Questions about Liquid Cooling Systems and Bolt
Post Date: 2021-04-24
MetaknightDK View Drop Down
  Quote MetaknightDK Quote  Post ReplyReply bullet Topic: Questions about Liquid Cooling Systems and Bolt
    Posted: 24 Apr 2021 at 7:26pm
Wow... Ok first off this reminds me of the old message boards back in the day. Anyways, I have a few questions for the users of liquid cooled systems from DS. I just bought a rig that I'll post below. My questions are:
What coolant do they use in the systems? (I ordered the red.)
The loop looks really easy to disconnect with the quick disconnect they install? Should I put anything on the rest of the rig when I change it once a year?
Has anyone had problems with upgrading the graphics card in the Bolt models? It seems like you would have to pick and choose very carefully when you get a new card in the future.
I CAN'T WAIT!!! I'M SO HYPE!!! My little bro is going to order one in a few months too. Right now our current builds are so old they can barely run Hearthstone at a stable framerate.
Thanks for your time and consideration,
MDK
Chassis Model: Digital Storm BOLT X
Side Window: Edge to Edge Premium Tempered Glass
Processor: Intel Core i9-10850K (5.2 GHz Turbo) (20-Thread) (10-Core) 3.6 GHz
Motherboard: ASU STRIX Z490-I Gaming / MSI MEG Z490-I UNIFY (Wi-Fi) (Z490 Chipset) (Mini-ITX) (Up to 1x PCI-E)
System Memory: 64GB DDR4 3200MHz Digital Storm Performance Series
Power Supply: 800W Digital Storm Performance Series (Modular) (80 Plus Platinum) (Supports up to RTX 3080)
Optical Drive: - No Thanks
Graphics Card(s): 1x GeForce RTX 3070 8GB (Performance Edition) (VR Ready)
Add On Card: - No Thanks
Extreme Cooling: Digital Storm HydroLux PRO LITE (CPU Only)
HydroLux Fluid Color: Red Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System)
Chassis Fans: Standard Black Fans
Internal Lighting: Remote Controlled Advanced RGB Internal + Front Panel LED Lighting
Airflow Control: - No Thanks
Operating System: Microsoft Windows 10 Home (64-Bit)
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
Priority Build: - No Thanks, Ship Within 30-35 Business Days After Order Is Successfully Processed
Edited by MetaknightDK - 24 Apr 2021 at 8:19pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 25 Apr 2021 at 3:43am
About all I know about liquid cooling is that you MUST use exactly what came in your system to add more. Buy extra from DS now, before you need it, and while it's available.
If you have not progressed past Stage 4 in your order, you should change Storage 1 to an NVMe M.2 SSD. You have chosen the absolutely slowest SSD for your primary drive. It's a SATA part, the NVMes run on PCIe and are easily from 7x to up to 10x faster. Note none of the DS Performance Series say "NVM Express". Do not pay extra for a Samsung 980 PRO. On an Intel system it will not run much faster than a 970 EVO plus. The best bang for buck is a 500TB Firecuda.
There is no conceivable way you will ever use/need 64 Gb of RAM for gaming. Above 32 GB is a total waste of your money. Get 32 GB if you must, but put that extra into a 1TB Samsung EVO SSD for Storage 2. You will never regret that. DS is happy to accommodate changes to your order at any time, but prior to stage 4 is best for no delays.
The Bolt is very tight quarters with special mobo, special PSUs to fit. You will always have to be very aware of size in the parts you upgrade.
