Problems with IE 10
Post Date: 2013-05-30
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Topic: Problems with IE 10
    Posted: 30 May 2013 at 8:18am
Is anybody having problems with the version of IE 10 that microsoft just shoved down our throats via an automatic push update? There seem to be quite a few complaints bug reports online, but that could be from just a tiny fraciton of the users.
IE 10 installed on my two Win 7/64 machines Tuesday. One of them seems to work fine. The other can't open page links in a new tab or window. It looks like this problem also existed, for some people, as far back as IE 8, but I haven't seen an actual fix for it. My solution was to roll the one machine back to IE 9 and shut off automatic updates.
I suppose the ultimate solution would be to switch to Firefox or Chrome.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 30 May 2013 at 8:27am
So far so good for me.   It just updated today, and other than being initially slow, has gotten a lot better.  My older pc will probably get the update later on when my wife uses it, so we'll see.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 30 May 2013 at 9:24am
I have IE10 but i don't ever use it, i use Chrome
lusiphur View Drop Down
  Quote lusiphur Quote  Post ReplyReply bullet Posted: 30 May 2013 at 12:55pm
I use Safari
Change your Windows Update settings so they don't automatically install.
You have the option for it to
1. Do nothing
2. Check for updates
3. Check for updates and download
4. Check for Updates, download and install
I prefer to keep mine at 2 because when it is set to 4, it will install updates while you are in the middle of something and then bounce you out with a message saying updates were installed.
Marshmellow Fluff is proof of a higher existence.
Tardis >>> My Digital Storm Bolt with GTX TITAN
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 30 May 2013 at 5:30pm
Thanks for the info lusiphur!
This page was generated in 5.957031E-02 seconds.
