Professionally Extreme Gaming Build :)
Post Date: 2012-03-15
nemex View Drop Down
  Quote nemex Quote  Post ReplyReply bullet Topic: Professionally Extreme Gaming Build :)
    Posted: 15 Mar 2012 at 8:24pm
Just going to follow the standard format since it's been layed out :)
Around $6000. Would like it to be lower, but willing to go a bit higher. I only need a tower, I already have monitors and peripherals.
My current system is antiquated, to say the least. Currently my favorite hobby, as well as secondary source of income, is from being a professional gamer. The market is moving, and I know that I need to expand my distribution in forms of expanding my YouTube channel and being able to host a high-quality stream for the games I'm playing. My sponsors are really pushing me on this.
I need to be able to fraps AND stream games in high/ultra quality, such as BF3, WoW, SC2, D3, CS1.6 (yeah not intensive), and future games.
I also need this computer to have longevity; at least 4 years.
I'm going to be using this computer upwards of 12 hours a day, most days around 6. It needs to be high performing and consistent, as well as quiet and aesthetically pleasing for when I have guests.
I'm going to be recording everything to my SSD's due to the performance gap compared to HDD writing. I'm initially planning 240gb of SSD space (I've grown accustom to having small disk space), though I'm unsure of how much space I'll need / be consuming with fraps at 60 fps on 1900x1200 or higher. I also need multitasking power to do all that has been mentioned, as well as potentially running 2-3 game clients simultaneously.
I'll also be rendering videos and projects quite a bit, and I'll probably want to be playing/streaming while doing so with little to no downtime, if possible.
Saved Ticket #: 665505 is my current WIP.
Specifications: The components that I've definitively chosen are the Rampage IV Extreme board as well as the 3930k. SSD/HDD's are up in the air, as well as PSU (though 1200W seems to be a well rounded number). I currently have selected dual 590's in quad SLI, though I'm waiting to compare to Nvidia's 680 SLI or 690 quad SLI when they're released soon (I prefer green over red :) ). I definitely want high performing liquid cooling on both my CPU and GPUs. I'm also unsure about which case I'll be sticking with, though out of the available on the DS site the Cosmos II is my favorite.
As a side note, I chose so much RAM because I'm unsure of what is going to be consumed by my everyday processes. If what I have is far more than enough, then I'll gladly run my game of the week off the "remainder" of the RAM itself.
Questions I Have:
1. I'm unsure of how DS does their waterblocks for GPUs; if they're custom made and/or outsourced. How soon after Nvidia's 6 series is released will waterblocks be available for liquid cooling solutions through their "stage 6" option?
2. Is DS willing to use cases not provided on their website? I'm still deciding between the Cosmos II and the SilverStone TJ11W-B, which isn't listed.
*how cool would it be to have a Cosmos II design with the top I/O functionality and air flow of the TJ11W-B? *
Any feedback is appreciated :)
Edited by nemex - 15 Mar 2012 at 8:34pm
BF3Addict View Drop Down
  Quote BF3Addict Quote  Post ReplyReply bullet Posted: 15 Mar 2012 at 11:08pm
I'll take a shot here since its late and I'm bored and not yet sleepy.
The 590's are not recommended. They run hot and it's really hard to find them now because they're at their end of life cycle. The 680's are about to be released in a few weeks (April maybe) and the word on the street is they are about 15-20% faster than AMD's 7970 cards. Also the 680's are PCI 3.0 compliant which gives you twice the bandwidth between the card and the mobo. I believe your choice of mobo will support the 3.0 spec (at least I assume so since the next lower one, the X79 deluxe, does. Put two or three 680's in SLI and you'll be screaming!
One final note about the 590's. A pair of SLI 570's will outperform a single 590. I believe three 580's in SLI will outperform a quad 590 (two card) setup as well. The 590 is essentially a pair of 570's on a single card sharing the bandwidth.
I know you said you were definitely getting the Rampage IV mobo, but if you're going to have DS do your OC for you why spend the extra money? The P9X79 Deluxe is about $70 cheaper and will handle the OC nicely. The only thing the Rampage has over the deluxe is the ability to mount four video cards vs three cards. Oh the deluxe has built in Bluetooth and wifi too.
The 1200W PSU will be fine for tri SLI. For reference I have a i7-3930K system with tri GTX570's and under max CPU/GPU loading (using Furmark and Prime simultaneously) I'm drawing about 870W (measured with a Kill-A-Watt device) from the wall.
I would lose the OC on the video cards. It tends to just shorten the life of the card while giving a marginal performance increase.
Lose the Raid setup on the SSD. I'm not even sure data striping makes any sense with SSD's. You already have a major speed boost. Plus if you lose one SSD you lose all of your data. If you want the extra capacity then get a single 240GB Intel 520.
Edited by BF3Addict - 15 Mar 2012 at 11:31pm
kenage View Drop Down
  Quote kenage Quote  Post ReplyReply bullet Posted: 16 Mar 2012 at 5:28am
Taking a look at your configuration...
The CM Cosmos II is a nice case, to be sure. Personally I don't like the aesthetic as much and would prefer the Corsair 800D, but either will handle the dual loop LC.
The Rampage IV is nice, and being an ROG product it'll handle all kinds of gaming well. But as BF3Addict mentions, the P9X79 Deluxe will serve you just as well. Up to you, in the end.
64GB of RAM? Even with running 2-3 game clients and Fraps, that's feels a bit excessive to me. I'd top out at 32GB maybe, since 16GB could get strained with all those clients running.
The PSU size is determined mostly by the number of cards you put into it. The 1200W is needed for tri-SLI, but you only need the 1050W Corsair Pro 1050HX for a dual card setup.
I would recommend the Intel 520 SSDs over the Corsair ones, just due to some firmware improvements Intel has made that the Corsair ones lack. I don't know if the Corsair firmware has TRIM support in RAID 0, but the Intel ones do, and TRIM support is what you want to keep your drives' longevity up. Or you could go with a single 240GB and not worry about it.
As BF3Addict says, the 590 is pretty much garbage. You'll see better returns out of either a tri-SLI 580 setup or a dual-CF 7970. I haven't seen much in the way of reviews comparing those two, but a dual 7970 beats a dual 580 very handily, and the dual 7970 is so powerful that most boutique manufacturers don't even go tripe-CF on it. A really nice dual 7970 review can be found here.
I would suggest also waiting to see how the Kepler cards compare, as information on the cards is supposed to be released next week, although slides for the 680 have already been leaked. The 680 looks to be a beast of a card, moreso than the  7970.
Whichever card you go for, you'll see better returns with the 7970 or 680, for future-proofing. They're both PCI-E 3.0 cards, like the motherboard, so when such a time comes as graphics cards exceed the PCI-E 2.0 x8 bandwidth, having a 3.0-capable board and cards will benefit you.
Given the stress your system will be under, it probably wouldn't hurt to bump the LC to include the chipset.
There's little reason to go with "performance" fans on the system, because you'll have most every heat source water-cooled. All they do is add noise and lights. But that's personal preference moreso, as I imagine you're used to living with jet engines when you game ;)
In the notes, remember to mention that you don't want your CPU OC to exceed a vcore of 1.4v
OC the video cards, not usually worth it. The 7970s have a huge headroom for OC though, and I imagine the 680s will as well. Personal preference again, and it's free to boot. Utilities exist to shut down the OC if you don't see enough performance gains to warrant shortening the life of the cards.
Windows 7 Ultimate vs Professional is a wash for me. Over Professional, you get BitLocker and some other miscellaneous additions, that for home users don't amount to the extra $30.
And last but certainly not least, you forgot your t-shirt!
With suggested changes, here's the new configuration: 665574
It comes in at $300ish cheaper. If you still want the 64gb of RAM, that'll make the configuration some $60 more expensive, but you get better video cards and chipset LC as well.
Edited by kenage - 16 Mar 2012 at 7:21pm
— Kenage
MCTS, MCP, Security+, Network+
Never put off until tomorrow what you can avoid doing entirely.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 16 Mar 2012 at 9:27am
Hi nemex,
So far you have gotten some very good advice. I was going to suggest a build for you but decided to just give you my thoughts.
1. The Case: For a full LC system the best case that DS offers is their HailStorm Edition. Which is the Obsidian 800D. I am a little confused by your comments about good airflow but you will have a full LC system. The Cosmos II is cool looking but is primarily an air cooled case. I suggest you go with the HailStorm. We have many members with full water systems that used the Hailstorm.
2. SSD/HDD: The best choice right now for your SSD is the Intel 520. If it was me I would get the 240Gb drive rather than two 120s. Corsair had a lot of problems with their SSDs but they seem to have resolved those problems. At least no one has reported any problems that I have see here. The Corsair SSD are cheaper than the Intel. Then use the HDD for data storage and backup. A good way to do this to get two 1Tb HDDs and then use one for data and one for backup. An external HDD is also a good way to go for backup.
3. RAID: I urge you to reconsider going with a RAID-0 configuration for your SSDs. This use to be necessary to get more speed out of your HDD. The speed of the SSD is so much faster you don't need to go RAID-0. RAID-0 strips the information and writes between the two SSDs. If one SSD fails you now have fragmented data on the second SSD and no way to recover it. So all your information is lost.
4. Power Supply: Get the 1200AX Corsair PS. It has a longer warranty and better performance than the DS PS.
5. GPU: The 590 is a terrible choice as outlined by others above.
6. Win-7: There is no reason to go with Ultimate unless you want to use foreign languages. Win-7 Pro is a good choice.
I also wonder about your monitor strategy. You say you have monitors with 1920 x 1200 resolution. Do you plan on playing on multiple monitors? That will influence how many GPUs you might need. Also if you are going to be a world class gamer why aren't you playing on a 27" or 30" with 2550 x 1600 resolution. Wouldn't this give you a leg up?
Edited by FrankW - 16 Mar 2012 at 9:30am
Avelict View Drop Down
  Quote Avelict Quote  Post ReplyReply bullet Posted: 16 Mar 2012 at 9:50am
Build 665622
Cost 5,616
So a couple things I did with this build was to go with the hailstorm case, primarily designed for LC. STage 6 cooling for CPU, chipset and GPU's. Since you're only playing on one monitor atm a dual 7970 setup would destroy.
Hard Drive Set 1: Operating System: 1x (240GB Solid State (By: Intel) (Model: 520 Series)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Hitachi/Seagate (7200 RPM) (32MB Cache)
Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (ASUS BC-12B1ST)
Video Card: 2x CrossFire Dual (ATI Radeon HD 7970 3GB)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards & Chipset
H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
Exclusive T-Shirt: Digital Storm T-Shirt - Black (Large)
Warranty: Life-time Expert Customer Care with 6 Year Limited Warranty
Edited by Avelict - 16 Mar 2012 at 9:51am
  Quote Avelict Quote  Post ReplyReply bullet Posted: 16 Mar 2012 at 9:52am
I meant for a Stage 2 CPU OC.
  Quote nemex Quote  Post ReplyReply bullet Posted: 16 Mar 2012 at 12:03pm
Thanks for the advice so far. I'm not going to be ordering a final system until I get definitive information on Nvidia's 680 price and performance in SLI versus the 7970 CF.
  Quote Alex Quote  Post ReplyReply bullet Posted: 16 Mar 2012 at 12:09pm
Chilling
  Quote Avelict Quote  Post ReplyReply bullet Posted: 16 Mar 2012 at 12:12pm
Lol Im sure Alex already knows pricing details.
But prelim 680 testing came out, and it's a 30% jump over the 580's, which is very impressive in one generation imo. And in almost every game the 680 outperformed the 7970 by 10+ fps. So excited!!!
  Quote nemex Quote  Post ReplyReply bullet Posted: 16 Mar 2012 at 12:26pm
Haha, more or less what I mean is that I'm not going to be ordering a system until 680's are available :P
Editing in a question I have:
Regarding the advice given, how necessary is using liquid cooling on the chipset? I'm in the midst of finding information on this myself, but if anyone else has something to point out I would be grateful :)
Edited by nemex - 16 Mar 2012 at 12:28pm
This page was generated in 6.152344E-02 seconds.
