Question about fans?
Post Date: 2015-09-10
jackbutler68 View Drop Down
  Quote jackbutler68 Quote  Post ReplyReply bullet Topic: Question about fans?
    Posted: 10 Sep 2015 at 3:54pm
OK just thought about this when I was reading another post. I selected the fan upgrade to the Corsair Airflow Performance Edition (Up to 6 Fans), will they install all 6 fans in the case or send the extra ones if they don't use them?
I ordered the Corsair Obsidian 550D case and it has a spot for 2 fans on the side panel but I don't think the fans are included in the stock fan configuration. Just thought it might help pull the heat out of the case near the graphics card.
Thanks
OccamsRazor View Drop Down
  Quote OccamsRazor Quote  Post ReplyReply bullet Posted: 12 Sep 2015 at 12:42am
"Obsidian Series 550D comes with two front-mounted 120mm intake fans and one 120mm exhaust fan... The top panel provides room for two 120mm or 140mm fans... The side panel has mounting points for another two 120mm or 140mm fans for cooling multiple GPUs...
In total, the 550D offers ten 120mm fan mounting points, six of which can also accommodate 140mm fans."
Taken direct from the 550D sales page from the Corsair website.
http://www.corsair.com/en-us/obsidian-series-550d-mid-tower-quiet-case
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Sep 2015 at 2:54am
I believe DS only replaces existing fans with a particular build if possible and doesn't add fans to optional locations.   They don't send unused fans last I heard. So with 550d they might replace the front 2 and rear fan.   Cooler fan I'm not sure.
The Slade 550d is popular for its quietness because of the top and side acoustic panels and adding fans there defeats that purpose.
If stress testing shows the need which isn't common with new cards, etc. they'll add fans.
DS would need to answer this as each build is different.
Edited by bprat22 - 12 Sep 2015 at 2:57am
Dax Doomslayer View Drop Down
Keeper of the commas
  Quote Dax Doomslayer Quote  Post ReplyReply bullet Posted: 12 Sep 2015 at 7:10am
When I was asking about the fans for the Corsair Air 540 and going the optional x3 120mm vs x2 140mm I was told that you would need to buy the optional fan package and their policy is that you don't get the extra fans if you don't use all 6.
  Quote jackbutler68 Quote  Post ReplyReply bullet Posted: 12 Sep 2015 at 7:37am
Okay thanks. I know the top panel will house the 240mm radiator so i am guessing that the front 2 fans and the rear fan will be upgraded.
My DS Slade..
Intel Core i7 5820K 3.3GHz
GIGABYTE GA­X99­SLI
32GB DDR4 2800MHz Corsair Vengeance LPX
SSD 1TB Samsung 850 EVO
NVIDIA GeForce GTX 980 Ti 6GB (ASUS Strix Edition)
