Question of hard drive partitioning
Post Date: 2022-03-13
Teufelhunde View Drop Down
  Quote Teufelhunde Quote  Post ReplyReply bullet Topic: Question of hard drive partitioning
    Posted: 13 Mar 2022 at 9:09pm
Waiting for my build to get done, and it will come with a 1tb SSD. I have one, maybe two questions....
1) Is there any advantage to partitioning the hard drive into a system only drive and a general use drive?
2) If question #1=yes, then with Windows 11 what would be the proper size for the system only drive?
TIA for the input
Lon
  Quote hoserator Quote  Post ReplyReply bullet Posted: 14 Mar 2022 at 12:20am
It really is up to you.
Some users like partitioning when the drive is large to speed up certain processes. With the new SSDs, speed has become a relative term and not the reason originally premised therefor.
I have 1 TB non-partitioned primary drives in 3 systems and have no complaints (yet). Smile
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 14 Mar 2022 at 1:59am
I also have multiple systems with primary OS Drive not partitioned.   Never felt the need, one reason being my files are primarily games, not any kind of critical data.   One reason to partition is if you get corrupted files the OS and data files stay seperated, easier to reformat.     My opinion is that a bad drive is more likely and partition doesn’t matter.
But, up to you like hose said.   Nothing wrong with it. You sometimes lose storage space when partitioning but not huge.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 14 Mar 2022 at 3:37am
I have been an advocate of partitioning, but I bow to my friends' more modern take on it. My NVMe SSD is a Samsung 960, and the much newer 980 is over twice as quick. I like a compact drive for faster, easier scans and back-ups mostly, but hoserator says his 1TB 980 is plenty fast enough.
If still on the table, the size depends on what your non-gaming software needs are. If all you use are the OS and a couple of essential apps and maintenance software, you could probably get by with ~100 GB. If you have Office or the like and some other large programs, 150-200 GB would be plenty.
PS: your username mean you're a fellow Marine, Lon?
  Quote Teufelhunde Quote  Post ReplyReply bullet Posted: 14 Mar 2022 at 7:23am
Thanks to all for the replies.
Lon
  Quote Teufelhunde Quote  Post ReplyReply bullet Posted: 14 Mar 2022 at 7:25am
Yessir, 1972to 1989. First as an 0311, then 0369, got out for a short spell, back in with retraining as an Air Traffic Control Radar Tech, 5953.
Medical discharge at a whopping 10%......
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 14 Mar 2022 at 4:28pm
I have a 500GB 980 for the OS & daily games, 1TB 970 for my game library and general use, as well as a 1TB HD for documents & music. Seems to work out for me.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 15 Mar 2022 at 4:20am
  Quote hoserator Quote  Post ReplyReply bullet Posted: 17 Mar 2022 at 2:15pm
Thank you all for your service and in particular when being in the service was looked down upon, if not worse.
Edited by hoserator - 17 Mar 2022 at 2:15pm
This page was generated in 5.664063E-02 seconds.
