Question On Expected Cooling System Levels
Post Date: 2021-03-08
DMCorsa View Drop Down
  Quote DMCorsa Quote  Post ReplyReply bullet Topic: Question On Expected Cooling System Levels
    Posted: 08 Mar 2021 at 8:34am
I have an Aventum X with the Hydrolux Pro cooling package which is flexible tubing setup. Recently I discovered I had a leak and the reservoir was empty. I contacted support and Ken from DS was wonderful with his assistance getting the matter resolved, a connector fitting was bad and he walked me through replacing it and draining and refilling the system. All good.
Now I have been watching the fluid level in the reservoir like a hawk, this is the first liquid cooled system I've ever had. Over the past week the fluid level in the reservoir has dropped by 3/8" (yes, I'm that anal, I've been measuring it).
I see no leaks anywhere that I can see and easily have access to so my question is, is this normal? How much should the reservoir level drop in normal use? I expected it was a sealed system and wouldn't lose fluid that quickly.
Thanks for your thoughts.
Mike
  Quote hoserator Quote  Post ReplyReply bullet Posted: 08 Mar 2021 at 11:23am
Hi,
Having just drained the system, it is probable that there were small pockets of air in the radiators, lines, etc that with the coolant flow go into the reservoir thereby lowering the coolant level. Once that is done, you will find that it will loose some coolant to evaporation. It is not sealed like an AIO. With time you can determine the rate of loss. I loose some and I have the cpu and gpus in the loop. If you have the cpu only in the loop, I would imagine the loss would be less.
Good luck and enjoy.
  Quote DMCorsa Quote  Post ReplyReply bullet Posted: 12 Mar 2021 at 6:15am
Ah ok thank you. I do have both the CPU and GPU loops. For some reason I thought it was a closed system and didn't expect evaporation. Thanks for the information, makes sense now.
Bluegrasser View Drop Down
  Quote Bluegrasser Quote  Post ReplyReply bullet Posted: 17 May 2021 at 8:39pm
What kind of coolant did you/Digital Storm use?
  Quote hoserator Quote  Post ReplyReply bullet Posted: 18 May 2021 at 2:52am
You have to ask DS for the particular coolant used in your system. It will vary with time.
