Really Need Help
Post Date: 2009-08-21
solomon413 View Drop Down
  Quote solomon413 Quote  Post ReplyReply bullet Topic: Really Need Help
    Posted: 21 Aug 2009 at 1:27am
Ok heres my question. Ive heard that you will be limited to to DDR1333 or possibly DDR1600, depending on how well your motherboard and CPU can overclock. This is due to limitations of the memory controller on your CPU when populating all 6 slots on the motherboard. I just recently bought a computer from DS and I have 6 gigs of 2000mhz memory. Now I wanted to buy 6 more gigs of 2000mhz memory to install. so my question is if I buy the 6 gigs of memory and install it. will the 12 gigs of memory I would now have be runing at 1333 or 1600mhz instead of the 2000mhz it would be runing at if i just had 6 gigs. and would it be worth it to install another 6 gigs. plus if i do install the extra 6 gigs will it automatically start runing at 1600mhz or need bios tweaking. Here is my computers spec if it will help you.
Processor: Intel Core i7 Extreme Edition 975 3.33GHz (Quad Core) (Extreme Performance)
Motherboard: EVGA X58 Classified 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
System Memory: 6GB DDR3 2000MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Hard Drive Set 1: Operating System: 2x (256GB Solid State (By: Corsair) (Model: CMFSSD-256GBG2D)
Set 1 Raid Options: Configure HDD Set 1 to a Raid 0 Config - Stripe Performance (Requires Two HDDs)
Hard Drive Set 3: Backup\Misc.: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Optical Drive 2: Blu-Ray Writer/Reader (Burn Blu-Ray discs and play them)
Video Card: 2x SLI Quad (NVIDIA GeForce GTX 295 1.792GB) (Includes PhysX Technology)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based)
Liquid Color:Red: Non-conductive High-Performance Fluid (Requires H20: Stage 3 Cooling Package)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Boost Processor: Stage 2: Overclock the processor between 4.0GHz to 4.2GHz (Requires H20 Cooling Upgrade)
LCD Display: - No Thanks
Warranty: 4 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 2:09am
im pretty sure you cant run 2000mhz ram with all the memory DIMS populated
unless your using some crazy huge program, or multiple huge programs, you wont ever need more than 6gigs
it would be a waste buying another set of 2000mhz ram, when you couldnt run it at 2kmhz
Edited by <8) slunK parade - 21 Aug 2009 at 2:10am
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 3:05am
I would suggest 12GB of 1866MHz (Muskin Preferred) if you want 4GHz+.  Reason is there is no memory divider for 2000MHz RAM, so the bus clock has to be changed from the stock 133MHz to 144MHz (2:14 Ratio) to get the RAM speed to 2000MHz.
There is a memory divider for 1866MHz, so all that needs to be changed is the CPU multiplier, and you will easily get 4-4.2GHz.
Or if you absolutely want the 2000MHz, get only 6GB.
  Quote solomon413 Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 7:03pm
Ok thanks guys. just trying to make sure I get the most out of my computer. and on a side note I want to say you guys do excellent work on your computers. Its almost like a work of art.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 7:21pm
I say go with 6GB of 1866MHz mushkin ram.
Edited by DST4ME - 21 Aug 2009 at 7:21pm
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 8:32pm
just keep the 2k mhz ram, more than enough
Edited by <8) slunK parade - 21 Aug 2009 at 8:33pm
sirsiddius View Drop Down
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 10:30pm
Why not have DS overclock a 920 to 4~4.2ghz?
Same preformance and you end up saving $$ 1000 $$
