Ready to place an order, quick questions..
Post Date: 2012-02-24
boneshaker View Drop Down
  Quote boneshaker Quote  Post ReplyReply bullet Topic: Ready to place an order, quick questions..
    Posted: 24 Feb 2012 at 9:13am
$2000 (for rig, monitor, keyboard etc..)
I expect it to run like a champ
Gaming, basic web surfing
Ok, so I'm ready to place an order, and have a couple of questions. I have 2k to spend, but I am starting from scratch and need everything. I have been leaning towards ODE 1, and getting monitor and such elsewhere. I believe I could stay well below the 2k doing that, and in turn my wife might be a little less paranoid about spending that much LOL. The ODE 1 looks great except that I would like to change the internal lighting. Red makes me angry Haha, so I would like blue. Is that even possible to do? Also, I have been looking at other options like the Dreadnaught 3. I'm just curious if I should spend a little extra on a rig to make any upgrades later less painful. I will mostly be gaming( retired wow player itching to play TOR ). And some basic web stuff. Any advice would be appreciated.
Faded Design View Drop Down
  Quote Faded Design Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 9:33am
As a married man myself, I'd say do whatever makes her the happiest. Other then that, I can't really help. I'm a noob here and I don't know much about computers. I'm just shopping around for my dream rig same as you. I do think I read somewhere earlier in the day that they can make changes to the premade rigs, but at a $50 fee.. or something.
Good luck!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 9:35am
Hi boneshaker...Welcome to the forums.
You didn't mention monitor size or resolution you'd being playning at, so let's say a 23" monitor or less  at 1920x 1080 resolution or less.
A single gpu will let you game at that resolution on high settings,  to game on maxed out, ultra settings a sli , 2 gpu, would be needed.
The ODE 1 is good performance at a reasonable price.  But, not much upgrade potential.
The Dreadnought 3 for for about $200 more gives you a better case for cooling, the HafX...
...a motherboard able to upgrade to sli, meaning 2 Nvidia graphic cards,...
... a 800W vesus 600W power to also handle sli even though the 1050HX is better but might kick you too high....
...add overclocking stage 1 or even better stage  2 and internal lighting to match ODE 1.
To make any changes to the ODE is $50 plus any difference in cost...so in your case another $50 to cnhange to blue lighting.  Cheaper to do yourself if you went ODE.
Hope this helps.  Check it out and Good LuckBig%20SmileBig%20Smile
If you could, the second option is the better.  If budget allows.
Edited by bprat22 - 24 Feb 2012 at 9:39am
  Quote boneshaker Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 9:48am
Thank u bprat! That was exactly the response I was looking for. That is the correct assumption on monitor size and reso. I do have another older monitor that I could use for web stuff, so I have wondered if maybe I should do the whole sli thing....in the end, I think I'd be more satisfied...I have been without any computer for about a year now, and I don't want to make a decision on one, and regret it in 6 months. Thank u for your welcome and your help.
@ Faded, yea when all is said and done, if she's ok with it, that's really all that matters LOL, we just moved across the US two weeks ago, and that's not cheap...any money I can keep from spending...just want to maximize my 2k I'm allotted :-)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 9:54am
Add another gtx 570 1.2 GB card and you're off and running with sli, if budget allows.
Try to at least Cpu Boost, overclocking, to stage 1.  It's like added horsepower to the car.
And, the most important item.....Free T-shirt.Big%20SmileBig%20Smile
  Quote Faded Design Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 10:03am
I know how that is man. I just moved from Montana to Kentucky last year to follow my job. 3842 miles of, I gota pee, slow down, turn the raido down, I'm not doing that in the car........
Such is life.
  Quote boneshaker Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 10:11am
YEA, I drove from South Carolina to Seattle...wife and 2 yr old flew, but I had my 11 yr old....we didn't make it thru Tennessee before I started hearing "are we there yet" haha
  Quote Faded Design Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 10:16am
LoL.
  Quote boneshaker Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 11:54am
Building off the Dteadnought 3, but it won't let me add another vid card....thought that the mobo supported sli....or have I missed something?
  Quote Faded Design Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 12:02pm
The sli choices should be in the same list you picked the first card. If you scroll down to the bottom there should be 2x <whatever> and even 3x<whatever>'s down there.
If you're in the Add-on card list, you're in the wrong list. Just go to the video card list and scroll down.
Edited by Faded Design - 24 Feb 2012 at 12:03pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 12:03pm
I just did it no problem.  Make sure you scroll down to .....as an example.....
2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Tech) (EVGA 012-P3-1571-BR......and check the box..
The config screen has been messing for a couple of days but today seems ok.
  Quote boneshaker Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 12:27pm
Cool, I got it now...thanks..
  Quote FrankW Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 1:46pm
Hi boneshaker,
Just a couple of things to think about. You can't go SLI with the ODE-1 with our changing the power supply first. If you want SLI then look at the ODE-3. The best buy at DS.
criTalon View Drop Down
  Quote criTalon Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 2:05pm
To add onto Frank's post, ODE-1's mobo also does not support SLI.
  Quote boneshaker Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 5:15pm
Still working off the Dreadnought 3, and I'm able to keep my price where I need it. Only other question i have is the difference between a 570 1.2gb and a 570 2.5gb? Are the two vid cards that much different?
jmaster299 View Drop Down
  Quote jmaster299 Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 5:29pm
I upgraded from the 1.2GB to the 2.5GB and I saw a noticeable difference in several games. The extra VRAM helps in resource hungry games like Arkham City with Physx enabled, BF3 and GTA IV.
It also helps with extra quality detail and eye candy like AA and AF in any game.
  Quote boneshaker Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 6:43pm
Awesome...thanks
