Question on Low Cost LC options from DS
Post Date: 2010-02-14
rocketdog View Drop Down
  Quote rocketdog Quote  Post ReplyReply bullet Topic: Question on Low Cost LC options from DS
    Posted: 14 Feb 2010 at 1:06pm
I am new to the Digital Storm world. I will be purchasing a system shortly.
Initially when looking at the different cooling notions I wanted the LCLC Asetek with the 120m radiator. After reading several comments on this forum and asking input from people who are familiar with the Asetek, I have decided to go with an air cooling option (the Nocuta Dual 120).
It appears to me based on the comments I have read the Aseteck LCLC (or any LCLC option is not good).
Is this true? Is it just the Asetek that is not any good? I have read on other sites thhat the Corsair H50 is a better LCLC than the Asetek. To me they look exactly the same. I assume the manf builds both units and it is just re-branded. I have read the Corsair is better (it has been beefed up and performs very well). The Corsair site really promotes how well it works.
http://www.corsair.com/products/h50/default.aspx
See the vidro tab, then the TweakTown visited Corsair at Computex and got a bit of hands-on exclusive with the product video.
I realize neither are real LCs but for a basic config with mild over-clocking wouldn't these products work ok? Not to mention how neat they look in a system. Which is what really attracted me to the option.
It has been mentioned that the Asetek leaks. Why on earth would DS sell something that has a know problem?
My questions are:
1. If the Asetek product is so bad, why does DS even offer it as an option? When I called DS even the sales rep said it was not a good selection.
2. If the Corsair H50 is a better product why doesn't DS sell it instead?
3. Is the Corsair H50 really a better product?
I understand overall that air cooling is all one needs for the basic configuration but the Asetek/Corsair  LCLC option sure makes for a neat build.
Any comments are welcomed and appreciated.
Thank you.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 1:35pm
H50 and Asetek same exact product, go air cooling, or custom water, but IMHO stay away from them.
philiporphillip View Drop Down
  Quote philiporphillip Quote  Post ReplyReply bullet Posted: 14 Feb 2010 at 1:40pm
Digital Storm
haf 922
i7-920 oc'd @ 3.6 ghz (1.28v)
evga x58 le edition sli
cooler master v8
6 gb ddr3 1600 mhz mushkin
evga nvidia geforce gtx 295 co-op edition
1000w corsair hx
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 12:42am
Noctua d14 will give you better temps, go with it.
asetek is for budget people, its cheap and there is a reason for it.
