quiet fans and other questions
Post Date: 2010-07-07
OnBake Platinum View Drop Down
  Quote OnBake Platinum Quote  Post ReplyReply bullet Topic: quiet fans and other questions
    Posted: 07 Jul 2010 at 11:03am
I'm thinking about getting the black ops hailstorm with level 6 water cooling for CPU, chipset, and 1 video card. I've seen from the pictures on here that the smaller radiator is hung out the back of the case with fans attached to it. Would getting the noise canceling package with this setup be redundant since you have fans actually outside the case?
Another thing is that I really like the white-fan-in-black-shroud scheme the protus has. Would it cost more money to have all the (visible) fans in the case replaced with the white fan/black shroud fans? If I order it as normal, then replace the stock fans myself, would it void the warranty? Also would it void the warranty if I added nzxt white cable extensions?
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 11:11am
Noise canceling package would be redundant, and like a lot of people say, it'll also turn your case into a thermos. LoL.
You can ask to have the visible fans custom painted, would cost more though. Gonna have to message DS to figure out exactly how much. You can replace the stock fans, yeah, do whatever you want to upgrade/swap out parts, won't void the warranty ;D. I think as long as you don't screw up a part, and try to RMA it, then anything you do is fine (rest of sys will still be under warranty, obviously, warranty doesn't extend to your own parts).
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote OnBake Platinum Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 11:18am
Oh cool, thank God. I'll just order the nzxt fans (which are the white and black) along with the extensions.
I'll have to get DS to customize the memory fan to black frame and white fans to complete the package. There's no way I'd do that myself.
Cool sig btw.
Edited by OnBake Platinum - 07 Jul 2010 at 11:19am
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 11:42am
you know, you can SEND them the fans....and they'll be happy to stick em in....OR, you can tell DS to order it themselves. :D
(sig was made by !ender_, I need to get photoshop myself to make one when I take new pics)
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 11:43am
sound deadening material should not raise internal temps. Digital Storm uses very thin acoustical treatments, I have tried them, and also used 2" thick stuff that would be used in a recording studio, and with neither one did I see any temp changes.
The fans pull air in, and exhaust air out, there is little to no heat exchange through the case panel itself.. I could see it i if there where no fans at all, and the case was made of aluminum, and all of the heat transfer was based on the case panels themselves. but this is not the case here.
If the sound deadening material did increase the temps, then plastic cases would also run a lot hotter than aluminum cases, and with all the new gaming type cases running so many fans, and a lot of them made of plastic they still produce very good temps.
  Quote OnBake Platinum Quote  Post ReplyReply bullet Posted: 07 Jul 2010 at 12:34pm
I was talking about the memory fan, not the case fans. The case fans I can order and stick in myself. For their memory fan, I think they use the kingston and paint it white for the protus.
Please more input about the noise package. I really want the computer to be silent.
