Quote  Post ReplyReply bullet Posted: 22 Oct 2007 at 10:37pm
The 2 USB ports have 9 pins connector, also 1 Digital Card Reader has 9 pins connector, so that if you have 1 Digital Card Reader, we have to un-plug your 2 USB ports. Thank you for your understanding.
We're here with you !    &(*_~)&
  Quote 67alecto Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 2:49am
Kenny advised me that one of my USB cables was unplugged, so I've reconnected it and I've now got 3 on the front and 4 in the back.
Edited by 67alecto - 23 Oct 2007 at 10:41am
Twister Pro
Vanquish II
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 2:54am
ok Kenny but I thought the A1 revision had 2 connectors, right?
commast View Drop Down
  Quote commast Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 3:14am
The A1 motherboard has a total of 10 usb ports. 6 in the backs and 2 on board usb headers.
  Quote Kenny Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 8:45am
Yeah, you're right, you have 2x9pins USB connectors in Motherboard for front USB.
Edited by Kenny - 23 Oct 2007 at 9:18am
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 2:28pm
so all the front usbs on the front would function on the pro with a media reader if I got the A1 board right? sorry for all the posts but it's better to know all the details before you buy I suppose
  Quote gdhart Quote  Post ReplyReply bullet Posted: 23 Oct 2007 at 3:49pm
Only half of the 4 front USB ports will work.  One of the two 9 Pin USB connectors will be used for the media reader.  The other will be used for 2 of the 4 USB Ports on the front.
I do not have a media reader on my PRO  case and both 9 pin connectors are used to power the 4 USB ports on the front.
Edited by gdhart - 23 Oct 2007 at 3:51pm
850W PSU/Pro Case
Q6600-G0 2.7GHz
4GB 800MHz XMS2
2x500GB Ext
ATI TV Wonder 650
Air Cooled Stage 3
