Rebuild help for 4k
Post Date: 2014-05-27
PawisBetlog View Drop Down
  Quote PawisBetlog Quote  Post ReplyReply bullet Topic: Rebuild help for 4k
    Posted: 27 May 2014 at 4:43pm
So I just got one of those Samsung 28" 4k monitors that can push 60Hz through DisplayPort, so now I'm wondering about a rebuild using parts from my Bolt.  I've built my own rig before, but it's probably been 7 or 8 years now and bought the Bolt last April.
Unfortunately the Bolt won't fit a second Titan, so I'm wondering what I would need to upgrade to from a case and Mobo perspective to be able to fit the second GPU.  List of current parts are below, would love any feedback.
Also, if this is a service DigitalStorm provides I'd love to know about it. :)
Motherboard: ASUS P8Z77-I Deluxe (Intel Z77 Chipset)
Power Supply: 500W Gold Plus Series Digital Storm Certified BOLT Edition (Enhanced Quiet Operation)
Hard Drive Set 1: Operating System: 1x (256GB Solid State (By: Samsung) (Model: 840 Pro Series) <b></b>
Hard Drive Set 2: Multimedia\Data: 1x (3TB Western Digital/Seagate/Hitachi/
Samsung (7200 RPM) (SATA 6Gbps) <b></b>
Optical Drive 1:  Blu-Ray Player (Blu-Ray 6x) & DVD/CD Writer <b></b>
Video Card(s): 1x NVIDIA GeForce GTX TITAN 6GB (Includes PhysX) <b></b>
Extreme Cooling: High Performance Cooler with Five Heatpipes
CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz
Is there a case and motherboard I could grab, and just use the rest of this stuff as is?  Secondary concern is whether I need a bigger power supply, thinking 2 Titans will tax that 500W unit.
Any help appreciated.
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 28 May 2014 at 5:05am
This will be a good starting resource for you:http://www.anandtech.com/show/7981/best-video-cards-april-2014.
Samsung makes lots of monitors, if you could give the native resolution of the one you bought, that would be helpful in giving you advice.
  Quote PawisBetlog Quote  Post ReplyReply bullet Posted: 28 May 2014 at 6:48am
The monitor is Samsung U28D590D, and I don't need help with the gpu, I already know I want to add a second Titan for SLI to support the 4k resolutions.
What I need help with is which motherboard and case would be best to utilize the other parts in my existing bolt rig (parts listed above). Also curious about power supply needs but I can go research that and do the math to determine whether I need to upgrade it also.
Thanks in advance for any help!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 28 May 2014 at 8:25am
Hi PawisBetlog.....  To move from the Titan Bolt to a sli Titan you can use pretty much any mid to full size case.  The ODE Corsair 600T case gives a lot of room to play in.    The Air 540, 730T , 230T all work.
For a sli motherboard, any sli mobo with lga 1155 pin count for the cpu will work.  The Z77 Sabertooth is a quality mobo.   Not sure the available of Z77, but it is getting tougher I believe.
The psu should be in the 1000 watt range and the Corsair 1050Hx is a real nice unit.
Hope this helps and good luck.  Big%20Smile
Edited by bprat22 - 28 May 2014 at 8:32am
This page was generated in 2.807617E-02 seconds.
