Question on CPU Temps
Post Date: 2010-07-20
ZFrost View Drop Down
  Quote ZFrost Quote  Post ReplyReply bullet Topic: Question on CPU Temps
    Posted: 20 Jul 2010 at 4:47pm
So I've been watching my CPU temps the past few days and I'm just trying to make sure everything is as it's supposed to be, they seem slightly high in my opinion. I picked the Asetek LC CPU option for the cooling, should I consider replacing it with something like the NH-D14?
Anyway, here's the temps. The highest I've seen one of the cores get to under heavy load is 81°C.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 5:40pm
they look a little warm, but you are at 3.8 ghz and that is a cheap cooler, so nothing really looks out of place
  Quote ZFrost Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 5:48pm
I guess more what I was wondering is am I shortening the life of the CPU by letting it run at those temperatures all the time? The cooler was the one thing I didn't do much research on before ordering and now I kinda regret it. If switching to a good air cooler with increase the life of the processor, I'm definitely for it.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 5:54pm
every aspect of overclocking shortens the life of your hardware, thats kind of the idea. but really, you wont be using that pc to game after 4ish years, and the chip will last that long.
id opt for some better cooling if it were me, but its under warranty for a reason. they set it up that way, so if it blows, and its under warranty, youre a-ok!
JJJJ_Shabadoo View Drop Down
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 6:13pm
If it were me, I'd probably go for some better cooling and, in the meantime, maybe drop your overclock a bit (I was able to drop my max core temps by about 20 degrees C just by lowering my voltage).
  Quote ZFrost Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 6:18pm
I'm pretty much clueless when it comes to overclocking, so I'm going to have to look up how to do that. But yeah, it seems like probably for the best until I can get a better cooling system.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 6:32pm
what motherboard do you have?
its a pretty easy process
  Quote JJJJ_Shabadoo Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 6:41pm
As discussed in this thread:
https://www.digitalstormonline.com/forums/forum_posts.asp?TID=11451&KW=
I'm not an overclocker either and most things I've picked up have been from the boards here.
I just went into my BIOS (I have an an ASUS board and needed to hit del on system start) and lowered the CPU voltage by a click or two at a time (in my BIOS I pressed the minus key), then entered Windows and ran Prime95.
If there are no errors, you can then lower the voltage a click or two again and run Prime95 again. Repeat.
If there are errors running Prime95, then raise the voltage up again. If you can get Prime95 to run stably for 24 hours you should be golden.
Justin also recommended lowering the multiplier to help lower temps, though in my case I was able to get my temps to an acceptable level by just lowering the voltage (and therefore not effecting my clock speeds).
Edited by JJJJ_Shabadoo - 20 Jul 2010 at 6:42pm
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 6:48pm
Hey Zfrost.  Digital Storm set my asetek cooler up with only 1 pulling fan.  Before you go replacing the entire cooler I would add a pushing fan for a "push/pull" configuration.  People on the EVGA forums that went push/pull with their Asetek/Corsair H50 have been very happy.
I had an Asetek and replaced it with a Noctua.  Although I love my Noctua I wish I'd have tried push/pull first.
Buy a good fan like the scyth gentle typhoon.  If it doesn't impact your temps on the Asetek to your liking then replace the Asetek with the Venemous X or meglahalems rev. B or similar cooler.  You can use that fan on those CPU coolers.
The Noctua's are great but their a few better performing heatsink (if you need go that route) that I'd check out befor I'd just go Noctua.
I'd also like to know what motherboard and case you have.  If you have a hole for the CPU retention plate replacing the cooler will be much easier.
  Quote ZFrost Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 6:48pm
Sounds easy enough, I definitely appreciate the help!
It's the EVGA X58 LE Edition SLI.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 9:19pm
try to edit the bios on your own. your looking to turn vcore down
you can test the new voltages a lot faster with intel burn test
if you get stuck in the bios just come back and post
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 10:59pm
81C under what load? what is your ambient temps?  without knowing those two bits of info, there is no way to tell anything.. if your ambients are 85F and load is with prime95, then you have very good temps.
If you don't mind some extra noise you can swap out the radiator fan with one that is more powerful, or just add another for a push pull setup to lower temps.
you can try to lower your V core in the BIOS, this will depend on the CPU batch you have, some need the V core that Digital Storm has inputed, some can get by on less, it is trial and error to find out.
I would not worry about temps unless you are having stability issues. use it, enjoy it. Big%20Smile
  Quote ZFrost Quote  Post ReplyReply bullet Posted: 21 Jul 2010 at 12:17pm
Well a little update, after lowering the voltage a couple of notches and opening the airflow in my computer room a bit more I've seen a pretty large improvement. It's now idling in the high 30's / low 40's, and on Prime95 stress testing it's only getting up to about 75 on a full load. I think I'll still look around for a better quality cooler, but this will work well enough for now. I appreciate everyone's help! Big%20Smile
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 21 Jul 2010 at 12:45pm
yea thats not a bad prime temp at all
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Posted: 04 Aug 2010 at 2:05pm
I know this is sort of a hijack, but can anyone explaing to me why coolers like asetek 550lc and 570LX are not real liquid cooling?
(BTW my DS system is going on 4 months old and I havent had a single problem. Not a single crash. thx DS)
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 04 Aug 2010 at 2:28pm
it's not modular, doesn't cool as well, sometimes leaks, isn't user-servicable, has a smaller reservoir/coolant capacity, and can't be customized at all. real LC involves much better and stronger pumps, more radiators (very very rarely do you see a single 120mm rad LC loop), bigger radiators, larger reservoirs, and more efficient cooling. AIO LC is like AIO desktops, have to sacrifice a lot to try to hit the user-friendly AIO mark.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 04 Aug 2010 at 2:33pm
it doesnt even have a res right? its just a small rad hooked up to a 120mm fan?
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 04 Aug 2010 at 3:26pm
I think the radiator might have some sort of tiny functionality as a res since it holds some amount of liquid at a time. LOL. LOL
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Posted: 04 Aug 2010 at 3:29pm
thx
