Problem with Audio Device
Post Date: 2009-02-03
Taurnil View Drop Down
  Quote Taurnil Quote  Post ReplyReply bullet Topic: Problem with Audio Device
    Posted: 03 Feb 2009 at 2:44pm
I recently had a virus on my system, so I needed to reinstall Windows.  Upon reinstalling, I noticed I had no sound, and when I checked under the sound part of the Control Panel, I have no Audio Device installed.  When I check to see what motherboard I'm using, there is no recognizable name, only a code, MCP55-M2N-E-00.  When I use device manager to try to update or reinstall drivers, it says it cannot find the file so it cannot complete the process.  If anyone had any insight, it would be much appreciated.
Samael View Drop Down
  Quote Samael Quote  Post ReplyReply bullet Posted: 03 Feb 2009 at 2:59pm
Dont you have your mother boards CD? That should have all the drivers. I am sure someone will come by and help you out.
Why do they blame me for all their little failings? They use my name as if I spent my entire day sitting on their shoulders, forcing them to commit acts they would otherwise find repulsive - Lucifer
  Quote Taurnil Quote  Post ReplyReply bullet Posted: 03 Feb 2009 at 3:02pm
The computer only came with 4 disks, a Restore DVD, a Windows Home Edition XP Install Disk, a Display Driver Installation CD, and an nForce 570 Series disk.  I don't think any of those are used to reinstall the drivers.
  Quote Samael Quote  Post ReplyReply bullet Posted: 03 Feb 2009 at 3:04pm
the nforce 570 Series disk might be it.
  Quote Taurnil Quote  Post ReplyReply bullet Posted: 03 Feb 2009 at 3:10pm
Yep, you were right.  I was dumb and that it was just a video card reinstall.  Thanks for the help.
This page was generated in 5.371094E-02 seconds.
