PSU Problem
Post Date: 2019-01-27
KiLLaMuNoZ View Drop Down
  Quote KiLLaMuNoZ Quote  Post ReplyReply bullet Topic: PSU Problem
    Posted: 27 Jan 2019 at 1:39am
Hello,
My PSU made a pop noise last night and will not power up. This is the second time my PSU has failed to power since I purchased the PC it has been a little over a year.
Would you guys recomenned me bringing it in to the facility or will it be better if I just buy a new PSU.
Also what are some good PSU that will work with my system.
Exterior Finish: Exotic Paint Finish - Blanco White
Processor: Intel Core i7-8700K (6-Core) 3.70GHz
Motherboard: ASUS ROG MAXIMUS X HERO (Intel Z370 Chipset) (Up to 3x PCI-E Devices)
System Memory: 16GB DDR4 3000MHz Digital Storm Performance Series
Power Supply: 1000W EVGA SuperNOVA G2
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Samsung 960 PRO) (NVM Express) (Extreme Performance)
Storage Set 2: 1x Storage (2TB Seagate / Toshiba)
Graphics Card(s): 1x GeForce GTX 1080 Ti 11GB (Performance Edition) (VR Ready)
Extreme Cooling: H20: Stage 2: Corsair H115i - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance)
Airflow Control: - No Thanks
Recovery Tools: Windows 10 Installation CD Only (Clean Install with No Drivers)
Branded Gear: - No Thanks
Warranty: Life-time Expert Care with 3 Year Limited Warranty (
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 27 Jan 2019 at 2:04am
Most likely a bad psu. Can you smell anything? Electronics gives off a very distinct smell when overheating, caps shorting, etc.
If it’s still under warranty with DS then have them verify it and they send a new one.   Being a modular psu, changing it should be easy.
A long shot, but try plugging the psu directly into a wall outlet, no surge protector.
  Quote Snaike Quote  Post ReplyReply bullet Posted: 27 Jan 2019 at 3:45am
The electrician in my family calls this "Letting the magic smoke out."
  Quote KiLLaMuNoZ Quote  Post ReplyReply bullet Posted: 27 Jan 2019 at 7:26am
No smell or smoke.
I tried plugging into a different outlet but I got nothing.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 27 Jan 2019 at 7:39am
Double check the On/Off switch on the psu.   It might have tripped..  Not usually, but ya never know.
Just in case its the mobo and not psu, hard to tell sometimes, unplug the 24 pin and 8 pin from the mobo and short the green and a black wire in 24 pin connector.  Do this by unplugging from the wall, unplug the 24 and 8 pin from mobo, short green and black with paper clip, pins 15 and 16 usually, but go by color,  plug back in and see if the fans , lights turn on.
Big%20Smile
