Ramdurand's system
Post Date: 2008-09-20
  Quote DST4ME Quote  Post ReplyReply bullet Topic: Ramdurand's system
    Posted: 20 Sep 2008 at 2:58pm
this what you want:
here you go Ticket# 185017 --- Price: $5166 (To see this build click here)
Processor: Intel Core 2 Quad QX9770 Extreme 3.20GHz (1600MHz FSB) (12MB Cache)
System Memory: 4GB DDR3 1600MHz OCZ Platinum Edition
Hard Drive 2: - No Thanks
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 280 1GB) (Includes PhysX Technology)
TV Tuner: - No Thanks
Modifications: NVIDIA Enthusiast System Architecture (ESA) System (Install, Test, Optimize Computer)
Protection: - No Thanks
LCD Display: - No Thanks
Warranty: 4 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
Ramdurand View Drop Down
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:07pm
What about this system
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:11pm
If i order the computer without a monitor will it be a problem hooking one up when i get the system.  I ordered a dell xps a couple of years ago without the monitor and keyboard and when i went to hook them up it wouldn't accept it.  I didn't even get the computer running and i had to send it back for a refund.  Thats why i am here.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:13pm
Why not liquid cool the graphics cards?  Thanks for the help DST4ME
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:22pm
monitor setup is so easy its not even funny, you can call DS and they will walk you thru it if you don't feel comfortable.
find your monitor at newegg, you will get a better price, check here for some recommendations
no reason to OC your graphic cards, thus no reason to liquid cool them, the HAF case has great air cooling and will keep your cards cool since the CPU is being liquid cooled.
not sure what happened with your dell, I'm an ex dell customer also and I think there was something wrong with that PC, that situation is not normal at all.
But a good think it happened because this pc will kick any xps's butt.
I would recommend if you like, for you to add a second HDD (500GB) for storing your media/personal files so that the os drive stays clean and fast
Edited by DST4ME - 20 Sep 2008 at 4:54pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:29pm
With that ESA thing, how much do you have to do with that.  I am the type of person that would like to have everything ready to go so i don't have to monkey around with adjusting things.  I don't know as much about computers as you guys do.
Tyler Lowe View Drop Down
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:32pm
If you don't care about tweaking, I would not pay for ESA.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:35pm
Okay here is another question.  How much tweaking is there with a computer like this?  Once its setup you shouldn't have to touch it anymore should you?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:41pm
TL is right if you don't want to mess with stuff then remove esa
once you get the pc and runing no there is nothing to mess with.
you may want to go to your bios and write down the oc setting just incase you need them later.
but remember you can always call DS, and get an english speaking person walk you thru anything you like.
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:43pm
The ability to tweak to your heart's content with hardware like this is there. DSO is going to set it up when they build it, so if that is not something you care for, it's also not neccesary. In this way, if you are a hardcore computer enthusiast you can have fun fine tuning to your personal tastes, and if you are not, you will get a system that will knock your socks off anyway, pre-tuned for performance.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:45pm
How is the corsair power unit is it quiet?  Also what about the 64 bit vista is it easy to use.  I heard there is some issues with older programs not working.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:47pm
some very old games maybe but most programs run on vista, you can run 32bit apps on vista 64bit no problem
well its not loud but its not exactly quiet either but for your setup you can't go any lower
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:48pm
I'm running 64 bit ultimate ed, and have had zero issues with anything. Maybe before service pack 1 there were problems, but older apps just run in 32 bit mode- again, no issues I can report here.
Corsair PSU's are among the best on the market. The HX series is whisper quiet, and very efficient. The 1000W version is a touch louder than the smaller units, but very quiet for it's capacity.
Edited by Tyler Lowe - 20 Sep 2008 at 4:51pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:49pm
How much juice do you think this rig is going to use?  Is it better to get the 1200watts?  I am a newb with alot of questions.  Thanks again for your help guys
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:51pm
no 1000w is perfect, 1200 is overkill and way loud.
ask as many questions as you like, its what we are hear for
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:52pm
Thanks,  who makes a good gaming monitor
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:53pm
Samsung.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:53pm
I said this befor but I guess you missed it :
Edited by DST4ME - 20 Sep 2008 at 4:53pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:57pm
I was just looking at newegg Cool.   When DS overclocks the cpu do they all end up about the same speed?  or is each chip different.  Also with the dual video cards do you have to do anything with them before you play a game.  Set them up i mean.   Its been years since i have played a computer game.  I miss it
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 4:59pm
no the oc depends on your cooling (case, heatsink, air/liquid cooling) and mombo... well lets just say every system is different.
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:02pm
How long do you think this computer will last with out upgrading.  Right now my gateway has 512mb and a 74 gig hd Smile
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:02pm
Every chip overclocks differently. Selecting better cooling and RAM ensures you get as close to the individual chip's performance potential, but there are no garantees of the final result.
The time frame between upgrades is dependant on how tolerant you are of lagging behind bleeding edge performance. For some, this type of system might last close to 8 years. For others, they would not be comfortable using it for more than a year or 2. The choice on how often to upgrade is a function of personal taste and often, wallet.
Edited by Tyler Lowe - 20 Sep 2008 at 5:04pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:05pm
I was going to ask this before. Is 4 gigs of ram plenty?  or is more better.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:06pm
yes but in this case he is getting the top of the line CPU that is offered now, and he can't upgrade that anymore cause for the new CPU, he will need new mombo, chip, heads kink, liquid cooling.
this pc will last you a long time.
Edited by DST4ME - 20 Sep 2008 at 5:07pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:10pm
I hope it lasts along time because its alot of cash.  If i got a monitor on Newegg does it come with all the cables i would need to hook it up.  The dell thing really pissed me off with the monitor and keyboard
  Quote Tyler Lowe Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:13pm
Yeah, to upgrade your system from this, you're talking replacement, but there it is. Some people would not be able to stand the idea that something faster is out there. Other people don't upgrade until the system they own just won't do something they need it to. Again, it's a personal decision. That's not a judgement of the system as configured, just an observation about end users, and how everyone's level of tolerance for a system that is not up to the moment is different. My guess with this system, is that with a graphics card update every two years, you might be able to get a good 6 years out of it.
Edited by Tyler Lowe - 20 Sep 2008 at 5:14pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:14pm
Forget the Dell thing, like I said that is not normal.
check and see whats included with the monitor, not sure if the cabels come with it
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:16pm
One last question.  How much maintence is there with the liquid cooling?  What if it breaks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:24pm
very little maintence, you may wantto check your levels once a month, with teh haf you can just add liquid if needed.
have a look here:
other then that, you may want to clean your system every 5 years, and DS will help you with that if you like
Edited by DST4ME - 20 Sep 2008 at 5:25pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:29pm
That is an awesome case.  Do you think that 4 gigs of ram is plenty for awhile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:34pm
unless you are doing heavy graphic work, (3D and etc.,) I think 4GB is plenty for a long while, but you can always buy more and add to it, your system can hold atleast 8GB of ram.
but for games and other normal stuff you should be ok
Edited by DST4ME - 20 Sep 2008 at 5:35pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:36pm
What about that sound card Razor.  Any good?  Or would the SB be a better one to get.  I listen to alot of music on my computer now
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:40pm
widdlecat, is our sound guru and she says razer is the way to go
Edited by DST4ME - 20 Sep 2008 at 5:40pm
  Quote Ramdurand Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:44pm
Hey thanks for your help DST4ME  and Tyler Lowe.  You have been alot of help.  Thanks for saving me money.  I am sure i will have more questions in the future.Ermm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 5:47pm
Anytime boss, anytime
enjoy the pc, now to pay us back, when you get the pc, please post your review with lots of pic so we can enjoy it with you
