Problem With Java
Post Date: 2013-02-21
iHateLoadingScreenz View Drop Down
  Quote iHateLoadingScreenz Quote  Post ReplyReply bullet Topic: Problem With Java
    Posted: 21 Feb 2013 at 4:06pm
Alright, so, for a while now, my computer hasn't been able to run games that require Java, such as Minecraft. Whenever I log into minecraft, it will do the loading screen and then the window will automatically close. It doesn't show a error window or anything. What it does do is make an error message file on my desktop. I've been ahving this problem since i last upgraded my Java to Version 7 Update 15. Below is what is written in to file put onto my desktop. IT would be really appreciated if someone were to help me as this is a MAJOR headache for me and people my my computer.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00000000, pid=5076, tid=3180
# JRE version: 7.0_15-b03
# Java VM: Java HotSpot(TM) Client VM (23.7-b01 mixed mode windows-x86 )
# Problematic frame:
# C 0x00000000
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x4a778800): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=3180, stack(0x4d7c0000,0x4d810000)]
siginfo: ExceptionCode=0xc0000005, ExceptionInformation=0x00000008 0x00000000
Registers:
EAX=0x4a91c830, EBX=0x4514df58, ECX=0x4a9186f0, EDX=0x4a91872c
ESP=0x4d80e9dc, EBP=0x4d80e9fc, ESI=0x00000000, EDI=0x4a778800
EIP=0x00000000, EFLAGS=0x00010206
Top of Stack: (sp=0x4d80e9dc)
0x4d80e9dc:   4cbb7fb6 00000001 4a91c830 4a9186f0
0x4d80e9ec:   00000000 00000000 00000000 00000000
0x4d80e9fc:   4d80ed78 4cbb7db3 fb4fb50e 4a9186f0
0x4d80ea0c:   000004b4 00001738 771a6f70 4d80ea54
0x4d80ea1c:   00000000 01001738 003ba640 003bb620
0x4d80ea2c:   003ba710 4d80ea4c 7711924d 00000001
0x4d80ea3c:   00000001 003ba6b0 003ec760 003d4680
0x4d80ea4c:   4d80ea68 7711924d 00000001 00000001
Instructions: (pc=0x00000000)
0xffffffe0:
Register to memory mapping:
EAX=0x4a91c830 is an unknown value
EBX=0x4514df58 is an oop
{method}
- klass: {other class}
ECX=0x4a9186f0 is an unknown value
EDX=0x4a91872c is an unknown value
ESP=0x4d80e9dc is pointing into the stack for thread: 0x4a778800
EBP=0x4d80e9fc is pointing into the stack for thread: 0x4a778800
ESI=0x00000000 is an unknown value
EDI=0x4a778800 is a thread
Stack: [0x4d7c0000,0x4d810000], sp=0x4d80e9dc, free space=314k
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.WindowsContextImplementation.nSwapBuffers(Ljava/nio/ByteBuffer;)V+0
j org.lwjgl.opengl.WindowsContextImplementation.swapBuffers()V+35
j org.lwjgl.opengl.Context.swapBuffers()V+3
j org.lwjgl.opengl.Display.swapBuffers()V+31
j org.lwjgl.opengl.Display.update(Z)V+44
j org.lwjgl.opengl.Display.update()V+1
j org.lwjgl.opengl.Display.initContext()V+19
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs;)V+97
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;)V+9
j net.minecraft.client.Minecraft.a()V+174
j asq.a()V+94
j net.minecraft.client.Minecraft.run()V+6
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x4a778800 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=3180, stack(0x4d7c0000,0x4d810000)]
0x4a777000 JavaThread "Timer hack thread" daemon [_thread_blocked, id=5528, stack(0x4c900000,0x4c950000)]
0x4a778000 JavaThread "Snooper Timer" daemon [_thread_blocked, id=5460, stack(0x4c980000,0x4c9d0000)]
0x0021b000 JavaThread "DestroyJavaVM" [_thread_blocked, id=4216, stack(0x01d60000,0x01db0000)]
0x4b707800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=2060, stack(0x4bbd0000,0x4bc20000)]
0x4b6ac800 JavaThread "TimerQueue" daemon [_thread_blocked, id=5228, stack(0x4bae0000,0x4bb30000)]
0x4b6e0000 JavaThread "SwingWorker-pool-1-thread-1" daemon [_thread_blocked, id=4164, stack(0x4ba50000,0x4baa0000)]
0x4a8c0400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3556, stack(0x4af40000,0x4af90000)]
0x4a8bfc00 JavaThread "AWT-Shutdown" [_thread_blocked, id=5708, stack(0x4ae30000,0x4ae80000)]
0x4a8bd800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=5824, stack(0x4ad20000,0x4ad70000)]
0x4a76ac00 JavaThread "Service Thread" daemon [_thread_blocked, id=2596, stack(0x4ac90000,0x4ace0000)]
0x4a74c400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=5864, stack(0x4a960000,0x4a9b0000)]
0x4a749c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=3116, stack(0x4ab00000,0x4ab50000)]
0x4a746c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2324, stack(0x4aa70000,0x4aac0000)]
0x4a6f3800 JavaThread "Finalizer" daemon [_thread_blocked, id=3704, stack(0x4a9e0000,0x4aa30000)]
0x024fc400 JavaThread "Reference Handler" daemon [_thread_blocked, id=2236, stack(0x01cc0000,0x01d10000)]
Other Threads:
0x024f8400 VMThread [stack: 0x4a6a0000,0x4a6f0000] [id=4744]
0x4a77bc00 WatcherThread [stack: 0x4ab90000,0x4abe0000] [id=4288]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation   total 157248K, used 99834K [0x04500000, 0x0efa0000, 0x19a50000)
eden space 139776K, 71% used [0x04500000, 0x0a67e930, 0x0cd80000)
from space 17472K,   0% used [0x0cd80000, 0x0cd80000, 0x0de90000)
to   space 17472K,   0% used [0x0de90000, 0x0de90000, 0x0efa0000)
tenured generation   total 349568K, used 0K [0x19a50000, 0x2efb0000, 0x44500000)
   the space 349568K,   0% used [0x19a50000, 0x19a50000, 0x19a50200, 0x2efb0000)
compacting perm gen total 13056K, used 12955K [0x44500000, 0x451c0000, 0x48500000)
   the space 13056K, 99% used [0x44500000, 0x451a6ce8, 0x451a6e00, 0x451c0000)
No shared spaces configured.
Card table byte_map: [0x4a300000,0x4a530000] byte_map_base: 0x4a2dd800
Polling page: 0x001d0000
Code Cache [0x02500000, 0x026d8000, 0x04500000)
total_blobs=1089 nmethods=778 adapters=245 free_code_cache=30895Kb largest_free_block=31637376
Compilation events (10 events):
Event: 17.326 Thread 0x4a74c400 770             java.lang.StringCoding::access$300 (8 bytes)
Event: 17.326 Thread 0x4a74c400 nmethod 770 0x026d2c48 code [0x026d2d50, 0x026d2efc]
Event: 17.326 Thread 0x4a74c400 771             java.lang.StringCoding::safeTrim (24 bytes)
Event: 17.327 Thread 0x4a74c400 nmethod 771 0x026d3008 code [0x026d3110, 0x026d32bc]
Event: 17.327 Thread 0x4a74c400 772             java.lang.String::getBytes (14 bytes)
Event: 17.327 Thread 0x4a74c400 nmethod 772 0x026d3388 code [0x026d3490, 0x026d352c]
Event: 17.327 Thread 0x4a74c400 773   !        java.lang.StringCoding::encode (64 bytes)
Event: 17.328 Thread 0x4a74c400 nmethod 773 0x026d35c8 code [0x026d3760, 0x026d3ad4]
Event: 17.338 Thread 0x4a74c400 774             java.util.HashSet::contains (9 bytes)
Event: 17.338 Thread 0x4a74c400 nmethod 774 0x026d3e88 code [0x026d3f90, 0x026d402c]
GC Heap History (0 events):
No events
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 17.320 Thread 0x4a778800 Threw 0x0a575c50 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.320 Thread 0x4a778800 Threw 0x0a576010 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.339 Thread 0x4a778800 Threw 0x0a590a30 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.339 Thread 0x4a778800 Threw 0x0a590e58 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.339 Thread 0x4a778800 Threw 0x0a593de8 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.339 Thread 0x4a778800 Threw 0x0a5941e0 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.340 Thread 0x4a778800 Threw 0x0a597328 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.340 Thread 0x4a778800 Threw 0x0a597750 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.341 Thread 0x4a778800 Threw 0x0a59ad48 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 17.341 Thread 0x4a778800 Threw 0x0a59b108 at C:\jdk7u2_32P\jdk7u15\hotspot\src\share\vm\prims\jvm.cpp:1166
Events (10 events):
Event: 17.320 loading class 0x4cfedb50
Event: 17.320 loading class 0x4cfedb50 done
Event: 17.339 loading class 0x4cff1650
Event: 17.339 loading class 0x4cff1650 done
Event: 17.339 loading class 0x4cfebea0
Event: 17.339 loading class 0x4cfebea0 done
Event: 17.340 loading class 0x4cff20d0
Event: 17.340 loading class 0x4cff20d0 done
Event: 17.340 loading class 0x4b92b3e0
Event: 17.341 loading class 0x4b92b3e0 done
Dynamic libraries:
0x01080000 - 0x010af000      C:\Program Files\Java\jre7\bin\javaw.exe
0x770e0000 - 0x77208000      C:\Windows\system32\ntdll.dll
0x75000000 - 0x750dc000      C:\Windows\system32\kernel32.dll
0x75710000 - 0x757d6000      C:\Windows\system32\ADVAPI32.dll
0x75a10000 - 0x75ad3000      C:\Windows\system32\RPCRT4.dll
0x75970000 - 0x75a0d000      C:\Windows\system32\USER32.dll
0x767d0000 - 0x7681b000      C:\Windows\system32\GDI32.dll
0x73bc0000 - 0x73d5e000      C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\COMCTL32.dll
0x75240000 - 0x752ea000      C:\Windows\system32\msvcrt.dll
0x74e50000 - 0x74ea9000      C:\Windows\system32\SHLWAPI.dll
0x768b0000 - 0x768ce000      C:\Windows\system32\IMM32.DLL
0x75170000 - 0x75238000      C:\Windows\system32\MSCTF.dll
0x768a0000 - 0x768a9000      C:\Windows\system32\LPK.DLL
0x74dd0000 - 0x74e4d000      C:\Windows\system32\USP10.dll
0x01000000 - 0x01038000      C:\Windows\system32\d3dgearload.dll
0x67a60000 - 0x67b1e000      C:\Program Files\Java\jre7\bin\msvcr100.dll
0x621d0000 - 0x6251c000      C:\Program Files\Java\jre7\bin\client\jvm.dll
0x72700000 - 0x72707000      C:\Windows\system32\WSOCK32.dll
0x755c0000 - 0x755ed000      C:\Windows\system32\WS2_32.dll
0x76890000 - 0x76896000      C:\Windows\system32\NSI.dll
0x734f0000 - 0x73522000      C:\Windows\system32\WINMM.dll
0x74eb0000 - 0x74ff5000      C:\Windows\system32\ole32.dll
0x752f0000 - 0x7537d000      C:\Windows\system32\OLEAUT32.dll
0x734b0000 - 0x734ee000      C:\Windows\system32\OLEACC.dll
0x74d70000 - 0x74d77000      C:\Windows\system32\PSAPI.DLL
0x72fd0000 - 0x72fdc000      C:\Program Files\Java\jre7\bin\verify.dll
0x72fb0000 - 0x72fd0000      C:\Program Files\Java\jre7\bin\java.dll
0x72f90000 - 0x72fa3000      C:\Program Files\Java\jre7\bin\zip.dll
0x64200000 - 0x64342000      C:\Program Files\Java\jre7\bin\awt.dll
0x73ec0000 - 0x73eff000      C:\Windows\system32\uxtheme.dll
0x75ae0000 - 0x765f1000      C:\Windows\system32\SHELL32.dll
0x77290000 - 0x7729c000      C:\Windows\system32\DWMAPI.DLL
0x69c90000 - 0x69cba000      C:\Program Files\Java\jre7\bin\fontmanager.dll
0x72f70000 - 0x72f84000      C:\Program Files\Java\jre7\bin\net.dll
0x73f90000 - 0x73fa4000      C:\Windows\system32\wpclsp.dll
0x74a60000 - 0x74ad6000      C:\Windows\system32\NETAPI32.dll
0x74820000 - 0x74831000      C:\Windows\system32\SAMLIB.dll
0x743a0000 - 0x743db000      C:\Windows\system32\mswsock.dll
0x74400000 - 0x74405000      C:\Windows\System32\wship6.dll
0x72f60000 - 0x72f6e000      C:\Program Files\Java\jre7\bin\nio.dll
0x73dd0000 - 0x73ddf000      C:\Windows\system32\NLAapi.dll
0x745f0000 - 0x74609000      C:\Windows\system32\IPHLPAPI.DLL
0x745b0000 - 0x745e5000      C:\Windows\system32\dhcpcsvc.DLL
0x74840000 - 0x7486c000      C:\Windows\system32\DNSAPI.dll
0x74c10000 - 0x74c24000      C:\Windows\system32\Secur32.dll
0x745a0000 - 0x745a7000      C:\Windows\system32\WINNSI.DLL
0x74570000 - 0x74592000      C:\Windows\system32\dhcpcsvc6.DLL
0x70aa0000 - 0x70aaf000      C:\Windows\system32\napinsp.dll
0x70800000 - 0x70812000      C:\Windows\system32\pnrpnsp.dll
0x70ab0000 - 0x70ab8000      C:\Windows\System32\winrnr.dll
0x74d80000 - 0x74dc9000      C:\Windows\system32\WLDAP32.dll
0x74120000 - 0x7415b000      C:\Windows\system32\rsaenh.dll
0x74c30000 - 0x74c4e000      C:\Windows\system32\USERENV.dll
0x73480000 - 0x73486000      C:\Windows\system32\rasadhlp.dll
0x74060000 - 0x74065000      C:\Windows\System32\wshtcpip.dll
0x69c70000 - 0x69c90000      C:\Program Files\Java\jre7\bin\sunec.dll
0x676d0000 - 0x67701000      C:\Program Files\Java\jre7\bin\t2k.dll
0x750e0000 - 0x75164000      C:\Windows\system32\CLBCatQ.DLL
0x730b0000 - 0x731a4000      C:\Windows\system32\WindowsCodecs.dll
0x74bb0000 - 0x74bdc000      C:\Windows\system32\apphelp.dll
0x768f0000 - 0x7690f000      C:\Windows\system32\EhStorShell.dll
0x73390000 - 0x7344b000      C:\Windows\system32\PROPSYS.dll
0x73450000 - 0x73459000      C:\Program Files\Java\jre7\bin\sunmscapi.dll
0x746a0000 - 0x74793000      C:\Windows\system32\CRYPT32.dll
0x74800000 - 0x74812000      C:\Windows\system32\MSASN1.dll
0x4b320000 - 0x4b38b000      C:\Users\Hollis\AppData\Roaming\.minecraft\bin\natives\lwjgl.dll
0x68580000 - 0x6864b000      C:\Windows\system32\OPENGL32.dll
0x68700000 - 0x68723000      C:\Windows\system32\GLU32.dll
0x68490000 - 0x68575000      C:\Windows\system32\DDRAW.dll
0x6de60000 - 0x6de66000      C:\Windows\system32\DCIMAN32.dll
0x757e0000 - 0x7596a000      C:\Windows\system32\SETUPAPI.dll
0x74410000 - 0x74418000      C:\Windows\system32\VERSION.dll
0x4cb90000 - 0x4cf71000      C:\Windows\system32\D3DGear.dll
0x76b70000 - 0x76d2a000      C:\Windows\system32\D3d9.dll
0x77260000 - 0x77266000      C:\Windows\system32\d3d8thk.dll
0x68920000 - 0x689a0000      C:\Windows\system32\Dxgi.dll
0x68730000 - 0x68832000      C:\Windows\system32\D3d10.dll
0x69b00000 - 0x69b33000      C:\Windows\system32\d3d10core.dll
0x6a2d0000 - 0x6a2fc000      C:\Windows\system32\D3d10_1.dll
0x688e0000 - 0x6891a000      C:\Windows\system32\d3d10_1core.dll
0x68850000 - 0x688d3000      C:\Windows\system32\D3d11.dll
0x657e0000 - 0x658e6000      C:\Windows\system32\D3d8.dll
0x6d7e0000 - 0x6d7e6000      C:\Program Files\Java\jre7\bin\jawt.dll
0x4dd10000 - 0x4df5a000      C:\Windows\system32\ig4icd32.dll
0x4e140000 - 0x4e28d000      C:\Windows\system32\ig4dev32.dll
0x6d230000 - 0x6d30c000      C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m
java_command: C:\Users\Hollis\Desktop\Minecraft.exe
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
PATH=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\Intel\DMIX;C:\Program Files\Common Files\Roxio Shared\10.0\DLLShared\;C:\Program Files\QuickTime\QTSystem\;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\D3DGear;C:\Program Files\Java\jre7\bin
USERNAME=Hollis
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 6, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows Vista Build 6002 Service Pack 2
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 6, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, tsc
Memory: 4k page, physical 3134484k(1678548k free), swap 6489168k(4436452k free)
vm_info: Java HotSpot(TM) Client VM (23.7-b01) for windows-x86 JRE (1.7.0_15-b03), built on Feb 15 2013 14:01:25 by "java_re" with unknown MS VC++:1600
time: Thu Feb 21 18:50:50 2013
elapsed time: 17 seconds
Hello, My name is Steve (Hi Steve!) and im addicted to computers...
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 4:25pm
not quiet sure what is going on.
try uninstalling all java versions via ccleaner, then install the latest one if you have a 32bit download this one
JerryW View Drop Down
  Quote JerryW Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 6:23pm
Scratch that idea I had.
I've been looking via web searches and the same problem is popping up all over the place.
Edited by JerryW - 21 Feb 2013 at 7:12pm
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 6:39pm
Originally posted by JerryW
Scratch that idea.
Scratch DST's idea? That's precisely where I would start. Or did you edit your own post? Just trying to clarify for future readers.
  Quote JerryW Quote  Post ReplyReply bullet Posted: 21 Feb 2013 at 7:10pm
Scratch that idea.I've been looking via web searches and the same problem is popping up all over the place.
Scratch my post.
  Quote iHateLoadingScreenz Quote  Post ReplyReply bullet Posted: 22 Feb 2013 at 7:09pm
I've tried uninstalling java and reinstalled the latest one. It might just be because the latest java only comes out with a 64 bit operating system. My old Dell XPS 210 has 32 bit so that might be it. I appreciate all you guys help. I didn't expect many people to help but when I saw replies I was really glad someone Could help. I'll try what you suggested and ill reply back
  Quote iHateLoadingScreenz Quote  Post ReplyReply bullet Posted: 22 Feb 2013 at 8:21pm
I tried downloading the 32 bit java. The same error message pops up. It just baffles me as to what's happening
  Quote JerryW Quote  Post ReplyReply bullet Posted: 22 Feb 2013 at 9:21pm
Java is trying to set up a Virtual Machine. There is a library that it is accessing that it does not like.  The problem is trying to find what it is using.  It could be a plug-in on some software you have installed.  It could be trying to access memory and running in to a problem. It is going to take some detective work to pin it down and that is not easy some times.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Feb 2013 at 10:08pm
Ok so latest java gives the same error that means it can be your drivers, what version of nvidia driver do you have?
  Quote iHateLoadingScreenz Quote  Post ReplyReply bullet Posted: 23 Feb 2013 at 1:21pm
I'm not running anygraphics card. All I have is intel standard graphics so...
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Feb 2013 at 1:22pm
That maybe your problem, the log indicates an issue with graphic card drivers.
  Quote iHateLoadingScreenz Quote  Post ReplyReply bullet Posted: 23 Feb 2013 at 3:00pm
I'll try and update my drivers for my graphics. I hope it works, otherwise I might have to buy the only graphics card that goes in my pc
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Feb 2013 at 3:03pm
Well see if you can take one out another pc or borrow one from a friend and test it, getting another gpu may not fix the problem.
  Quote iHateLoadingScreenz Quote  Post ReplyReply bullet Posted: 23 Feb 2013 at 3:46pm
I know of only a few that will fit in my pc. This is why I plan on getting a digital storm when I get enough money for it :p until then ill just deal with what a have
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Feb 2013 at 3:47pm
Good luck Boss
