Questions on gaming system
Post Date: 2007-09-04
Fondue View Drop Down
  Quote Fondue Quote  Post ReplyReply bullet Topic: Questions on gaming system
    Posted: 04 Sep 2007 at 11:21am
After alot of research I've decided to go with DigitalStorm.  I haven't bought a new computer in 4 years so I'm a little unsure if the configuration I've picked out is the right way to go for me. The computer will be used mostly for gaming, WoW and FPS. I have a 24" Dell lcd on the way and I want to be able to run whatever at high res and settings. I'm looking to spend around $4500 or less.
Case: Digital Storm Twister EXTREME (Black Anodized Aluminum Finish)
Power Supply: 1200W Thermaltake (8800 GTX SLI Compatible) (Silent Toughpower Edition)
Processor: Intel Core 2 Duo (TwisterBoost Enhanced) E6750 2.80GHz (1400MHz Front Side Bus)
Motherboard: nVidia 680i Core 2 Quad (By: eVGA) (nForce 680i SLI) (A1 Revision)
Memory: 4GB DDR2 Corsair at 1066MHz Dominator (Dual Channel) (Extreme-Performance)
Floppy / Media: Sony 1.44MB Floppy (Black Edition)
Hard Drive 1: 250GB (Western Digital / Seagate) (16MB Cache) (7200 RPM) (SATA)
Hard Drive 2: 250GB (Western Digital / Seagate) (16MB Cache) (7200 RPM) (SATA)
Raid Option: Setup my two hard drives in a Raid 0 Stripe (Read and Write Performance Boost)
Modem: - No Thanks
Video Card: 2x SLI Dual (nVidia GeForce 8800ULTRA 768MB (By: eVGA / Asus) (PCI-Express)
TV Tuner: - No Thanks
Sound Card: Creative Labs Sound Blaster X-Fi XtremeGamer (Up to 7.1 Channel) (Recommended)
Physics Card: - No Thanks
Cooling: Liquid Chilled CPU & Video Cards (TwisterBoost Overclocked) (Artic Blue Liquid)
Round Cables: Enhanced Interior Air Flow (Optical Drive & Floppy Cables (Yellow Edition)
Protection: - No Thanks
LCD Display: - No Thanks
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 04 Sep 2007 at 12:43pm
It looks great but you might suggest getting Windows Vista Premium 64-bit or downgrade to 2GB of ram.
Windows XP does not recognize 4GB of ram and can not do DX10.
commast View Drop Down
Guest
Guest
  Quote commast Quote  Post ReplyReply bullet Posted: 04 Sep 2007 at 1:20pm
Nice rig Smile I would get a much bigger hard drive for your RAID array, you'll need to install games - 2 500GB should do it. Hope you know about the RAM limit in XP and Vista (4gb max for 32 bit). Vista is getting much better with games and MS won't sell WinXP after Jan2008. Your best setup is Dual-Boot and i think DS can do it for you.
  Quote Fondue Quote  Post ReplyReply bullet Posted: 04 Sep 2007 at 1:26pm
I dont mind going with just Vista but I'm concerned about what I've read about it running games slower than XP.  Have they addressed that yet or is it still in the works?
Harry View Drop Down
  Quote Harry Quote  Post ReplyReply bullet Posted: 04 Sep 2007 at 2:02pm
Just curious way you did not go quad?
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 04 Sep 2007 at 2:11pm
Vista is great, getting better everyday. It uses memory a lot better then XP. SP1 is currently in beta and retail should be out by early 2008.
Totally up to you I guess, rumors have it that XP SP3 is due in 2008.
IMO, no point in getting a DX10 card and 4GB of ram if you are not going to use Vista.
I do not think you need a 500GB HDD either since rarely does a gamer use more then 100GB.
Edited by skyR - 04 Sep 2007 at 2:12pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 05 Sep 2007 at 12:44am
Setup looks good, but, I would drop the 4GB Memory setup, and go with a high-end Quad-Core processor. Vista is getting closer to XP in performance. I suggest you go with Vista now, it's really changed over time. Our install's do come with Vista's hot-fixes as well. If you want XP, that's fine as well.
