Question about the DRAM_LED
Post Date: 2012-08-29
LinkGirl View Drop Down
  Quote LinkGirl Quote  Post ReplyReply bullet Topic: Question about the DRAM_LED
    Posted: 29 Aug 2012 at 12:37am
Hey guys, because I had some bad RAM in my computer, I've had to take my RAM out and put in some new sticks. I haven't had any problems, but I did notice when starting up my computer that the DRAM_LED (on my AUSU P8X77-V LX) turned on for a second and then turned off. Everything started up fine, but I'm a bit paranoid now. Is it normal for the DRAM_LED to turn on for a second when first starting up your computer or is it possible that I didn't correctly seat one of the sticks (not sure how that's possible if the computer starts up fine).
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 29 Aug 2012 at 6:21am
As long as the LED goes off I think your good to go.  It does check the ram on boot and if it sees a problem stays on until fixed.
Good luck
Double check with your mobo manual under Onboard LEDs.
Edited by bprat22 - 29 Aug 2012 at 6:22am
